    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    12.3k
    • Hornetriderundefined
      Hornetrider
      Yeah, I got it.
      Didn't think about it, regarding the Z axis as moving bed...
      Thin I will get used to it as soon as I have updated my second printer to RRF3.0...
      • supernovaeundefined
        supernovae
        Thanks for all your hard work @dc42! Love this update! Converted my HyperCube evo over and all is well (corexy)
        • kraegarundefined
          kraegar
          Just wanted to chime in that 3.0 is running on several RailCore's with both Duet 2's and Duet3's now with no reported troubles. Thanks for the great work @dc42 !
            dc42 administrators @kraegar
            @kraegar, thanks for the feedback.
            Do you have an application for conditional GCode on the RailCore?
            kraegarundefined stewwyundefined 2 Replies Last reply Reply Quote 0
            • kraegarundefined
              kraegar @dc42
              @dc42 We definitely do! Auto-leveling until below a set threshold is the obvious first one. But I've had quite a few others as well - I have a systems admin background, so being able to script within gcode has been something I've wanted for a long time. Very much looking forward to it!
              • kraegarundefined
                kraegar
                This is the "upgrade guide" I made for our users have been using to convert their RailCore's with a Duet2 to RRF3, if it's helpful to anyone else. It's taking our base RRF2.x config, and making it RRF3 compatible for new builds. There's a text document to describe the process for upgrading.
                https://www.dropbox.com/sh/pg0ugu5qunokjc9/AAD8PkPqVGPp-yWV5Cug3_Usa?dl=0
                • stewwyundefined
                  stewwy @dc42
                  @dc42 Must say this runs nicely, once I got over an error on my part, must learn to RTFI :-).
                  • DaBitundefined
                    DaBit
                    I did 15 hours of printing with RRF3 on the Duet. No failures due to RRF3. Random things I noticed:
                    • I had to recalibrate the BLTouch triggerpoint to nozzle Z-offset. Difference with RRF2.05 is 0.12mm smaller.
                    • Printing PusaSlicer generated brims at 60mm/s sounds a bit rougher than it did with 2.05. While printing the actual part I noticed no difference.
                    • Some weirdness with 'pause print' and then not being able to cancel it in DWC. Might as well be an issue with running DWC on my (Android 7.1) phone; that usually takes a few reloads before DWC is displayed correctly anyway.
                    DIY-O-Sphereundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                    • DIY-O-Sphereundefined
                      DIY-O-Sphere @DaBit
                      @DaBit said in RepRapFirmware 3.0 is released!:
                      I can confirm that for a Maestro.
                      (UTC+1)
                      • matej1006undefined
                        matej1006
                        Hello i just upgrade and after upgrade it's show that
                        ![alt text](9eaa4038-424a-4495-b744-c4ba10e60cd4-image.png image url)
                        what i did wrong?
                        Matej
                          I haven't tested RRF 3.0 with DWC 1.22.6. I suggest you upgrade to DWC 2.0.4.
                            matej1006
                            how i do that and what changes are with this DWC
                              Move the SD card to a PC and unzip DuetWebControl-2.0.4-SD.zip into the /www folder.
                              You can find DWC release info at https://github.com/chrishamm/DuetWebControl/releases.
                                matej1006
                                Is this DWC make change to config or any code or just for web interface
                                  Upgrading DWC does not require configuration changes.
                                    A Former User @DIY-O-Sphere
                                    @DIY-O-Sphere said in RepRapFirmware 3.0 is released!:
                                    Wow, this is weird?!
                                      deckingman @DaBit
                                      @DaBit Ref the BL touch offset, does using a slower probing speed help? Or more specifically does probing speed affect the offset? Just wondering if there could be a latency issue between when the BL touch triggers and when the firmware reacts to that trigger. I don't use a BL touch myself so I could be way off the mark.
                                      Edit. And is the probe connected to the main board or an expansion board?
                                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                        matej1006
                                        how i must convert this code :
                                        ;Water temp
                                        M305 S"Water temperature" P103 X2 T10000 B3950
                                        And that:
                                        M574 Z1 S2 ; Set endstops controlled by probe
                                        M558 P1 H5 F120 T3000 ; Set Z probe type to modulated and the dive height + speeds
                                        G31 P467 X0 Y40 Z1.0 ; Set Z probe trigger value, offset and trigger height
                                        how it's with auto bed compensation do i need there also to change anything
                                          DIY-O-Sphere @matej1006
                                          @matej1006
                                          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M305
                                          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M558
                                          But you also have to edit some more places in config.g and in some files in sys folder. Maybe it's easy to do the base of conversion with the online configurator.
                                          (UTC+1)
                                          matej1006undefined 1 Reply Last reply Reply Quote 0
                                            matej1006 @DIY-O-Sphere
                                            @DIY-O-Sphere Thanks
