    Conditional GCode and object model variables
    Gcode meta commands
    32
    66
    7.7k
      dc42 administrators @Riev
      @Riev said in Conditional GCode and object model variables:
      @dc42 , I think The most useful things is :
      1. The conditional block may consist "AND / OR" expression so we can combine two or more logic expression.
      2. SELECT CASE Function as alternative conditional block after IF-ELIF
      3. Attach "LABEL" name Function in any certain line and "JUMP TO LABEL / GOTO LABEL" Function so we can jump or loop to any line we desire. I think this is more flexible than "While" or other Loop function.
      4. "WAIT" Function for any input signal or variable is triggered/changed, and make decision with conditional expression based on change of that input signal (Like wait for button is pressed)
      5. Any variable / command to manipulate "Counter and Timer" Function.
      Thanks for your suggestions. #1 is already implemented. #2 is complicated to do in a line-oriented language, also I don't envisage any common situations in which there would be many cases to choose from; so I won;t imllement it at least for now. For #3, 60 years of program language development have taught us GOTO is bad, so I won't be implementing it. #4 is interesting and I will consider it. Can you explain exactly what you mean by #5?
      garyd9undefined grizewaldundefined 2 Replies Last reply Reply Quote 0
      • garyd9undefined
        garyd9 @dc42
        @dc42 said in Conditional GCode and object model variables:
        Surely you knew when typing the above that you'd be starting a discussion on the merits of goto in programming, right?
        Goto isn't the demon that it's made out to be. The problem is that it was massively abused. (Just like anything.) For things such as state machines, they are extremely useful. (Is conditional gcode a state machine?)
        Keep in mind that all our languages are usually compiled to assembly. Show me any functional assembly that isn't littered with "goto" (jmp) instructions.
        (I'm not suggesting that any type of 'goto' should exist. I was just making a silly point.)
        • grizewaldundefined
          grizewald @dc42
          I'm guessing you mean that GOTO is bad for those who don't know how to program. They should certainly be used very sparingly and can be misused to create spaghetti worse than any 3D printer, but they are not bad per-se.
          In deeply nested decision blocks, a goto can be a life saver for code clarity. Even in those languages which don't provide a goto but give you a try, catch pattern instead, it still boils down to an absolute jump once it gets compiled.
          • infiniteloopundefined
            infiniteloop @grizewald
            @grizewald I’ve spent many years with GOTO, because the first incarnation of APL had nothing else to offer. This 'style' makes your code unreadable and difficult to debug, it’s a nightmare. Even with labels instead of line numbers: it’s easy to break the stack, to jump out of context… or think of someone who re-assigns a label by accident to something else. No, GOTO is nothing else than an invitation for bugs.
            • JoergS5undefined
              JoergS5
              C++ has goto and even Java has something similar with labels to jump out of a loop. I would prefer if it's available in a language and the developer can decide himself whether he wants to use it in extreme cases. I myself don't use it, but there may be specific cases.
              • wilrikerundefined
                wilriker @JoergS5
                @JoergS5 said in Conditional GCode and object model variables:
                Java even has goto as a reserved word - it will lead to a compiler error when used. 😂
                I don't actually want to chime in on the goto discussion. All I would have said is a mixture of the above.
                @dc42 I was reading the language description wiki page and I was surprised that logical AND and logical OR are on the same precedence level. Most languages I know have a higher precedence for logical AND than for logical OR.
                Manuel
                My Tool Collection
                  A Former User @wilriker
                  @wilriker said in Conditional GCode and object model variables:
                  • it will lead to a compiler error when used
                  Touché!
                  But I guess we can put the whole discussion to bed with the following. All in favour of removing jmpinstruction raise their hand .. and having it doesn't mean you have to use it.
                  OT aside, really looking forward to this beta!
                  • gtj0undefined
                    gtj0 @dc42
                    @bearer said in Conditional GCode and object model variables:
                    On the subject of Min/Max. Access to work dimensions as well as the specific job dimensions as mrwolter requets.
                    This is tricky, because GCode files do not contain information about the total dimensions of the part being printed/CNC'd/cut. But we can make a reasonable guess at it by scanning the entire GCode file. This assumes the the GCode file does not contain custom scripts for purge or prime towers, or similar operation that move to coordinates outside the model.
                    This reminds me of a discussion we had a while back about having the DCS provide pre-processing hooks on files. The hook would provide the name of the file, the script would do whatever it needs to it, write it out to a temp file, then tell the DCS the new file name. This may already be possible with intercepts ( @chrishamm ? ).
                    What RRF would need to do is allow statements to set variables in the print file that would later be accessible from macros.
                    The original thought came up when we were talking about having multiple bed heaters creating zones on a large bed plate, then having the gcode only turn on the zones needed for the particular print. The thought was that the script would calculate the bounds and either override the bed heater commands in the input gcode or pass the bounds on to a macro with conditional gcode.
                    • gtj0undefined
                      gtj0
                      I kinda missed this thread but in reading it and the Meta Commands stuff it looks pretty good. Variables are the most important for me since I really want to make changes to things temporarily then set them back to the original value when I'm done.
                      I also didn't see this in the discussion ( or I missed it ) but being able to get things set in config.g that aren't already in the object model is something I think we'd need. Kinda like a JSON output of M503 that we can reference in the macro.
                        dc42 administrators @gtj0
                        @gtj0 said in Conditional GCode and object model variables:
                        Can you give me an example?
