ZA and ZB connections ?
@Veti said in ZA and ZB connections ?:
j'attends toujours la sortie des commandes multibles G32
Is that what you want to talk about?
Hi Rudy2A,
my experience is, that the Z-axis of the hypercube isn't rigid enough. The frame of the bed bends to much. I would suggest you to improve that fist.
Try to find z-carriages witch connect the beams by plates.For my modification you will need new bearings. But I have seen similar parts for the standard bearings on thingiverse.
You should also replace the springs by silicon dampers.
After that, the Z-Axis is absolutely reliable. Forget about levelling before every print.
Auto bed leveling can't compensate mechanical weakness.Regards
Frank -
yes. that means your bed is so bad that it does not do any adjustment.
you will need to manual get the bed close to a flat area before you can do normal G32 adjustment. -
you will need to manual get the bed close to a flat area before you can do normal G32 adjustment.Even with these values (I can not do better ), nothing happens !
I'm starting to get lost because I don't understand something!
If the limits of the correction points must not exceed 0.00 mm, what is the point of making an automatic correction with G32, since the limits being at 0, there will be no automatic correction?I post my files, if a charitable soul can take a look and correct it would be great!
Thank you !
@DIY-O-Sphere said in ZA and ZB connections ?:
mon expérience est que l'axe Z de l'hypercube n'est pas assez rigide
Thank you for this advice.
M671 X-10: 240 Y0: 0 S0,5; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de l'axe X
duet uses . and not , for decimal, so this command does not work.
M584 X0 Y1 Z2: 4 U4 E3 P3 ; deux moteurs Z connectés aux sorties pilote Z et E1
there should be no spaces in a lot of your commands.
also you should delete the u axis. it is not neededM207 ; Paramétre de rétraction
thats not a command for the config. it has no parameters.
M558 P1 X0 Z0
bltouch is P9, and this config line is missing a lot of parameters.
G31 P500 Z1.48
you are missing the offset of your probe
Thank you for being so kind to watch ...
However, I didn’t understand everything.
utilisations en duo. et non, pour la décimale, donc cette commande ne fonctionne pas.
S0,5 Is he the problem?
il ne devrait pas y avoir d'espace dans beaucoup de vos commandes.
vous devez également supprimer l'axe u. ce n'est pas nécessaireOK
OK
ce n'est pas une commande pour la config. il n'a pas de paramètres.
M558 P1 X0 Z0
This is not an order for the mini IR probe?
bltouch est P9, et cette ligne de configuration manque beaucoup de paramètres.
G31 P500 Z1.48
il vous manque le décalage de votre sonde
I do not use BLTouch, but a mini IR probe ... It seems to me that there is no lag? (to check)
@Rudy2A said in ZA and ZB connections ?:
yes
i assumed you have a bltouch because of this
M307 H3 A-1 C-1 D-1 ; Désactiver le chauffage sur le canal PWM pour le BLTouchbut even the mini ir probe has an offset. without the offset you probing will be wrong
S0,5 Est-ce le problème?
It’s with people like you that we move forward!
As I start and sometimes I am a little stupid ... if it is not S0.5 what to put, I simply copied from a previously cited example.
For the rest I understood ...
you have to write S0.5
you wrote S0,5notice , and . duet does not use , for decimal representation.
vous devez écrire S0.5
vous avez écrit S0,5Ok ... frankly, I was far from that mistake
. Thank you !
Hello, thanks to the members of this forum and more particularly to Veti.
I solved my problem and my current tests are very good. I only have a few small adjustments left and everything will be on top!
I still have a question ... I would like to get the best out of G32 and G29 in my impressions. How do you go about your settings?
You make a G32 in your slicer and you included in your Bed.g G29 or G29S1 file or else, you put G32 and G29 (S1) or vice versa in your slicer or do you use another method?
I take your advice once again.
if you run G32 then you need to run a G29 and not a G29 S1.
si vous exécutez G32, vous devez exécuter un G29 et non un G29 S1.
Very good, but in what order? G29 followed by G32 (or vice versa in my slicer or G32 in my slicer and G29 in my Bed.g or other file?
The best solution...
You can put everything in your slicer gcode if you want it to run before the print every time.
You can use G32 for the leveling tilt first, and then do a g29 to map the surface of the bed. The g29 could be within bed.g and called as part of G32 (which just calls bed.g) or you could have it as a separate command in the slicer start gcode. Up to you. But it is important to correct for tilt before doing the mesh compensation.
More simply:
Slicer start gcode:
G28 ; home the printer G32 ; level for tilt G29 ; mesh bed compensation mapping
@Phaedrux said in ZA and ZB connections ?:
Vous pouvez tout mettre dans votre gcode slicer si vous voulez qu'il s'exécute à chaque fois avant l'impression.
Vous pouvez d'abord utiliser G32 pour l'inclinaison de mise à niveau, puis faire un g29 pour cartographier la surface du lit. Le g29 peut être dans bed.g et appelé dans le cadre de G32 (qui appelle simplement bed.g) ou vous pouvez l'avoir comme une commande distincte dans le slicer start gcode. Dépend de vous. Mais il est important de corriger l'inclinaison avant de faire la compensation de maillage.Thank you, quick and precise !!!
This forum is like Duet material, that is to say of quality !!!
It's quite in order to run G32 to correct for loss of sync of the Z motors, followed by G29 S1 to load a height map to compensate for gantry sag and any undulations in the bed surface.
Happy New Year everyone !
I spoke too quickly ... I realized that when I wanted to print large pieces the leveling of the bed did not work finally!
While searching the forum, I found a case very close to mine, but unfortunately that has apparently not been resolved!
However, I would point out that before my mini IR probe, I had a BLTouch and the problem was the same!
Thank you.
Are you now using G32 to level the two sides of the bed, with the two Z motors connected to separate drivers? If so, after running G32, do you then get a level height map if you run G29 S0 ?
