    Z axis issue: wrong movement (layers)
    My Duet controlled machine
    1.9k
      @zecchi said in Z axis issue: wrong movement (layers):
      M203 X6000.00 Y6000.00 Z1200.00 E4800.00 ; set maximum speeds (mm/min)
      1200 may be a bit too fast for your Z axis. Try reducing it by half. Perhaps it's missing steps or binding. Though this is likely offset by the very low acceleration value.
      Can you test the repeatability of your Z axis? Set to a known position marker and then move the z axis up and down many times and see if it returns to the same starting position.
      (0.26, 0.18, 0.24... )
      What is the full step resolution of your z axis? You show that it's belted to the lead screw. Is there a gear reduction involved? Is the belt slipping the teeth?
      The motor current for the Z axis is 1000. What is the rated current of the motor? Ideally you should set the current to be 70-85% of the rated max current of the motor.
      You're using anti-backlash nuts. They typically are not necessary on the Z axis since there is constant downward force on the bed from gravity and the bed is always dropping away from the nozzle during a print. They can increase friction however to the point they cause binding.
      Have you lubricated the lead screws?
      zecchiundefined Phaedruxundefined 6 Replies Last reply Reply Quote 1
      • zecchiundefined
        zecchi @Phaedrux
        @Phaedrux said in Z axis issue: wrong movement (layers):
        Thanks for your replay.
        I'll try later.
        • zecchiundefined
          zecchi @Phaedrux
          There is a 1 to 1 ratio
          • zecchiundefined
            zecchi @Phaedrux
            Belts are quite tight, I don't think they can slip (I hope… no noises , nothing that make me to think they are slipping )
            • zecchiundefined
              zecchi @Phaedrux
              Ok, it was too low. I set 1200 mA (80% of 1.5A). Unfortunately the error doesn't disappear.
              • zecchiundefined
                zecchi @Phaedrux
                I'll try to remove nuts and use normal ones. Also I'll try to clean and re-lubricate the lead screws
                • zecchiundefined
                  zecchi
                  News:
                  -Repetitivety Is ok, tested with a dial indicator
                  -I've change the nut. Some improvements but the error doesn't disappear.
                  Other advices?
                  • SIamundefined
                    SIam
                    it looks like a z-wobble dubble (tripple) check the Z-Axis motion this must be stable and run smooth (it can be a nightmare to find the right position)
                    Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                    Duet WiFi 1.02 or later + DueX5
                    RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                    Duet WiFi Server: 1.26
                    Duet Web Control 3.4.0beta4 (2021-09-27)
                    zecchiundefined 1 Reply Last reply Reply Quote 0
                    • zecchiundefined
                      zecchi @SIam
                      @SIam
                      I've printed a piece in order to fix the lead screws at the exactly center of the two rods, quite good but I didn't solve the problem.
                      Any suggestions?
                        Phaedrux Moderator @zecchi
                        Look for more sources of binding. The smooth rods and bearings would be my next target.
                        • zecchiundefined
                          zecchi
                          Also rods are checked. Z axes is absolutely perfect, tested with a dial indicator (only 0.01mm of error in 300mm ). I've also printed a jig in order to have the rods at the same distance.
                          But , layer are, still, inconstant (0.24, 0.18, 0.22 ecc...) And this cause the blob (I'm pretty sure about that ).
                            Phaedrux Moderator @Phaedrux
                            @zecchi What is the pitch/lead of your lead screws?
                            The problem really seems to be similar to trying to print at a layer height that isn't a multiple of the full step resolution of the Z axis.
                            https://blog.prusaprinters.org/calculator/#optimallayer
                            zecchiundefined 2 Replies Last reply Reply Quote 0
                            • zecchiundefined
                              zecchi @Phaedrux
                              @Phaedrux
                              2mm pitch. (I ordered the 8mm pitch but it arrived wrong).
                              • zecchiundefined
                                zecchi @Phaedrux
                                @Phaedrux
                                I've shorter 8mm pitch lead screws. I'll try with them.
                                  2mm pitch.
                                  Well there goes that theory.
                                  With a 2mm lead, and 1.8 degree motors (deduced from your 1600 steps per mm on Z) your full step resolution is 0.01mm. So you have no limits there.
                                  What are the motor specs?
                                  • zecchiundefined
                                    zecchi @Phaedrux
                                    @Phaedrux
                                    So, if my layer height is 0.2mm isn't a problem, correct?
                                    Motor: 1.5A , 1.8°. Classic 17HS4401 stepper motor.
                                    Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      @Phaedrux
                                      Correct
                                        I'm unable to find a data sheet that seems close. There are many sub-models of 17H4401 between many manufacturers. I didn't even see any that were 1.5a.
                                        Can you find a data sheet that seems to match your motor based on what you know about it?
                                        • zecchiundefined
                                          zecchi @Phaedrux
                                          @Phaedrux
                                          Second line of this datasheet:
                                          17HS2408-MotionKing.pdf
                                          Now I realize that the seller made fun of me selling this motor as 1.5A instead 1.3A (I re-cecked and in the description is written 1.5A😠 ).
                                          • zecchiundefined
                                            zecchi @zecchi
                                            @zecchi
                                            My fault , the line is actually the number eight. So the current is 1.7A. awesome.
                                            This is the link :
                                            € 21,62 20%OFF | Nema17 Stepper Motor 42 motor Nema 17 motor 42BYGH 1.5A 38mm 17HS4401 motor 4-lead for 3D printer CNC
                                            https://a.aliexpress.com/BBHPrX2gL
