    Add laser for duet2 wifi
    Laser Cutters
    5.1k
    • yamanundefined
      yaman @hector
      @hector
      thanks for you replay
      but this circuit will not work in my case because I don't have Fan 2
      fan 2 I use it for tool 2
      I have heater 6 -7 with 5v PWM
      https://forum.duet3d.com/assets/uploads/files/1570300649740-laser_cable_2.jpg
      • Danalundefined
        Danal
        @yaman said in Add laser for duet2 wifi:
        after I make little change the Laser finally wor
        Sounds like that laser wants 10V in.
        Some want 5V (TTL), some want 10V. The two versions of the circuit above will work for the respective cases.
        yamanundefined 1 Reply Last reply Reply Quote 1
        • yamanundefined
          yaman @Danal
          @Danal
          @EasyTarget
          @T3P3Tony
          Thanks for your replay
          that what I find maybe the real test will be in G code file and let the machine work for hours
          but first I have to do some work at Firmware
          Right now I'm at Version 2.0.0-RC2
          so any Suggestions for good version work fine with 3dprinter and Laser ?
          EasyTargetundefined 1 Reply Last reply Reply Quote 0
          • Danalundefined
            Danal
            I haven't personally tried laser, so can't comment on releases.
            I can say I've had very good results using the "latest", including release candidates.
            • EasyTargetundefined
              EasyTarget @yaman
              The latest release, always the latest.
              https://github.com/dc42/RepRapFirmware/releases/latest
              Duet makes upgrading super easy, there is no real excuse for not upgrading asap and when new releases come out. Currently it is 2.03.
              This is especially true if doing CNC machine control, Duet3D are pushing heavily in this direction at present and related features are appearing in each new release.
              If you want to throw caution to the wind, try the latest 2.0x Release candidate, but I would avoid the 3.0 series betas at this time for general users. Though the 3.x series will eventually bring even more CNC related feature goodness.
              Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
              PrintPy2024 to the rescue!
              MicroPython based; with simple wiring and and no custom PCB.
              • yamanundefined
                yaman
                Laser Engraving picture
                EasyTargetundefined 1 Reply Last reply Reply Quote 2
                  EasyTarget @yaman
                  @yaman COOL!, it's great when it gets working.
                  Now you have all the tuning fun you could wish for; carving and engraving is much more of a 'craft' than 3d printing, the sheer range of materials and techniques ensures that every job is a one-off. With my printers I strive for reproducibility, but for laser art I want everything to be slightly 'individual', it's part of the charm.
                  • yamanundefined
                    yaman
                    video for the Test
                    • yamanundefined
                      yaman @EasyTarget
                      @EasyTarget
                      thanks for your support ☺
                      otaku521undefined 1 Reply Last reply Reply Quote 0
                      • otaku521undefined
                        otaku521 @yaman
                        @yaman
                        mind sharing your laser part of your config.g? are u running on the expansion board? I am trying to mine to work... but my laser have 2 pin 12v and 2 pin ttl... dont know how to plug this up (heater 7 pwn and gnd?)
                        • gabbieundefined gabbie referenced this topic
