    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    12.3k
    • appjawsundefined
      appjaws
      Nearly there.
      My bed isn't heating up at all
      RRF 2 old -- worked
      M307 H0 A104.6 C986.0 D1.9 ;B0 ; Auto tune PID for bed heater
      M305 P0 R4700 B3950 S"Bed Heater" ; bed thermistor R and B values
      RRF 3 new -- not working
      ; Thermistors and heaters
      M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bed_heat" T0 ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S70 ; set temperature limit for heater 0 to 70C
      M307 H0 A104.6 C986.0 D1.9 B0 S1.00 ; Auto tune PID for bed heater
      Thanks for any help
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      Dougal1957undefined 1 Reply Last reply Reply Quote 1
      • Dougal1957undefined
        Dougal1957 @appjaws
        @appjaws this is how my Heater section is configured on my delta with a Duet2 WiFi only difference is that I Use PT100's for my temp sensors so you will have to allow for that hop it helps.
        M143 S300 ; Set maximum heater temperature to 300C
        ;M305 P0 X201 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 201
        ;M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
        M308 S0 P"spi.cs2" Y"rtd-max31865" F50
        M308 S1 P"spi.cs1" Y"rtd-max31865" F50
        M950 H1 C"e0_heat" T1
        ;M307 H0 A199.0 C962.6 D5 B0
        ;M307 H1 A409.7 C232.2 D4.5 B0
        ;M307 H0 A161.6 C1109.8 D5.8 S1.00 V24.4 B0
        M307 H0 A449.1 C783.3 D9.8 S1.00 V24.4 B0
        M307 H1 A544.9 C280.1 D4.2 S1.00 V24.4 B0
        Can't see anything wrong in yours mind may be worth just double checking that the Zero's are Zero and not O
        Doug
        • Hornetriderundefined
          Hornetrider
          I found something odd, or it is just to late at night.
          This is my heater and fan definition:
          M308 S3 Y"mcu-temp" A"MCUTemp" ; configure sensor 3 as MCU Temperature
          M308 S4 Y"drivers" A"DriverTemp" ; configure sensor 4 as Dirver Temperature
          M950 F1 C"out8" Q500 ; create fan 0 on pin out7 and set its frequency
          M106 P1 S1 H1 T45 C"Tool Fan" ; set fan 0 value. Thermostatic control is turned on
          M950 F0 C"out7" Q500 ; create fan 1 on pin out8 and set its frequency
          M106 P0 S0 H-1 C"Part Fan" ; set fan 1 value. Thermostatic control is turned off
          M950 F2 C"!out4" ; create fan 2 on pin out4 and set its frequency
          M106 P2 H3:H4 T48:60 C"MCU FAN" ; set fan 2 value. Thermostatic control is turned on
          I have noticed that in this config the bedtemp drives the MCU fan....like the "drivers" is using the bed temp...and not the drivers temp.
          Can somebody please check?
          Am I missing something?
          Btw. how do I activate the tacho and get and on DWC?
          I have a DUET3 6HC with RRF3.0 in use
            dc42 administrators @Hornetrider
            To use a 4-wire fan including the tacho, create the fan like this:
            M950 F2 C"!out4+out4.tach" Q25000
            Check your config by running M98 P"config.g" to see if there are any error messages. You can also send M308 S2, M308 S3 and M106 P2 to check that the settings for the electronics cooling fan and associated sensors are correct.
              Hornetrider
              thx for reacting so fast.
              I will check on your input.
              Before my last post I run the following check...
              Considering that for basic setup:
              M950 F2 C"!out4" -> works
              M106 P2 H3:H4 T48:60 C"MCU FAN" -> shows strange behaviour as "drivers" is influenced by "bedtemp"
              I checked this by changing M106 to:
              M106 P2 H4 T48:60 C"MCU FAN"
              While MCUTemp stayed at ~40°C I run the bed heating to 50°C and at 48°C the fan started running....
              Then I made a recheck for only "mcutemp" like:
              M106 P2 H3 T38:60 C"MCU FAN"
              And everything worked as supposed: as MCUtemp came below 38°C the fan turned of.
