    problem with switching to seperate Z axis drivers
    647
    • Twigzundefined
      Twigz @Phaedrux
      @Phaedrux said in problem with switching to seperate Z axis drivers:
      I think you're going to need to add the second Z driver to your M906 command because right now I think it may be using the motor current for the extruder.
      Try M906 X900 Y1200 Z900:900 E700 I50
      i tried as you suggested, the issue remains the same, it just makes a bunch of noise and does not turn.
      Using a different motor makes the same noise with no spinning of the motors.
      one thing i noticed is that after i tried to move the Z axis one side is resisting movement while the other side is spinning easily.
      i dont know what changed to cause this behaviour, i only took the plug from the second Z connection and placed it onto the E1 connection and then used the jumpers on the Z connection.
      besides that i updated the firmware but i dont think that would make a difference?
      jeff
        dc42 administrators @Phaedrux
        That's not needed, but the M906 command does need to come after the M584 command in config.g (which it already is).
          Phaedrux Moderator @Twigz
          @Twigz said in problem with switching to seperate Z axis drivers:
          i plugged the X axis into the z motor to confirm the motors are ok and this works as it should rulling out defect motors.
          Can you describe your test a little more? Which motor did you connect to which driver?
          Twigzundefined 1 Reply Last reply Reply Quote 0
          • Twigzundefined
            Twigz @Phaedrux
            the X axis motor is close to the left Z axis motor, so i switched the connectors around so an input on the X axis would result into a movement on the Z axis and visa versa.
            The result is when i try to move the X axis via the webpage it moves up and down without any issue. no vibration and no weird noises.
            On the other hand the X axis then displays the same issue where it vibrates but does not move.
            jeff
              What happens if you connect the Z motors back to the Za and Zb connectors, then connect the X motor to the E1 connector, and change the M584 command to:
              M584 X4 Y1 Z2 E3
              Does the X axis move normally?
              • Twigzundefined
                Twigz @dc42
                @dc42 said in problem with switching to seperate Z axis drivers:
                M584 X4 Y1 Z2 E3
                i just tried connecting driver E1 to the X axis and it has the same result. connecting it back to Za and Zb also doesn't work anymore and gives the same result.
                jeff
                  deckingman @Twigz
                  jeff
                  If I've read that correctly, it's the motor or the wiring between the Duet board and the motor. Possibly a bad crimp?
                  Twigzundefined 2 Replies Last reply Reply Quote 1
                  • Twigzundefined
                    Twigz @deckingman
                    @deckingman said in problem with switching to seperate Z axis drivers:
                    jeff
                    i dont think it is the motor as they do work on other drivers, i didn't touch any cables but i will check the cables and see if they are alright.
                    edit: i think you're onto somthing, i now used the x axis wiring on E1 and this works flawlessly.
                    placing both Z axis motors on Za and Zb again now works and moves the z axis but is just very noisy, getting closer
                    jeff
                    • Twigzundefined
                      Twigz @deckingman
                      jeff
                      i went ahead and replaced the cables today and that resolved the issue. i don't know how the cables went bad but either way its fixed.
                      Thanks a lot to you and others for the suggestions.
                      jeff
                        deckingman @Twigz
                        @Twigz Pleased for you that the issue is resolved.
