    DUET 2 Wifi heaters-"undefined" & Bed-"error"
    • siriltejadundefined
      siriltejad
      I setup the Duet 2 wifi with the duex 5 extension board. I can connect to the duet 2 access point and can home the axis but i cannot get the heaters and the bed working. What am I doing wrong. I am attaching the config file for reference.
      config.g
      • aidarundefined
        aidar
        Looks like you missing M307 commands in config.g https://duet3d.dozuki.com/Wiki/Gcode#Section_M307_Set_or_report_heating_process_parameters
        • DIY-O-Sphereundefined
          DIY-O-Sphere
          The parameter setings M307 are missing.
          Standard is M307 H0 B1 S1.00 (PID-Mode) (example for the bed)
          You have to configure this for each heater.
          Afterwards do a PID Tunning
          https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
          (UTC+1)
            Which firmware version are you running?
            If you send M98 P"config.g" from the console, do you get any error messages?
