    Ender 3 Non-Pro Loud steppers when idle and moving.
    395
      A Former User
      Loud isn't very specific; but common issues would be high inductance and low voltage or one phase not connected properly.
      Elaborate a little on the sound, motor specs and supply voltage please.
      smith505undefined 1 Reply Last reply Reply Quote 0
      • smith505undefined
        smith505
        @bearer
        https://www.reprap.me/creality-3d-two-phase-42-34-reprap-42mm-stepper-motor-for-ender-3-3d-printer.html
        https://www.youtube.com/watch?v=JWDe56KYB_w Video of my printer. Thanks for the reply.
          A Former User
          Rules out one phase. 12v presumably? Its probably as quiet as it will be without enabling stealth chop or what its called.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
          In particular the D and V parameters. Not familiar with the Ethernet version so others will have to provide any further guidance.
          • Vetiundefined
            Veti
            have you read
            https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise?
            • smith505undefined
              smith505 @Veti
              @Veti Been testing all day and still sound like poop. Thanks though!
              • smith505undefined
                smith505 @A Former User
                @bearer Also was messing with D and V parameters. Helped slightly but they're still really loud.
                • Vetiundefined
                  Veti
                  @smith505 said in Ender 3 Non-Pro Loud steppers when idle and moving.:
                  M906 X800 Y800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                  are you sure about those currents?
                  compare to https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                  • zecchiundefined
                    zecchi @smith505
                    @smith505
                    I don't know if what I've done is correct but I've solve the noise of steppers changing step-per-mm
                    Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    • Vetiundefined
                      Veti @zecchi
                      @zecchi said in Ender 3 Non-Pro Loud steppers when idle and moving.:
                      i dont know about you, but i prefer correct prints to noise.
                      zecchiundefined 1 Reply Last reply Reply Quote 0
                      • zecchiundefined
                        zecchi @Veti
                        @Veti
                        I'm completely agree. Nevertheless the change is of half steps ( or minus)
                          Phaedrux Moderator @zecchi
                          @smith505
                          I don't understand. How does that solve the problem of noise? If the steps per mm are wrong the print will be the wrong size. Do you solve that by scaling the model in the slicer?
                          • smith505undefined
                            smith505 @Veti
                            @Veti Yessir im sure about the currents as the ones in the link you put are the same besides the Extruder.
                              Phaedrux Moderator @smith505
                              @smith505 You may be able to reduce currents a bit and still have good results. Try 700, 600, 500 and do a test print between. There should be some improvement in sound. How low you can go on current will depend on your acceleration and speed settings.