              Any clues?
                What temperature does Driver Temp show in DWC while you heat the bed?
                  Hornetrider
                  0.0°C
                    @Hornetrider said in RepRapFirmware 3.0 is released!:
                    I've just spotted the problem. You are using:
                    but it should be:
                    M106 P2 H3:4 T48:60 C"MCU FAN"
                    Sending M106 P2 would have revealed that it was monitoring sensors 0 and 3.
                      Hornetrider
                      thx!
                      I'll give it a try later today and get back to you.
                        Hornetrider
                        now everything is like it should be... thx a lot!
                        • 4latheundefined
                          4lathe
                          I have several duet 2 wifi’s on deltas and a railcore Zl and have converted the deltas to rrf3. I decided to put a maestro on a Frankenstein Ender 3 Pro that had a bltouch and v6 on it ( I first tested it with a spare duet wifi I had on hand using 2.05 and that worked perfectly). So I installed the maestro and tested using 2.05. No problems. I then upgraded to 3.0. All works perfectly except for deploy and retract probe. I added M950 S0 P”zprobe.mod” before my M558. I then changed the deployprobe.g and retractprobe.g to M280 P0 S10 and M280 P0 S90. When I went to homez, the probe didn't deploy. I tested issuing the commands in the console. Nothing. I searched here and saw that someone said they had to put the M950 command again just before the M280’s in deployprobe and retractprobe. I tried that and it works perfectly. There is no config-override file so nothing is undoing the original M950 in config.g. Any ideas on why this is happening? Thx for any help.
                          • DIY-O-Sphereundefined
                            DIY-O-Sphere
                            That are the lines for my Maestro.
                            Already on RRF3.01b
                            M558 P9 C"zprobe.in" H5 F120 T3000
                            M950 S0 C"zprobe.mod"
                            (UTC+1)
                              dc42 administrators @4lathe
                              @4lathe said in RepRapFirmware 3.0 is released!:
                              In 3.0 the Z probe defaults to using probe.in+zprobe.mod. You need to use
                              M558 to make the Z probe use just zprobe.in. Only then will zprobe.mod be free to use in M950.
                              • 4latheundefined
                                4lathe
                                @dc42 here is my config.g
                                M950 S0 C”zprobe.mod”
                                M558 P9 C”zprobe.in” H4 F120 T2400 R0.5
                                So are you saying I must place the M950 after that M558?
                                • 4latheundefined
                                  4lathe
                                  Just tried that. Works fine. Might be worth a comment somewhere to tell people that M950 has to be after the M558 since it default assigns both.
                                  • 4latheundefined
                                    4lathe
                                    On another issue, I upgraded to 3.01 no issues. I also upgraded to dwc 2.0.5 but in the system page it still shows 2.0.4.
                                    • 4latheundefined
                                      4lathe
                                      Sorry to post on this again, but used the version on chrishamm’s github page and it now shows 2.0.5.
                                        Thanks, I'll check which version I included in the release.
                                        In 3.01 there is no default Z probe, so the ordering issue between M950 and M558 should not arise.
                                        • Adryzzundefined
                                          Adryzz @dc42
                                          I just updated from 2.0 to 3.0 on a corexy, I used the online configurator, but the stallguard does not work, the cart does not stop, while in 2.0 it worked perfectly.
                                          In config,g i've put :
                                          M574 X1 S3 ; configure sensorless endstop for low end on X
                                          M574 Y1 S3 ; configure sensorless endstop for low end on Y
                                          and in homex.g (for example) i've put:
                                          M915 P0:1 S0 R0 F0 H400; both motors because corexy; Sensitivity 10, don't take action, don't filter, 400steps/sec
                                          G91 ; relative positioning
                                          G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X5 F6000 ; go back a few mm
                                          G90 ; absolute positioning
                                            Try upgrading to 3.01beta. I have a CoreXY tool changer running 3.01 with stall homing working on X and Y.
                                            Also, try running M98 P"config.g" to see if it generates any error messages.
