    Ender 3 Non-Pro Loud steppers when idle and moving.
    395
    • smith505undefined
      smith505
      Duet 2 Ethernet
      Please let me know if theres any other info needed.
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      zecchiundefined 1 Reply Last reply Reply Quote 0
        A Former User
        Loud isn't very specific; but common issues would be high inductance and low voltage or one phase not connected properly.
        Elaborate a little on the sound, motor specs and supply voltage please.
        smith505undefined 1 Reply Last reply Reply Quote 0
        • smith505undefined
          smith505
          @bearer
          https://www.reprap.me/creality-3d-two-phase-42-34-reprap-42mm-stepper-motor-for-ender-3-3d-printer.html
          https://www.youtube.com/watch?v=JWDe56KYB_w Video of my printer. Thanks for the reply.
            A Former User
            Rules out one phase. 12v presumably? Its probably as quiet as it will be without enabling stealth chop or what its called.
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
            In particular the D and V parameters. Not familiar with the Ethernet version so others will have to provide any further guidance.
            • Vetiundefined
              Veti
              have you read
              https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise?
              • smith505undefined
                smith505 @Veti
                @Veti Been testing all day and still sound like poop. Thanks though!
                • smith505undefined
                  smith505 @A Former User
                  @bearer Also was messing with D and V parameters. Helped slightly but they're still really loud.
                  • Vetiundefined
                    Veti
                    @smith505 said in Ender 3 Non-Pro Loud steppers when idle and moving.:
                    are you sure about those currents?
                    compare to https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                    • zecchiundefined
                      zecchi @smith505
                      @smith505
                      I don't know if what I've done is correct but I've solve the noise of steppers changing step-per-mm
                      Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      • Vetiundefined
                        Veti @zecchi
                        @zecchi said in Ender 3 Non-Pro Loud steppers when idle and moving.:
                        i dont know about you, but i prefer correct prints to noise.
                        • zecchiundefined
                          zecchi @Veti
                          @Veti
                          I'm completely agree. Nevertheless the change is of half steps ( or minus)
                            Phaedrux Moderator @zecchi
                            @smith505
                            I don't understand. How does that solve the problem of noise? If the steps per mm are wrong the print will be the wrong size. Do you solve that by scaling the model in the slicer?
                            • smith505undefined
                              smith505 @Veti
                              @Veti Yessir im sure about the currents as the ones in the link you put are the same besides the Extruder.
                                Phaedrux Moderator @smith505
                                @smith505 You may be able to reduce currents a bit and still have good results. Try 700, 600, 500 and do a test print between. There should be some improvement in sound. How low you can go on current will depend on your acceleration and speed settings.