                        If you need to restore everything to the values in config.g, you can do that by re-running config.g. To restore a subset of values, set those up in a macro that config.g calls.
                        The plan is that everything you can configure (and some things you cannot) will be in the OM. Now that the OM framework is complete, it's mostly a matter of adding entries to tables and a few simple getter functions.
                          A Former User @dc42
                          It can, many of us use post-processors for G-Code after it exits the slicer, and there many useful info can be embedded in the code... for e.g. there are some that embed %done, total amount of plastic, date, time etc etc... it's fairly easy to embed the size of the object, position... now, most of them embed this info in form of comment but when you implement the VAR xxx = yyy I assume that's it as then we can set in slicer/postprocessor to instead add this as comment, add these in form of VAR maxwhatever = 12345 ..
                          tbh I expected this gcode addon to be also inside comments, to use some "special comments" like for e.g. bash uses #! or mysql /*! to be special comment ... so I expected something like ;! if blah blah .. so that G-Code works on other interpretters too (kinda) but I don't mind it like this 🙂
                          • gtj0undefined
                            gtj0 @dc42
                            The one that sprang to mind immediately was defining the mesh grid
                            M557 X0:460 Y0:450 S25
                            • DaBitundefined
                              DaBit
                              Should I ask these questions here or in the 3.01beta topic?
                              I flashed 3.01 on my Duet2; I want more intelligent heating/cooling in my toolchanges.
                              Two things I notice right away:
                              • In heat.heaters there is both a sensor number (heat.heaters[x].sensor) and a copy of the sensor value's lastReading (heat.heaters[x].current). That is redundant. And the actual setpoint is missing?
                              • There is no information about tools in the object model, right?
                              Part of the M409 response:
                              "heat": {
                                    "coldExtrudeTemperature": 160,
                                    "coldRetractTemperature": 90,
                                    "heaters": [
                                        "current": 16.5,
                                        "sensor": 0,
                                        "state": "Off"
                                        "current": 66.4,
                                        "sensor": 1,
                                        "state": "Active"
                                        "current": 40,
                                        "sensor": 2,
                                        "state": "Standby"
                                    "sensors": [
                                        "lastReading": 16.5,
                                        "name": "",
                                        "type": "Thermistor"
                                        "lastReading": 66.4,
                                        "name": "",
                                        "lastReading": 40,
                                        "name": "",
                                        "lastReading": 29.5,
                                        "name": "mcu-temp",
                                        "type": "microcontroller embedded temperature sensor"
                              Can I also access the response given by M408 P1 somehow?
                                dc42 administrators @DaBit
                                @DaBit said in Conditional GCode and object model variables:
                                Here is good.
                                Correct. We could remove the one in the Heater object, but then you would have to write heat.sensors[heat.heaters[n].sensor].lastReading instead of just heat.heaters[n].current. Maybe that's acceptable and I should remove the redundant one.
                                I haven't got round to adding it yet.
                                Not yet, just the current tool number.
                                Yes, see the wiki page about the object model.
                                • DaBitundefined
                                  DaBit
                                  Duplicating data is not often a good idea so my vote goes to heat.sensors[heat.heaters[n].sensor].lastReading. On the other hand there is a line length limit of 160 characters.
                                  About accessing the M408 P1 object in Gcode (which at least contains active/standby temps): how? 'echo heaters[0]' does not work.
                                  Now that I look at the JSON response I see something weird in the M408 P1 response; after executing these G10's with T0 active and T1 in standby:
                                  G10 P0 S60 R30
                                  G10 P1 S70 R40
                                  The M408 P1 response is:
                                    "status": "I",
                                    "heaters": [
                                      18.4,
                                      60,
                                      40
                                    "active": [
                                      0,
                                      60,
                                      0
                                    "standby": [
                                      0,
                                      30,
                                      40
                                  Heater 0 is the bed heater, 1 is for T0, 2 is for T1
                                  The active temperature for heater 2 returns 0 instead of the 70 I would expect.
                                  (RRF 3.01-beta1+1 (2020-01-15b2), by the way)
                                    As stated in the wiki page on GCode meta commands, object model expressions in them must evaluate to primitive types, not objects. Try 'echo heat.heaters[0].current'.
                                    • DaBitundefined
                                      DaBit
                                      That refers to the object model as returned by M409. I can access those. M408 does not return a 'heat' sub-object or whatever the official JSON name for nested items is.
                                      I was just hoping that I could use the values in the JSON object as returned by M408 also. Those contain info about the tools.... 😊
                                      Nevermind, I will exercise a bit of patience until more is added to the object model.
                                      • appjawsundefined
                                        appjaws
                                        Just a few question for @dc42
                                        1. Has the object model been updated recently?
                                        2. Is it possible to have the fan[].fanPercent included?
                                        3. What test can I used to check if a filament is loaded?
                                        4. When will we be able to define a variable?
                                        Thanks for any help
                                        appjaws - Core XYUV Duet Ethernet Duex5
                                        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                        Ormerod 1-converted to laser engraver, Duet wifi
                                        OpenSCAD version 2024.03.18
                                        Simplify3D 5.1.2
                                        dc42undefined 3 Replies Last reply Reply Quote 0
                                          dc42 administrators @appjaws
                                          @appjaws said in Conditional GCode and object model variables:
                                          Yes, in 3.01-RC2.
                                          I will look into it.
                                          Currently you would need to define a GP input pin for the filament present switch and then test it.
                                          In the 3.02 release.
                                            fan[].requestedValue and fan[].actualvalue are already provided.
