    Mesh Compensation
    1.5k
    • Vetiundefined
      Veti
      @Corexy said in Mesh Compensation:
      G31 P500 X0 Y0
      ok you need to configure the probe position.
      X and Y is the offset of the probe from the nozzle. X postive is to the your Y positive is behing. Without this your mesh will be inaccurate.
      M557 X20:180 Y20:180 S40
      change S40 to S15 or S10
      M574 Z0 S0 ; Define active low and unused microswitches
      change to
      post your homing scripts. they will prob be wrong.
      • Corexyundefined
        Corexy
        I should point out that x and y have homing switches...the probe only does the bed level.
        Does that change anything?
        Thanks for helping with this. What's crazy is that despite me using this thing for years with little tuning/adjustment, I knock out some pretty good prints.
        • Vetiundefined
          Veti @Corexy
          no
          • Corexyundefined
            Corexy
            OK,
            So my nozzle/probe offsets are:
            X 4mm
            Y 28mm
            So my M557 becomes:
            M557 X4:195 Y28:195 S10 (?)
            Just a bit worried that the fans might bang into some hardware with these offsets. It's a tight fit in there.
            My slicer start script:
            G28 (home all?)
            G29 (mesh probe?)
            Nothing else at all? I should really tack the purge/wipe I was asking about in my other thread on here while I'm at it?
            Any changes to bed.g?
            Homing files...
            homeall.g:
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:58 GMT+1100 (Australian Eastern Daylight Time)
            G91 ; relative positioning
            G1 H1 X-200 Y-200 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-200 Y-200 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 H2 X97.5 Y97.5 F6000 ; go to first bed probe point and home Z
            G1 S2 Z5 F100 ; lift Z relative to current position
            homex.g:
            ; homex.g
            ; called to home the X axis
            ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:59 GMT+1100 (Australian Eastern Daylight Time)
            G1 H1 X-200 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X5 F6000 ; go back a few mm
            G1 H1 X-200 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-5 F6000 ; lower Z again
            homey.g:
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y-200 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y5 F6000 ; go back a few mm
            G1 H1 Y-200 F360 ; move slowly to Y axis endstop once more (second pass)
            homez.g:
            ; homez.g
            ; called to home the Z axis
            G1 H2 X15 Y15 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G1 H2 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
            I do suspect my files are messy. I come on here asking things and get a line to add here and there. Would really love to have an expert here with me in front of the thing for a day...
            • Vetiundefined
              Veti @Corexy
              no you change the probe offset in the G31 command like i posted.
              lets get your mesh working first.
              bed.g is for G32 command which you are not using.
              your homing files look fine
              Corexyundefined 1 Reply Last reply Reply Quote 0
              • Corexyundefined
                Corexy @Veti
                Ok, sorry my mistake
                X and Y is the offset of the probe from the nozzle. X postive is to the your Y positive is behind. Without this your mesh will be inaccurate.
                Not quite sure what you mean here...you mean that I enter a positive value offset if the probe is further "along" the axis than the nozzle tip, and negative if it is "behind"?
                Thank you for your patience by the way.
                • Vetiundefined
                  Veti
                  that was posted regarding your
                  G31 P500 X0 Y0
                  command.
                  that command means the probe is at the same place as the nozzle is, which it is not as you are using a ir probe.
                  so you need to tell the duet where the ir senssor actualy is while assuming that the nozzle is at 0,0.
                  post a picture of your carriage.
                  • Corexyundefined
                    Corexy @Veti
                    @Veti said in Mesh Compensation:
                    G31 P500 X0 Y0
                    command.
                    OK, so I just went out there and moved the nozzle around the absolute outside of the build area via the touchscreen, and the nozzle travels the absolute limits of the build area and obstacles as it is. If I add these offsets is there any chance I'll bump into things, or should I do something to avoid that.
                    [img]https://i.imgur.com/kCMHC1Q.jpg[/img]
                    [img]https://i.imgur.com/bC9SaMB.jpg[/img]
                    • Vetiundefined
                      Veti @Corexy
                      @Corexy
                      try it with the hand on the power switch.
                      but if i remember correctly the offset does not change the mesh coordinates, as they are absolute nozzle parameter.
                      • Vetiundefined
                        Veti @Veti
                        @Veti
                        also
                        M208 X195 Y195 Z175 S0 ; Set axis maxima
                        this is a hard limit for your axis. if at X195 Y195 there is no problem. then you can not cause a problem with the mesh leveling.
                        • Corexyundefined
                          Corexy
                          Yes, I'll keep the switch handy ha ha. But It still must home the axis' against the limit switches, so yes no offset was probably only messing up my mesh.
