low motor torque
is there a message about disconnected phase in the console log?
the beta value 4138 is not the correct value for the thermistors you are using, so it will display the wrong temperature at high temperatures.
No, it doesn´t show any error massages.
And thank you for pointing me out about the thermistor values, but how do you know wich kind of thermistors I use?I´m just wondering, why one of the motors stops working when I move M584 to the correct position?
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MGN-Cube" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards X M569 P1 S0 ; physical drive 1 goes forwards Y M569 P2 S0 ; physical drive 2 goes forwards Z-L M569 P3 S0 ; physical drive 3 goes forwards Z-R M560 P4 S1 ; physical drive 4 goes forwards E M584 X0 Y1 Z2:3 E4 ; two Z motors connected to driver outputs Z and E0 M671 X-60:360 Y150:150 S15 ; leadscrews at left (connected to Z) and right (connected to E1) (of X axis) M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z4266.67 E420.00 ; set steps/mm M566 X900.00 Y900.00 Z12 E120.00 ; set jerk (mm/min) M203 X6000.00 Y6000.00 Z90 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z50 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in percent M84 S5 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis min M208 X300 Y300 Z365 S0 ; set axis max ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstop controlled by probe ; Z-Probe M558 P1 H5 F120 T6000 ; set Z probe type to IR-Probe and the dive height + speed G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X0:280 Y5:300 S80 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom Configuration
It is right like this, isn´t it?
@Neufra said in low motor torque:
which thermistors did you buy?
and which motor is not working?
I have NTC100K thermistors.
If you mean wich motors have little torque, it´s all of them. If you mean wich one stopped working after moving M584, it´s the second Z-Motor (connected to E0) -
that just says it has 100k restistance at 25C nothing more. you need a specific type defintion of the thermistor like semitec-104gt-2.
for testing can you disconnect the duex5?
I don´t know wich specific type of thermistor my bed has, it just says: "Thermistor 100k". (My hotends have those "Semitec-104gt-2" thermistors you mentioned)
When I disconect the duex, do I have to change something in the firmware as well? -
if its a chinese bed. its most likely a B3950.
the semitec is B4725 C7.060000e-8
no
Soo, disconecting the duex doesn´t seem to change anything, the Motor connected to the E0 output still doesn´t move.
About the thermistors, I put in the correct values for the Hotends.
(I have this heater for my bed. I will contact their support and ask them about the thermistor type!) -
ok connect up the duex5 again and remap the second z to one on the duex5
This post is deleted! -
The motor works now, I can´t reverse it, but it works. (I just flipped the connector)
@Neufra
reversing the connector should only change the direction. maybe a bad crimp job? -
No. That´s not what I mean. The motor works, independently of the connector direction. But I can´t change the motor direction through confi.g, only by reversing the connector.
are you restarting after changing the config.g?
are you editing the config.g in your sys folder?also try M98 P"/sys/config.g"
well, DuetWebControl asks me the following, after any change in config.g:
Reset board? Would you like to restart your board to apply the updated configuration?
I click "yes" there.
And on top of the config.g editor it says:0:/sys/config.g
Your command gives me that:
M98 P"/sys/config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Writing to file: 4 S1 Done saving file. Error: Bad command: 560 P5 S1
please post your new config.g again
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MGN-Cube" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards X M569 P1 S0 ; physical drive 1 goes forwards Y M569 P2 S0 ; physical drive 2 goes forwards Z-L M569 P3 S0 ; physical drive 3 goes forwards Z-R M560 P4 S1 ; physical drive 4 goes forwards E M560 P5 S0 ; physical drive 5 goes forwards Z M584 X0 Y1 Z2:5 E3 ; two Z motors connected to driver outputs Z and E0 M671 X-60:360 Y150:150 S15 ; leadscrews at left (connected to Z) and right (connected to E1) (of X axis) M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z4266.67 E420.00 ; set steps/mm M566 X900.00 Y900.00 Z12 E120.00 ; set jerk (mm/min) M203 X6000.00 Y6000.00 Z90 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z50 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in percent M84 S5 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis min M208 X300 Y300 Z365 S0 ; set axis max ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstop controlled by probe ; Z-Probe M558 P1 H5 F120 T6000 ; set Z probe type to IR-Probe and the dive height + speed G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X0:280 Y5:300 S80 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom Configuration
by the drives you have four times M569 after that you use M560 this is wrong and should be M569
ohhh, I overlooked that. Thanks
Edit: now the reversing of the motor works! -
@SIam Good Spot
