    Ender 5 upgraded with Duet 2 Wifi - Problems
    786
    • TiToMoskitoundefined
      TiToMoskito
      I cleaned my bed alcohol, so there is no fat or fingerprints on it.
      Can someone tell me how to make my mesh grid bigger?
      When i change the grid to
      M557 X0:200 Y0:200 S40
      it will probe outside the bed, and it doesnt start really from zero it always start from the homing position.
      By the way, the homing position shouldn't it be on the center of the bed 😄 ?
      homing_pos
      My bed dimensions are: X: 220 Y: 220 (prev. on klipper i had on y 235)
      Heightmap
      Here is my heightmap: heightmap.csv
      I put my z on zero and made a manual paper bed leveling (sorry i dont how to call it, i hope you understand what i mean)
      • Vetiundefined
        Veti
        what material are you printing and at what temperature?
          TiToMoskito
          Im printing PLA with 200°C and 60°C bed temp
          • Vetiundefined
            Veti
            can you try the values for the thermistor from this and see if it makes a difference?
            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38?lang=en
              Phaedrux Moderator @TiToMoskito
              @TiToMoskito said in Ender 5 upgraded with Duet 2 Wifi - Problems:
              By the way, the homing position shouldn't it be on the center of the bed ?
              Can you post your homing files?
                TiToMoskito
                @Veti this is not a temp issue, i think its more a calibration failure on my site.
                @Phaedrux What kind of homing files do you need?
                Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • Vetiundefined
                  Veti @TiToMoskito
                  nevertheless your thermistors settings are not correct.
                    all of them? Homeall, homez, homex, homey. bed.g as well if you use G32 at all.
                    TiToMoskitoundefined 1 Reply Last reply Reply Quote 0
                      TiToMoskito @Phaedrux
                      @Phaedrux i hope its everything 🙂
                      homez.g homey.g homex.g homedelta.g homeall.g bed.g
                        From your homeall.
                        G1 H2 Z2 F6000          ; lift Z relative to current position
                        G1 H1 X-235 Y-230 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H2 X5 Y5 F6000       ; go back a few mm
                        G1 H1 X-235 Y-230 F360  ; move slowly to X and Y axis endstops once more (second pass)
                        G90                     ; absolute positioning
                        G1 H2 X51 Y22 F6000     ; go to first bed probe point and home Z
                        G30                     ; home Z by probing the bed
                        The position of the bed probing for the Z axis is set as X51 Y22. You can change that as needed to position to probe at the center of the bed.
                          TiToMoskito
                          Thanks, i changed it to 117 to the center of the bed.
                          My mesh grid is set on X to max 180, why does it exceed?
                          M557 X5:180 Y5:215 S10
                          And why does it start at X: 49.0 Y:22.0 and not from 5 ?
                          mesherror
                            Are you getting messages in the console saying points unreachable?
                            The grid specifies the area of the bed you want probed. But the probe has an offset from the nozzle and it's possible that it cannot reach all points.
