Solved Y axis moving when trying to move Z axis with multiple Z motors
Yep. I just tried two axis with two motors each. Reproduced the issue.
12/21/2019, 7:02:51 PM M584 X0.0 Y0.1:0.3 Z0.4:0.5 U0.2 E0.3:0.4 12/21/2019, 7:02:58 PM M584 Driver assignments: X0.0 Y0.1:0.3 Z0.1:0.3 U0.2 E0.1:0.3, 4 axes visible
Z should be 4 5, instead it is repeat of Y's 1 3. E is wrong as well, again, a repeat of 1 3
Interestingly enough, it is OK to have multiple motors on Z and E. This is my day-to-day configuration on a tool changer:
12/21/2019, 7:06:11 PM M584 Driver assignments: X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E1.0:1.1, 4 axes visible
So, bug? One for @dc42? Thanks for getting to the bottom of it!
Certainly looks like a bug.
And I'm running what I believe to be the very latest:
Board: Duet 3 MB6HC (MB6HC) DSF Version: 1.1.0.5 Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-12-02b2)
Same thing happens if X has more than one motor, it "overlays" all later multimotor axis mappings.
12/21/2019, 7:12:02 PM M584 X0.0:0.3 Y0.1 Z0.4:0.5 U0.2 E1.0:1.1 12/21/2019, 7:12:08 PM M584 Driver assignments: X0.0:0.3 Y0.1 Z0.0:0.3 U0.2 E0.0:0.3, 4 axes visible
TRIPLE motor Z seems to work fine:
12/21/2019, 7:13:29 PM M584 X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E1.0:1.1 12/21/2019, 7:13:42 PM M584 Driver assignments: X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E0.3:0.4, 4 axes visible
However, DUAL motor Z overlays E:
12/21/2019, 7:14:39 PM M584 X0.0 Y0.1 Z0.4:0.5 U0.2 E1.0:1.1 12/21/2019, 7:14:45 PM M584 Driver assignments: X0.0 Y0.1 Z0.4:0.5 U0.2 E0.4:0.5, 4 axes visible
@Danal Triple motor Z also overwrote the E mapping
My best guess is that whatever values are getting used for multi motor mapping are not reset or filled or something between cycles of the code loop running
Yep, and it looks like it is the "single line parser" loop. Specifying each axis on a separate line yields proper results. For example, with this sequence, E never gets overlaid:
12/21/2019, 7:17:40 PM M584 Driver assignments: X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E1.0:1.1, 4 axes visible 12/21/2019, 7:17:45 PM M584 X0.0 12/21/2019, 7:17:58 PM M584 Y0.1:0.3 12/21/2019, 7:18:16 PM M584 Driver assignments: X0.0 Y0.1:0.3 Z0.3:0.4:0.5 U0.2 E1.0:1.1, 4 axes visible 12/21/2019, 7:18:34 PM M584 Z0.4:0.5 12/21/2019, 7:18:41 PM M584 Driver assignments: X0.0 Y0.1:0.3 Z0.4:0.5 U0.2 E1.0:1.1, 4 axes visible 12/21/2019, 7:18:54 PM M584 E1.0:1.1 12/21/2019, 7:18:59 PM M584 Driver assignments: X0.0 Y0.1:0.3 Z0.4:0.5 U0.2 E1.0:1.1, 4 axes visible
This also provides a bypass until this is fixed.
@Danal A workaround solution until things get a proper fix!! Fantastic. I was just about to ask what your day to day config looks like since in the example from before it E got overwritten but you had a working readout from your day to day.
@HWW said in Y axis moving when trying to move Z axis with multiple Z motors:
You are correct!!!
And I just looked in my actual config.g, and I'd separated the extruders because this is a toolchanger and I'm adding tools one at a time:
; Axis to driver mapping M584 X0 Y1 U2 Z3:4:5 ; X and Y for CoreXY. U for toolchanger lock. Z has three drivers for kinematic bed suspension. M584 E1.0:1.1 ; Extruders for four tools.
Man, a bullet dodged a few weeks back. That would have been VERY frustrating when I was trying to figure out a bunch of other stuff as well...!
I have added this as an issue to the github tracker
https://github.com/dc42/RepRapFirmware/issues/345 -
https://github.com/dc42/RepRapFirmware/issues/345It's probably a DSF issue not a RRF issue, because it doesn't happen when the Duet 3 is run in standalone mode.
It was an issue in RRF code that is only used when communicating with the SBC. Will be fixed in RRF3.0RC2.
