    [SOLVED] Bad arg letter.... on 12864 display with Maestro board
    1.4k
    • Bikerbuzundefined
      Bikerbuz @dc42
      Thanks. I'm sure it's going to work perfectly on Your Maestro just as it did on DaveA's though.
      I'm almost certain that it's something wrong with my wiring or the Maestro itself. I just can't figure out how it can miss read the files and then respond with clear and readable text if the wiring is to blame, but I'll re check all that tomorrow. For now it's a printer free night for me 🙂
        Yes it works perfectly on my Maestro.
        Please check that you really are running firmware 2.02. You can do that by sending command M115 from DWC or over USB.
        Bikerbuzundefined 1 Reply Last reply Reply Quote 0
        • Bikerbuzundefined
          Bikerbuz @dc42
          Well, I downloaded ver. 2.02a from here and installed it Without any errors. It had ver 1.something before and It now reports ver '2.0(RTOS) (2018-06-05b3' from the software information tab on the settings page. With M115 in DWC I get this:
          FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-05b3
          Do You mean that it could somehow be another version? Should I try installing the latest beta?
            Phaedrux Moderator @Bikerbuz
            @bikerbuz You're still not running 2.02.
            Download this zip file https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02a.zip
            Upload the whole zip file through the DWC and everything should get updated properly. Use M115 again to check.
            • Bikerbuzundefined
              Bikerbuz @Phaedrux
              @phaedrux
              Ok, Thanks. I had already gone to bed when You posted and I'm at work now, but I'll do that when I get home tonight.
              I reeeally hope that will fix it 🙂 This time difference is a bitch...
              • Bikerbuzundefined
                Bikerbuz @Bikerbuz
                @Phaedrux
                Downloaded the file here at work and thats the exact same file that I already installed, so I guess I did something wrong (go figure) when I installed it. I'll let You know how it goes tonight 👍
                  It might be that the version of Duet Web Control you were running initially didn't handle the case of a main firmware file being included in a zip file. If so then it might work second time.
                  • Bikerbuzundefined
                    Bikerbuz @dc42
                    Ahh, ok. I hope that's the issue. I've already done a couple of tests and it prints great.
                    If the display starts working, that's the last "hurdle" in my rebuild of the Mecreator2. For now that is.
                    The next step is to make the extruder all metal, so I can increase the temp and hopefully print nylon.
                    Maybe even PC at some point as I have a couple of rolls of that stuff.
                    If that works, I might try out a bowden setup so it can use all of the bed surface. Now it doesn't quite reach the front edge, due to the bulky extruder setup. An extra 5-10mm would be great for printing RC car bodies... I'll let You know tonight if things worked out 🙂
                    • Bikerbuzundefined
                      Bikerbuz
                      @Phaedrux @dc42 @davea
                      Success 😄
                      A big thanks to all of You for Your help and Your patience. It's greatly appreciated.
                      It's a bummer that I can't return the favor. At least not any time soon...
                      I'm officially retracting my claim in my first ever post on here, that I thought I understood the basics of how the Duet boards work.
                      That's clearly not the case, but I hoping to slowly learn as I go along in this endeavor.
                      • JaneRoggerundefined
                        JaneRogger
                        Thanks for the solution. Now i am gonna watch netflix movie.
                        freeaccountsonline.com
