    Control of Keenovo heat bed.
    25
    1.3k
      A Former User @jens55
      @jens55 said in Control of Keenovo heat bed.:
      The default 10 hz
      is it? i asked because i tried:
      (maybe the experiment is flawed?)
      • jens55undefined
        jens55
        I am pretty sure it is 10hz for the Duet2wifi as I did not explicitly set up frequency. Are you running 2 or 3 ?
          RFF3 on Duet 3, just don't recall reading it changed, or mentioned in the upgrade notes and its potentially a bit of a big deal. Will fire up the Maestro and see if there is a difference between RRF2 and RFF3 when i get a chance.
          • Garfieldundefined
            Garfield
            Bearer - do you have an M308 line defining the sensor before the M950 line ?
            That said the gcode documentation for M950 states
            T Temperature sensor number, required only when creating a heater [not yet implemented]. See M308.
            The online generation tool adds the sensor to the M950 line - perhaps the Tx serves no purpose but then how do you assign a sensor to the heater ???
              RRF2 and RRF3 on Duet 2 assume that heater 0 is the bed heater until you tell it otherwise using M141. RRF3 on Duet 3 doesn't have a default bed heater. The best option when using RRF3 with a SSR is to specify the frequency explicitly in the M950 command that creates that heater.
                A Former User @Garfield
                @Garfield said in Control of Keenovo heat bed.:
                to be honest i don't have a heather nor a sensor, the board is on a cnc router
                  A Former User @dc42
                  @dc42 said in Control of Keenovo heat bed.:
                  That could probably have been made clearer somewhere, but makes sense as you move away from predefined roles for pins. Thanks for clearing that up!
                  • Garfieldundefined
                    Garfield
                    So is the gcode documentation in error - is the T statement implemented now ?
                      dc42 administrators @Garfield
                      Yes, it's been implemented for a long time.
                      • Garfieldundefined
                        Garfield
                        No worries - needs updating in the documentation.
                          @droftarts, please fix this, also check whether the RRF3 wiki page has the same error. I'm on a smartphone, otherwise I'd do it myself.
                          • Garfieldundefined
                            Garfield
                            It's OK on reprap.org
                            On this page it says not yet implemented
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                              droftarts administrators @dc42
                              @dc42 Updated Gcode page, removed "not yet implemented". https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                              RRF3 wiki page was correct already. https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M950_Create_heater_fan_or_GPIO_servo_port