                          G31 P500 X2 Y28 Z2.465
                          I measured it a bit more accurately. So I run G29 and see what happens??
                          • Vetiundefined
                            Veti @Corexy
                            @Corexy
                            yes
                            • Corexyundefined
                              Corexy
                              M557 X20:180 Y20:180 S10
                              Ok, it's ticking over happily with the mesh (cold build plate), but it's going to take a lot longer with these 10mm intervals. Which is fine if it will give me a better first layer.
                              To probe the entire (195x195) bed, should I take it out to the edges?
                              M557 X5:190 Y5:190 S10
                              And I'm also thinking should I:
                              1. Warm build plate
                              2. Home all
                              3. Mesh probe (each time, as different bed temps will make different mesh)
                              4. Purge/wipe
                              5. Start print
                              It would be really good to do the mesh probe with a cold nozzle as the ooze is a pain and I'm using an IR probe anyway. I don't mind at all the mesh taking a long time if I'm not picking ooze off the nozzle with tweezers the whole time.
                              • Vetiundefined
                                Veti @Corexy
                                post the picture of the mesh grid.
                                going to a higher spacing depends on the quality of your build plate. the wider the spacing the less details it has to correct with.
                                so if there are no irregulaties, you can get away with a wider spacing.
                                with the bigger mesh: if your Y offset is 28 to probe at 5 it would need to move to Y-23, which is not allowed. for X it would work
                                • Corexyundefined
                                  Corexy
                                  Yes, I can't "reclaim" the Y offset...mechanical obstacles. Makes a case for ally extrusion chassis in my next printer, built well oversize to the build plate.
                                  Running this now regardless, and it seems to be just doing what it can reach.
                                  Mate I really appreciate this help so much, but it's late now and the other half wants me to give it a rest for tonight.
                                  I'll have another look in the morning, but this has been a win so far.
                                  Cheers and thanks!
                                  [img]https://i.imgur.com/3hQysIH.png[/img]
                                  • Vetiundefined
                                    Veti
                                    that picture suggests that the surface is not suited very well for ir probing.
                                    see
                                    https://miscsolutions.wordpress.com/mini-height-sensor-board/
                                    • Corexyundefined
                                      Corexy
                                      OK, really?
                                      It's the original Printbite, supposedly OK. It does give very consistent readings when calibrating the Z height.
                                      I have wondered about those BL touch probes, are they better?
                                      I would really like to keep the Printbite, just because I don't have to replace it. That surface is 3 years old and going strong.
                                      Are there any other surfaces that are similar out there that do work well with IR? I have really liked this probe to be honest, but the Printbite has been tricky with ABS.
                                      I'll see how it performs with this new mesh tomorrow.
                                      @dc42 @deckingman
                                      • Corexyundefined
                                        Corexy
                                        So how would one of these be as a bed sensor?:
                                        https://www.ebay.com.au/itm/5mm-Noncontact-Inductive-Proximity-Sensor-Switch-Detect-DC-6-36V-NPN-TL-W5MC1/253114333447
                                        I've thrown straight edges on this build plate, and while i's not perfect I don't think it runs out as much as this mesh suggests.
                                        With the build plate under the printbite being cast ally, would this type of sensor work better? Is it a straight up fit, or would I need a daughter board of some sort?
                                        I saw another thread where a guy was reporting good results with one of these (due to having trouble with the IR sensor on Printbite), but the thread seemed to die out.
                                        Unless there's a comparable (long lasting/self releasing) surface out there with good IR sensor compatibility, would this be an option?
                                        • Corexyundefined
                                          Corexy
                                          [img]https://i.imgur.com/1Zczdwt.png[/img]
                                          Here a mesh I ran with a plain sheet of white paper on the bed. It was certainly not flat, but I don't see the "spikyness" in the map that I get with Printbite.
                                          Can someone tell me if I need to use a different sensor, and if so, what do I use?
                                          I'm wondering if I've been printing for a few years now with a setup that was not capable of reading the bed properly....
                                          Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          • Corexyundefined
                                            Corexy
                                            And at the risk of talking to myself it all seems to be working better now.
                                            I took the ABS out, as it's known to be a bit difficult on Printbite (until you've got it dialed right in) and went back to a roll of PLA.
                                            I had to babystep -0.15mm, which I then added as a Z offset in the slicer and it's printing a pretty perfect first layer with no sign of the problems I've had in the past.
                                            On this surface I've always had to use a raft for ABS, so I guess that might still be required.
