    Dual gear extruder drive
    741
    • jens55undefined
      jens55
      I am waiting for confirmation from my supplier but I think the BMG-X2 can only be used with the Chimera/Cyclops in a direct extruder configuration rather than a bowden setup. I am not yet prepared to go direct.
      The extruder for a CR-10 is $115 CDN each with no motor (the BMG-X2 was a two extruder configuration with motors). Last night I decided to blow $17 CDN for a Chinese clone to see what I get. I fully expect it to be lower quality but by the time taxes are included the real thing is about ten times (!!!) the cost of a clone which is crazy.
      My curiosity will be satisfied by the end of January.
      Re the Hermera, I would like to stick with my Chimera setup for now.
      • Danalundefined
        Danal
        Keep us posted! It will be very interesting to see how that all works out.
        • cdl1701yahoo.comundefined
          cdl1701yahoo.com
          I have had a bondtech QR, Bondtech BMG and the BMG x2 as well as a few clones, I ended up designing and printing my own gear housings and just using the gears from them. The Clone gears wear out much faster than the genuine bondtech gears so now I just buy bontech gears and parts.
          I have customized my housings to work with the printer design I am working with rather than conforming to the standard Bondtech designs. I highly recommend going dual gear over single gear, you will not regret it.
          Just a side note on the BMG x2, I never did get it working to my satisfaction although that was not a reflection on the extruder but more on the E3D Chimera (genuine). I personally cannot recommend the Chimera/Cyclops as a hotend.
          • jens55undefined
            jens55
            The only issue I have with the Chimera is it's tendency to string with a Volcano hot end but I always felt that was due to the large melt chamber in the Volcano.
            I am looking forward to receiving the clone BMG. If the concept improves things to the extent everybody says it does then I don't mind spending money on the original but spending that kind of money without feeling confident on the result seems a bit foolish.
            Can you confirm that the BMG-X2 can not be used in a bowden tube setup ?
            cdl1701yahoo.comundefined 1 Reply Last reply Reply Quote 0
            • antlestxpundefined
              antlestxp
              I'm not ashamed to say the TriangleLabs bmg clones work the same as the originals. I bought the clone to see how I would like them. Then bought the originals to support the company that actually put in the RnD. Sorry to say they print exactly the same. I will always say support genuine products but if cost is a limiting factor, majority of the stuff coming out of trianglelabs is top notch. Side note, the TL e3d titan clones are actually better than the original e3d products.
              • jens55undefined
                jens55
                Good to know! Here is hoping ....
                • zaptaundefined
                  zapta @Danal
                  @Veti said in Dual gear extruder drive:
                  what about the new e3d Hemera? i am intrigued by it but waiting for the smaller motor version.
                  I presume for a direct extruder configuration. Same here though in a recent video, Tom compared overall weights and if I recall correctly, it was not as bad as it looks.
                  The hemera has a very short path from the extruder to the nozzle. Same for some metal BMG clones that uses the extruder body as a heatsink.
                    cdl1701yahoo.com @jens55
                    @jens55
                    The x2 is not designed to be used with a bowden set up but that does not mean that it cannot be modified to work. Here is an image of the bottom of the main body of mine.
                    I suppose you could drill out the plastic holes to fit a push-in fitting for the bowden tube.
                    • jens55undefined
                      jens55
                      Thanks ! That is exactly the view I was looking for and that isn't published anywhere.
                      Probably doesn't even need to be drilled out, just print a tight fitting press fit internally threaded adapter to fit into the recess, screw in a regular pneumatic fitting and Bob is your uncle. I use that method in a couple of other areas and it's working well.
                      Good to know that this is another option.
                        @jens55
                        The dimensions of those larger diameter holes is 10mm diameter x 5mm deep.
                        the depth of the internal hole is about 17mm that fits the PTFE tube.
