    RRF 3.0 Upgrade - Help wanted
    Firmware installation
    649
      A Former User @pro3d
      @pro3d said in RRF 3.0 Upgrade - Help wanted:
      I am not sure if I run the stock heater but it is 30W or 40W - is this important?
      No doesn't matter, the current should be less than less than 3.5A even if running off 12V, and the new VH3.96 contacts can handle that and then some.
      • pro3dundefined
        pro3d @stewwy
        @stewwy said in RRF 3.0 Upgrade - Help wanted:
        I found reading the notes confusing and gave a lot of detail i did not need to know.
        Simplest way was to use the Configurator tool and when it had spit out all the files looking through them and punching in all my correct details. Took me about a day to get it sorted. main problem I found was the config tool missed out my M671 command so my bed tramming did not work. It's much simpler than it appears 🙂
        Thank you - I did not think about using the configurator. I will try that
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
        • pro3dundefined
          pro3d
          What is modulation pin? Never heard this before and I use a BL Touch as endstop
          • stewwyundefined
            stewwy
            I don't use a bltouch but from the wiki : Analogue probe with modulation Modulation (IR LED on/off control)
            pro3dundefined 1 Reply Last reply Reply Quote 0
            • pro3dundefined
              pro3d @stewwy
              @stewwy
              Phew... Lots of new stuff here I have to read up on I see.. Thanks for helping
              • stewwyundefined
                stewwy
                I did find that I had to redo my PID tuning again so you need to factor that in.
                  dc42 administrators @pro3d
                  Here is my old config
                  My hotend is a e3d V6 with a PT1000 (NOT PT100) temp sensor. I am not sure if I run the stock heater but it is 30W or 40W - is this important?
                  The Bed Heater is a 1000W silicon pad with a NTC3950 thermistor
                  M305 P1 X501 R4700 ; heater 1 uses a PT1000 connected to thermistor channel 1
                  M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                  Try this:
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; heater 0 uses a thermistor connected to temp0
                  M308 S1 P"temp1" Y"pt1000" ; heater 1 uses a PT1000 connected to temp1
                  M950 H0 T0 C"bedheat" Q10 ; heater 0 uses output bed_heat, low PWM frequency
                  M950 H1 T1 C"e0heat" ; heater 1 uses output e0heat
                  pro3dundefined 2 Replies Last reply Reply Quote 0
                  • pro3dundefined
                    pro3d @dc42
                    Thank you DC! Do you have an advice for the BL touch as well? It is very confusing in the configurator and also I dont understand the guide
                    • pro3dundefined
                      pro3d @dc42
                      @dc42 said in RRF 3.0 Upgrade - Help wanted:
                      Try this:
                      It did not work well. Both now read 2000
                      • pro3dundefined
                        pro3d
                        I now have the temp sensor working - Need to figure out the bltouch
                          Try re-running config.g (send M98 P"config.g" from the console) and see if you get any error messages.
                          • pro3dundefined
                            pro3d @dc42
                            This is what the config tool threw at me and it seems to work. Now I just need the rest.. BLTOuch and what not
                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4100 ; configure sensor 0 as thermistor on pin bedtemp
                            M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                            M308 S1 P"e0temp" Y"pt1000" ; heater 1 uses a PT1000 connected to temp1
                            M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                              What do you current have in config.g for bltouch, and what do you have in deplyprobe.g and retractprobe.g?
                              You don't need a modulation pin for bltouch so you can set it to none.
                              • pro3dundefined
                                pro3d @dc42
                                Here is my old probe config
                                M574 Z1 S2 ; Set endstops controlled by probe
                                M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                                M558 P9 H5 F120 T6000 A30 S0.02 ; Set Z probe type to bltouch and the dive height + speeds
                                G31 P500 X26 Y0 Z1 ; Set Z probe trigger value, offset and trigger height
                                M557 X26:326 Y16:376 S150:180 ; Define mesh grid
                                  The M574 line was wrong anyway, it should have been M574 Z1 S0 (i.e. no Z endstop). I assume you are using G30 commands to home Z in homez.g and homeall.g.
                                  Remove the M307 line. Change the M558 line to:
                                  M558 P9 C"zprobe.in" H5 F120 T6000 A30 S0.02 ; Set Z probe type to bltouch and the dive height + speeds
                                  I will assume that you don't have an attached DueX expansion board. Add this line:
                                  M950 S0 C"exp.heater3"
                                  Change your M280 commands in deployprobe.g and retractprobe.g to use P0 instead of P3, and remove the i1 parameter.
                                  Before you rely on Z homing working, test deployment and retraction of the probe (M401 and M402). Then test Z homing very carefully, making sure you can cut the power if the Z motors don't stop in time.
                                  • pro3dundefined
                                    pro3d @dc42
                                    Its alive 🙂 Thanks!
