    Delta printer belts and 16 tooth pulleys
    3D Printing General Chat
    2.8k
    • bartolomeusundefined
      bartolomeus @garyd9
      @garyd9 here it is, nothing special and it doesn't have a tensioning system: https://www.thingiverse.com/thing:3167267
        Phaedrux Moderator @Danal
        Are you ok @Danal? Something seems to be rubbing you the wrong way.
        garyd9undefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal
          Hmmm... tone is hard when just typing. Nothing is wrong as far as I know, just really trying to balance perfection and pragmatism.
          Annnnd I always have a tendency to over-explain. 🙂
          Thank you very much for asking!
            @Danal 🤦 It was a play on the belts rubbing.
            • Danalundefined
              Danal
              WOOOOSH!!! Man, that went right over my head!!! And I normally catch those.
              Good one!
              • garyd9undefined
                garyd9 @Phaedrux
                @Phaedrux his teeth are on edge...
                Phaedruxundefined 1 Reply Last reply Reply Quote 2
                  Phaedrux Moderator @garyd9
                  @garyd9 👌
                  • garyd9undefined
                    garyd9
                    After reading this thread, I'll acknowledge that a belt rubbing might not matter and everything works "good enough."
                    However, a person can also argue that using an 8 bit board to control a delta with 1.8 degrees stepper motors is also "good enough." Or that if rod spacings are within 2/10th of a mm of each other, it'd be good enough.
                    However, once I know about a potential issue, I can't help but to want to solve it. I suspect that most people currently posting in this thread are similar...
                    So, I've scoured thingiverse for some type of belt tensioning system idea that is adjustable, wouldn't rub, and that I can use with my own model. So far, in 2 hours of searching I've only found one. (Keep in mind that thingiverse is painful to search as well as incredibly slow - and that I have to actually download STL files, and import them into fusion 360 to properly measure the gaps.)
                    Here's a carriage designed for use with v-slot wheels that uses a belt tensioning "system" that is only attached to the carriage by a single M3 bolt and leaves plenty of room for the "return" belt: https://www.thingiverse.com/thing:2183347
                    Being that the only attachment between the carriage and the tensioner is a single M3, it should be easy to fit this type of system on anything with minimal effort. I have to admit that I'm trying to find something wrong with this tensioning "system." It just seems too simple and not nearly fancy enough to work properly.
                    • Danalundefined
                      Danal
                      Hmmm... if they are that rare, then here is one more. This is the one I've been running, modified to be 8mm core. This MIGHT cause issues with the 3mm tension screw; may have to go to 2mm screw.
                      Photo is of an old "fat core", just to make the traveler/tension easier to understand.
                      Carriage for HWIN 55mm Mag 9mm belt - Traveler.stl
                      Carriage for HWIN 55mm Mag 9mm belt V6.stl
                      • garyd9undefined
                        garyd9 @Danal
                        @Danal said in Delta printer belts and 16 tooth pulleys:
                        As you suspected, thinning out the core creates a problem with the M3 tension screw. A 3mm hole in a 4mm block of plastic doesn't work well.
                        What might work instead is to instead thin out the "wall" that runs the entire length of the carriage (which is 3mm thick in the stl's you posted) to 2mm and then thicken the traveler and section where the M3 screw goes up to 5mm (from 4mm in the files you posted.) That might require shifting everything to one side.
                        How does the traveler work on this? Do you glue the nut in place on the carriage?
                        I might mock up something similar tonight or tomorrow and see how it works out.
                        • Danalundefined
                          Danal
                          The nut tends to stay in place.
                          This is all openSCAD by the way, I can post those files as well. I did not, because the forum won't accept that file extension and I will have to zip them or something.
                          I'll change the various widths in a few min.
                            It won't take zip files either. You'd have to change the extension to .txt or something or host it elsewhere and link it.
                              dc42 administrators @Phaedrux
                              I have added .scad to the list of allowed file extensions.
                              • Danalundefined
                                Danal
                                THANK YOU!! What a rapidly delivered 2020 gift!
                                • Danalundefined
                                  Danal
                                  Updated for 2mm buffer, 1mm space for belt, 5mm clamps and travelers. 8 total.
                                  Carriage for HWIN 55mm Mag 9mm belt V6.scad
                                  • garyd9undefined
                                    garyd9 @Danal
                                    @Danal This looks good. Thank you. Is there a different scad file for the traveler?
                                    Also, I'm wondering what plastic you used to print this. While I might tend towards ABS or PETG for "workhorse" parts, I wonder if PLA is better due to the need for exact spacing on the magballs, and for the hardness of PLA (so the magballs don't flex with movement..)
                                    • Danalundefined
                                      Danal
                                      I used PLA.
                                      I will update the traveler in a few min (just forgot that it's width needed to change as well.)
                                      • garyd9undefined
                                        garyd9 @Danal
                                        I used PLA.
                                        Modified from the file on thingiverse.
                                        Carriage_for_HWIN_55mm_Mag_6mm_belt_-_Traveler.scad
                                        Thank you!
                                        • Danalundefined
                                          Danal
                                          Thanks, @garyd9, obviously I got sidetracked.
                                          Thanks again.
                                            I just checked my delta. You are right, they do rub slightly. The machine might be a little quieter if they didn't. It looks like there is enough material so that the part that touches the belt could be milled down a little.
