    Part cooling fan duct (again!)
    3D Printing General Chat
    1.8k
    • DocTruckerundefined
      DocTrucker
      Thanks for the comments. Yes, I have been thinking about ditching the 30W cartridges for some time. I didn't have much issues when printing 180-200ish but as soon as it went over 200 it struggles on temp. That said wouldn't the PID tune just set the expected temp rise in 1sec to a larger number?
      Regards smoothness I've not experimented with that and noise is a secondary concern to printed part quality. That said the layers are aligned to the airflow as it exits the nozzle.
      A Former User? DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
        A Former User @DocTrucker
        @DocTrucker said in Part cooling fan duct (again!):
        While I overpower them, it's not required, for e.g. teartime is making printers that print their own brand of ABS that requires 270C for printing and they do it with 18W heater!!! I never had issue with TT printer heating abs to 270C and maintaining that temp.. (on the other hand their heaters can barely reach 100C so replacing bed heater is something one almost have to do)
        • DIY-O-Sphereundefined
          DIY-O-Sphere @DocTrucker
          That said wouldn't the PID tude just set the ecoected temp rise in 1sec to a larger number?
          Just 2 ideas:
          Have you checked the value of the safety temperature limit in config.g
          Maybe it's set around 200°C
          The other idea: pwm of the heater is limited in config.g
          (UTC+1)
            DocTrucker @DIY-O-Sphere
            @DIY-O-Sphere thanks for your comments. Couple of typos there now corrected!
            My temp limit is set to 250 and there is no limit set on heater modulation. When it faults out it is a message saying sometjing along the lines of "Heater fault, temp rise of 0.9 degrees per second not met." I suspect this value is extrapolated from the PID tuning and if so, if I put a more powerful heater in its place I suspect this trigger value for the alarm will increase. Potentially meaning the trip still occurs, although as the cooling capacity of the fan system remains unchanged I guess the overall effect would be less.
              DIY-O-Sphere
              There is an instruction how to manually adjust the parameter.
              I thing it's worth trying.
              https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control#Section_Manual_adjustments_to_the_heater_model_parameters
              Or what about to repeat PID tuning with fan on?
              (UTC+1)
              • wilrikerundefined
                wilriker
                @DocTrucker did you do your PID tuning with the part cooling fan at 100%? That's at least how I learned to do it. This should take any effect the part cooling fan has on the temperature into account and thus mitigate your heater fault problems.
                Also I had to redo my PID tuning a few weeks back with no hardware changes made to the system at all. Suddenly it was no longer able to even reach 100°C without faulting that it did not rise fast enough. Maybe you need to redo it also.
                Manuel
                My Tool Collection
                DocTruckerundefined 1 Reply Last reply Reply Quote 1
                  DocTrucker @wilriker
                  @wilriker I did try that a while ago, but you've got me thinking perhaps there is an argument for two PID tunes. One for control and one for worst case heat up time fault detecton setup? The difference in the autotune results of fan off and fan on could also be a neat test to run from now on when changing the duct design.
                    @DIY-O-Sphere I don't think you can tune the alarm point directly but will have anotherlook thanks. As above I have tried tuning with the fan on, I had an issue but can't remember what it was. Possibly excessive oscillation. Will try next week.
                    DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                      DocTrucker @A Former User
                      @smece said in Part cooling fan duct (again!):
                      ...zero improvements in performance, air flow looks identical even on high speed camera, but sound levels drop significantly...
                      How did you visualise flow?
                        @DocTrucker
                        Just a question, do you use an external power supply connected to the boards 5V input?
                        (UTC+1)
                          @DIY-O-Sphere yes. Think it's a 2A one.
                            @DocTrucker
                            Are you also using a 5V part cooling fan?
                            Can you switch that power supply to an other one?
                            The reason is, I just remembered, that I had a similar problem in the past with my ramps.
                            The temp was freaking around the set point. And it was caused by a bad stabilised LM2596 DC step down module.
                            After adding a big capacitator to the 5V rail everything worked fine.
                            (UTC+1)
                              visualise flow?
                              the ones I was designing myself I was using some plugin for solidworks and later I was trying some plugins for onshape... not really very useful to me, neither of them, as I don't know 90% of the things they ask me to set before simulation + the printed part has so many imperfections + air source from the radial and axial fans makes a lot of difference and I have no clue how to set that up so.. it was interesting to play, useless for final design...
                              so I decided to go with the old proven way and use smoke and high speed camera 😄 ... high speed is on phones (I don't have real high speed camera, just bunch of samsung, google and apple phones that have that feature... lot of phones, my company makes apps so we have ton of phones for testing purposes, some have high speed capability 😄 ) and smoke I tried number of sources ... burning ABS smokes a lot, cigars (not cigarettes) have good thick smoke, vaping devices produce good smoke (it's I think vapor but who cares looks like smoke, visible..) etc etc .. but the best results I had with some heated oil for train models and smoke machine I lend from my brothers club... black background and good lighting ... now, last time I did it was over two years ago but I doubt any of my findings would be different these days.. and btw results from real life test vs simulators - 2 totally different things 😞 can't even compare
                              now the simplest test I seen ppl do (never tried myself) is with ball of water... it actually gives you air pressure info too so should be done when designing a duct (you put a ball of water under the hotend and look how the airflow disturbs the water surface - check example here 2:44 https://youtu.be/xmZCwJDyxYU?t=164 )
                              DocTruckerundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                @DIY-O-Sphere good to be aware of issues like that but no thanks, it's a 12VDC radial blower. The temp plot on tue web control looks smooth and noise free.
                                  @smece Cheers, thanks I was meaning how do you make it visible. I'd thought of the smoke bombs used to test gas fire exhausts but thought there was far too much smoke. Model train engine smoke generators is a great shout. Someone had mentioned the water trick before and I had completely forgotten!
                                  • zaptaundefined
                                    zapta @A Former User
                                    Would this help? https://www.draeger.com/en_uk/Products/Air-Flow-Tester
                                    https://duckduckgo.com/?q=smoke+testers+air+flow&atb=v88-4_g&iar=images&iax=images&ia=images
                                      A Former User @zapta
                                      @zapta oh yes, it would, they use them in wind tunnels and a bunch of other places, but I can't find that locally, no store sells them... I even pinged some ppl that work in the air tunnel and they have no clue where I can buy them locally (they order them from some company that brings them all the consumables, and they can't spare any as .. dunno why actually, probably they don't like me enough 😄 ) ... I never held that in my hand so no clue how it actually works but I've seen it being used from the far and I'm sure it would be great for duct testing ... but, train smoke oil works ok and smoke machine is great (unfortunately don't ahve access to one any more, brother closed his club and moved to murica )
                                      • zaptaundefined
                                        zapta
                                        I wonder if a IR camera would be useful here. E.g. take an object, warm it a little, place under the nozzle with fan on, and observe the cooling temperature. After all this is what we care about, the cooling pattern.
                                        https://www.amazon.com/Seek-Thermal-Compact-All-Purpose-MicroUSB/dp/B00NYWAHHM
