    ZA and ZB connections ?
    2.9k
    • Rudy2Aundefined
      Rudy2A @Phaedrux
      @Phaedrux said in ZA and ZB connections ?:
      Vous pouvez tout mettre dans votre gcode slicer si vous voulez qu'il s'exécute à chaque fois avant l'impression.
      Vous pouvez d'abord utiliser G32 pour l'inclinaison de mise à niveau, puis faire un g29 pour cartographier la surface du lit. Le g29 peut être dans bed.g et appelé dans le cadre de G32 (qui appelle simplement bed.g) ou vous pouvez l'avoir comme une commande distincte dans le slicer start gcode. Dépend de vous. Mais il est important de corriger l'inclinaison avant de faire la compensation de maillage.
      Thank you, quick and precise !!!
      This forum is like Duet material, that is to say of quality !!!
        dc42 administrators @Veti
        @Veti said in ZA and ZB connections ?:
        if you run G32 then you need to run a G29 and not a G29 S1.
        It's quite in order to run G32 to correct for loss of sync of the Z motors, followed by G29 S1 to load a height map to compensate for gantry sag and any undulations in the bed surface.
        • Rudy2Aundefined
          Rudy2A
          Happy New Year everyone !
          I spoke too quickly ... I realized that when I wanted to print large pieces the leveling of the bed did not work finally!
          While searching the forum, I found a case very close to mine, but unfortunately that has apparently not been resolved!
          https://forum.duet3d.com/topic/725/still-having-problems-with-bed-compensation-with-the-dc42-probe?_=1578077431668
          However, I would point out that before my mini IR probe, I had a BLTouch and the problem was the same!
          Thank you.
            dc42 administrators @Rudy2A
            @Rudy2A said in ZA and ZB connections ?:
            Are you now using G32 to level the two sides of the bed, with the two Z motors connected to separate drivers? If so, after running G32, do you then get a level height map if you run G29 S0 ?
            Rudy2Aundefined 2 Replies Last reply Reply Quote 0
            • Rudy2Aundefined
              Rudy2A @dc42
              @dc42 said in ZA and ZB connections ?:
              Utilisez-vous maintenant G32 pour niveler les deux côtés du lit, avec les deux moteurs Z connectés à des pilotes séparés? Si oui, après avoir exécuté G32, obtenez-vous une carte de hauteur de niveau si vous exécutez G29 S0?
              Need details ...
              When I look at my height map, I see that the corner in front on the left (near the arrows XYZ) is too high! So, if I understood correctly, I must lower my bed on this side using the adjusting screw. However if I look at my test print which is in the same place, the deposit of the PLA is too high and does not really stick to 100% on my bed, which could indicate that I should assemble my bed!
              What does the grid (reference model) represent perfectly straight on my height map and what does the green part (for me) represent?
              • Rudy2Aundefined
                Rudy2A @dc42
                Yes absolutely, I use the two separate Z pilots ... G32 then G29 ...
                But the problem is that, even if I adjust my bed in any way after doing G32 and G29, the result remains the same! It is as if the correction of my bed keeps in mind the error of the departure! Difficult to explain ! But, I find myself after the correction with the same faults (in the same place as at the start) without any correction having been made and yet I see perfectly moving the Z differently.
                  Phaedrux Moderator @Rudy2A
                  @Rudy2A your mesh would benefit from more points. It's fairly sparse.
                  Rudy2Aundefined 1 Reply Last reply Reply Quote 0
                  • Rudy2Aundefined
                    Rudy2A @Phaedrux
                    votre maillage bénéficierait de plus de points. C'est assez clairsemé.
                    For the sake of understanding, I prefer to use the P of M557 than S
                    M557 X11: 250 Y11: 252 P4
                    What would be the P value to make it more meaningful?
                    • Rudy2Aundefined
                      Rudy2A @Rudy2A
                      Par souci de compréhension, je préfère utiliser le P de M557 que S
                      Quelle serait la valeur P pour la rendre plus significative?
                      My bed is 300X300
                        Try double?
                        • Rudy2Aundefined
                          Rudy2A @Phaedrux
                          Essayez double?
                          Here, I get this result from M557 P4 to P8 ...
                          The worst part is that by looking for solutions to my problem on the forum, I found quite a few cases similar to mine, but each time, the cases were not resolved or were not commented on final solution, it's a shame!
                          • Rudy2Aundefined
                            Rudy2A @Rudy2A
                            As I said a little higher ... No matter the result of my height map by making a G29S0! My first layer does not receive any correction, the impression always remains identical in all the tests (and yet the height maps are never identical) ... same defect in the same place, it is frankly annoying not to understand!
                            • DIY-O-Sphereundefined
                              DIY-O-Sphere
                              How are the motors connected to the leadscrews? Can you please attach a picture?
                              (UTC+1)
                              • Rudy2Aundefined
                                Rudy2A @DIY-O-Sphere
                                @DIY-O-Sphere said in ZA and ZB connections ?:
                                Comment les moteurs sont-ils connectés aux vis-mères? Pouvez-vous joindre une photo?
                                Like this...
                                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                  Do you see the Z axis turning while it's printing?
                                  • Rudy2Aundefined
                                    Rudy2A @Phaedrux
                                    Voyez-vous l'axe Z tourner pendant l'impression?
                                    Yes absolutely, my CoreXY printer (it's my moving bed) has 2 Z axes. One Z on Za and the other on E1, I can see my Z axes turning indifferently during my print tests ...
                                    • Vetiundefined
                                      Veti @Rudy2A
                                      can you post a picture of the first layer?
                                        DIY-O-Sphere @Rudy2A
                                        @Rudy2A
                                        I hate those types of couplers, as they behave like a spring.
                                        But I think that in your case, the lead screw is fixed in Z by the upper bearing.
                                        (UTC+1)
                                        • Rudy2Aundefined
                                          Rudy2A @Veti
                                          pouvez-vous publier une photo de la première couche?
                                          here is... the quality of the photography is not great, but we can clearly see where my first layer is crushed, and where it is too high!
                                          Whatever I do as a setting, it comes down to the same every time! it's like a model is in memory on the printer ...
                                          Even if I level my bed using the adjustment screws with a print in progress, I manage to have a very appreciable result ... Only, when I launch a new print test (without restarting the printer) my settings are not taken into account and we start again on a leveling of the bed almost identical to the photograph above!
                                          • Vetiundefined
                                            Veti @Rudy2A
                                            @Rudy2A
                                            post the picture of the mesh grid.
                                            while printing check with m122 that mesh grid is active.
