G1 H1 X-355 F3000 does not work as expected
388
    spllg
    G1 H1 X-355 F3000 stops movement before reaching endstop when y < ~100. this makes homing unreliable.
    what can i do to get this fixed? (except homing y first and move to y > ~200)
    y does not suffer from this.
    when properly homed x can be moved anywhere without any issues.
    hw: duet 3 6hc rev 1.0
    sw: FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1
    conf: corexy printer
    regards, gsp
    undefined undefined 2 Replies Last reply 31 Dec 2019, 09:09 Reply Quote 0
      jay_s_uk @spllg
      @spllg how big is your printer?
      Try increasing the -350 to a larger number. I use -999 in mine which is larger than my print size.
      undefined 1 Reply Last reply 31 Dec 2019, 12:34 Reply Quote 0
        dc42 administrators @spllg
        Please upgrade your firmware to 3.0RC2.
        undefined 2 Replies Last reply 31 Dec 2019, 12:16 Reply Quote 1
          spllg @dc42
          @dc42 upgrading to 3.0RC2 made things worse:
          • after an initial failed x-home (from x=100,y=0, g1 h1 premature stopped at invisible endswitch) a subsequent x-home attempt (null-effect) did not terminate
          • after a successful x-home from (x=100,y=120) a z-home caused one spindle to move upwards while the other spindle did not move (dual z-steppers) resulting in a very ugly noise.
          reverted to 3.0beta12
            spllg @jay_s_uk
            @jay_s_uk already have tried this - could not observe any change
              spllg @dc42
              @dc42 i feel, the problem might be related to micro step configuration as the y-threshold changes when i change micro step configuration (using m350 xnn ynn)
              ? 1 Reply Last reply 31 Dec 2019, 13:12 Reply Quote 0
                A Former User @spllg
                @spllg said in G1 H1 X-355 F3000 does not work as expected:
                don't recall the specifics, but changes to microstepper or steps/mm after the other will affect the former. I.e. the order matters. show your config and I'm sure someone will spot any issues there.
                  Danal
                  Yes, please post your entire config.g
                  undefined 1 Reply Last reply 31 Dec 2019, 13:50 Reply Quote 0
                    spllg @Danal
                    @Danal here it is
                    M550 P"3dd" ; set printer name
                    M667 S1 ; select CoreXY mode
                    M569 P0.0 S1 ; physical drive 0.0 goes forwards ; XY - right
                    M569 P0.1 S1 ; physical drive 0.1 goes forwards ; XY - left
                    M569 P0.2 S1 ; physical drive 0.2 goes forwards ; Zr
                    M569 P0.3 S1 ; physical drive 0.3 goes forwards ; Zl
                    M569 P0.4 S0 ; physical drive 0.3 goes forwards ; E0
                    ;M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                    ;M584 X0.0 Y0.1 Z0.3 E0.3 ; set drive mapping
                    M584 X0.0 Y0.1 Z0.2:3 E0.4 ; set drive mapping
                    M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm
                    M203 X12000.00 Y12000.00 Z3000.00 E3600.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z25.00 E250.00 ; set accelerations (mm/s^2)
                    M84 S30 ; Set idle timeout
                    M208 X-26 Y0 Z0 S1 ; set axis minima
                    M208 X280 Y300 Z340 S0 ; set axis maxima
                    M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io3.in
                    M574 Y1 S1 P"io4.in" ; configure active-low endstop for low end on Y via pin io4.in
                    M574 Z1 S1 P"io5.in" ; configure active-low endstop for low end on Z via pin io5.in
                    ; bed leveling
                    ;M671 X50:150 Y150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                    ;M558 P1 C"io5.in" H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    ; Z-Probe ( https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type )
                    ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    ;M557 X15:215 Y15:195 S20 ; define mesh grid
                    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                    ; 2DO: fix and all below
                    M143 H0 S110 ; set temperature limit for heater 0 to 120C
                    M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                    M950 F0 C"out4" Q500 ; create fan 0 on pin out3 and set its frequency
                    M106 P0 H-1 ; set fan 0 value. Thermostatic control is turned off
                    ;M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"out5" Q500 ; create fan 1 on pin out4 and set its frequency
                    M106 P1 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
                    ;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                    undefined 1 Reply Last reply 31 Dec 2019, 14:43 Reply Quote 0
                      deckingman @spllg
                      @spllg The Z movement issue might be caused by this M584 X0.0 Y0.1 Z0.2:3 E0.4 which ought to be M584 X0.0 Y0.1 Z0.2:0.3 E0.4. Also, strictly speaking M667 is deprecated so M667 S1 ought to be M669 K1.
                      It might be an idea if you post your homing files too.
                      undefined 1 Reply Last reply 31 Dec 2019, 15:57 Reply Quote 2
                        spllg @deckingman
                        @deckingman changing the 2 suggested lines solved both issues - x-homing now works fine using 3.0RC2
                        thanks a lot
                        2 out of 11
