    mesh grid compensation
    1.4k
      G29 will run a mesh probing routine.
      G29 S1 will load the saved heightmap and enable mesh compensation.
      G29 S2 will disable mesh compensation.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
      akisjonundefined 1 Reply Last reply Reply Quote 0
      • akisjonundefined
        akisjon @Phaedrux
        hello and good year everyone i came again with many corrections but that i dont know how to fix it will help me?
        is she still out of bed?
          Phaedrux Moderator @akisjon
          @akisjon That would appear to be sag in the X gantry. No amount of bed leveling will fix that. But mesh compensation should be able to correct for it.
          The question is, does the mesh compensation correct for it correctly or not?
          You can test with an STL like this to verify your first layer across the bed surface quickly.
          bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
          Print it twice, once without mesh compensation, and once with.
          • akisjonundefined
            akisjon @Phaedrux
            @Phaedrux In a strange case it prints in both cases but better print when the bed compensation is disable . is it possible?
              Can you post your current config.g and homing files?
              Did you incorporate the changes mentioned earlier in the thread?
              You may need to do a more detailed mesh with more points.
              • akisjonundefined
                akisjon
                config.g
                ; generated by RepRapFirmware Configuration Tool v2.0.5 on Sun Oct 27 2019 13:47:05 GMT+0200 (Χειμερινή ώρα Ανατολικής Ευρώπης)
                G21 ; Work in millimetres
                G90
                M669 K1 ; Select CoreXY mode
                M550 P"Hypercube Evo" ; set printer name
                M552 S1 ; enable network
                M552 P192.168.1.69 S1 ; Enable network and set IP address
                M553 P255.255.255.0 ; Set netmask
                M554 P192.168.1.1 ; Set gateway
                M587 S"COSMOTE-483A22" P"" ; Configure access point. You can delete this line once connec; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P0 S1 ; physical drive 0 goes backwards
                M569 P1 S1 ; physical drive 1 goes backwards
                M569 P2 S1 ; physical drive 2 goes forwards Z
                M350 X256 Y256 Z256 E256 I1 ; configure microstepping with interpolation
                M92 X1280 Y1280 Z6400 E6500 ; set steps per mm
                M566 X900.00 Y900.00 Z290 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z400.00 E250.00 ; set accelerations (mm/s^2)
                M906 X1000 Y1000 Z1800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M376 H0.591
                ;M671 X0:0 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                M208 X440 Y460 Z900 S0 ; set axis maxima
                M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                M558 P9 H4 A6 F120 T4000 R0.2 ;S0.004 ; set Z probe type to bltouch and the dive height + speeds
                G31 P25 X25 Y35 Z3.930 ; set Z probe trigger value, offset and trigger height
                M557 X50:430 Y100:420 S80 ; define mesh grid
                T0 ; select first
                ;M290 S-0.330
                homeall
                ; homeall.g
                ; called to home all axes
                G91
                M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                ;M402 ; Retract probe just in case it's down
                M564 H0
                G1 S1 X-480 F4000 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 S1 Y-480 F4000
                G1 S1 X-480 F360
                G1 S1 Y-480 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G90 ; absolute positioning
                G1 X220 Y220 F6000 ; go to first bed probe point and home Z
                ;G29 S1
                homex
                ; called to home the X axis
                G91 ; relative positioning
                G1 S1 X-485 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 X5 F6000 ; go back a few mm
                G1 S1 X-485 F360 ; move slowly to X axis endstop once more (second pass)
                G1 Z-5 F6000 S2 ; lower Z again
                homey
                ; homey.g
                ; called to home the Y axis
                G1 S1 Y-485 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G1 Y5 F6000 ; go back a few mm
                G1 S1 Y-485 F360 ; move slowly to Y axis endstop once more (second pass)
                homez
                ; homez.g
                ; called to home the Z axis
                G1 X210 Y210 F6000; Move x and Y axis over to bed center so probe is on top of bed
                  @akisjon said in mesh grid compensation:
                  Best to use x16 microstepping interpolated to 256 by the driver. Using x256 on all axis will lead to problems and offers no real benefit.
                  M376 H0.591
                  Your bed taper is set exceedingly low. This could be causing the problems you describe.
                  it is recommended that the taper height be set to at least 20x the maximum error in the height map, so that the maximum amount of the resulting over- or under- extrusion is limited to 5%.
                  Based on your max deviation of 0.6 your taper should be at least 12mm.
                  https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Compensation_Taper
                  Try S40 to increase your mesh resolution.
                  M564 H0
                  This is not needed since your Z moves in your homing files are using the S2 parameter already.
                  The probe points in homeall and homez do not match.
                  akisjonundefined 2 Replies Last reply Reply Quote 0
                  • akisjonundefined
                    akisjon @Phaedrux
                    @Phaedrux thank you very much for your quick answers i will try tomorrow
                    • akisjonundefined
                      akisjon @Phaedrux
                      @Phaedrux So i do all of the changes you suggested and that is the best effect. impresses me is a curve in the back of the bed, do you know what can come from it?
                        The best way to interpret the heightmap visualization is to compare it to an actual print test to see if errors are true to reality and that the correction is being applied successfully.
                        If you print this test twice, once with mesh compensation active, and again with it deactivated, you should be able to tell if things are working properly.
