    Endstop Issues with RepRap 3.0 upgrade
    • Scrabartundefined
      Scrabart
      I seem to be having issues with the endstops after having retrofitted a creality CR10 with a duet wifi.
      Everything worked fine until I blew up my original Duet 2 rev 1.04c (long story) and replaced it with a new one of the same revision. during the replacement I upgraded the firmware to 3.0 and now all of the switches seem to be inverted. The Axes wont home because they think the switches are already tripped. I tried changing the output with the M574 command in my config.g without success. Any suggestions?
      • jrsphotoundefined
        jrsphoto
        Please post your config.g file so I can take a look
        • DIY-O-Sphereundefined
          DIY-O-Sphere
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
          Have you tried invert the input by prefixing the pin name with '!'
          (UTC+1)
          Scrabartundefined 1 Reply Last reply Reply Quote 0
          • Scrabartundefined
            Scrabart
            Here is the config.g file
            09Jan2020_config.g
            • Scrabartundefined
              Scrabart @DIY-O-Sphere
              @DIY-O-Sphere
              Thank You So Much! That works perfectly.
              I had no Idea that they added all of this functionality to the M574. It will be really helpful when I switch over to dual Z endstops too.
