    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    12.5k
    • 4latheundefined
      4lathe
      I have several duet 2 wifi’s on deltas and a railcore Zl and have converted the deltas to rrf3. I decided to put a maestro on a Frankenstein Ender 3 Pro that had a bltouch and v6 on it ( I first tested it with a spare duet wifi I had on hand using 2.05 and that worked perfectly). So I installed the maestro and tested using 2.05. No problems. I then upgraded to 3.0. All works perfectly except for deploy and retract probe. I added M950 S0 P”zprobe.mod” before my M558. I then changed the deployprobe.g and retractprobe.g to M280 P0 S10 and M280 P0 S90. When I went to homez, the probe didn't deploy. I tested issuing the commands in the console. Nothing. I searched here and saw that someone said they had to put the M950 command again just before the M280’s in deployprobe and retractprobe. I tried that and it works perfectly. There is no config-override file so nothing is undoing the original M950 in config.g. Any ideas on why this is happening? Thx for any help.
      • DIY-O-Sphereundefined
        DIY-O-Sphere
        That are the lines for my Maestro.
        Already on RRF3.01b
        M558 P9 C"zprobe.in" H5 F120 T3000
        M950 S0 C"zprobe.mod"
        (UTC+1)
          dc42 administrators @4lathe
          @4lathe said in RepRapFirmware 3.0 is released!:
          In 3.0 the Z probe defaults to using probe.in+zprobe.mod. You need to use
          M558 to make the Z probe use just zprobe.in. Only then will zprobe.mod be free to use in M950.
          • 4latheundefined
            4lathe
            @dc42 here is my config.g
            M950 S0 C”zprobe.mod”
            M558 P9 C”zprobe.in” H4 F120 T2400 R0.5
            So are you saying I must place the M950 after that M558?
            • 4latheundefined
              4lathe
              Just tried that. Works fine. Might be worth a comment somewhere to tell people that M950 has to be after the M558 since it default assigns both.
              • 4latheundefined
                4lathe
                On another issue, I upgraded to 3.01 no issues. I also upgraded to dwc 2.0.5 but in the system page it still shows 2.0.4.
                • 4latheundefined
                  4lathe
                  Sorry to post on this again, but used the version on chrishamm’s github page and it now shows 2.0.5.
                    Thanks, I'll check which version I included in the release.
                    In 3.01 there is no default Z probe, so the ordering issue between M950 and M558 should not arise.
                    • Adryzzundefined
                      Adryzz @dc42
                      I just updated from 2.0 to 3.0 on a corexy, I used the online configurator, but the stallguard does not work, the cart does not stop, while in 2.0 it worked perfectly.
                      In config,g i've put :
                      M574 X1 S3 ; configure sensorless endstop for low end on X
                      M574 Y1 S3 ; configure sensorless endstop for low end on Y
                      and in homex.g (for example) i've put:
                      M915 P0:1 S0 R0 F0 H400; both motors because corexy; Sensitivity 10, don't take action, don't filter, 400steps/sec
                      G91 ; relative positioning
                      G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X5 F6000 ; go back a few mm
                      G90 ; absolute positioning
                        Try upgrading to 3.01beta. I have a CoreXY tool changer running 3.01 with stall homing working on X and Y.
                        Also, try running M98 P"config.g" to see if it generates any error messages.
                        • zerspaner_gerdundefined
                          zerspaner_gerd
                          Hello everyone
                          I just switched to RF3
                          I would have the following questions
                          • How can I convert M581 S-1 into RF3?
                          • Why does my X homing fail?
                            Y, Z and homeall work?
                          ; homeall.g
                          G1 H1 Z215 F1600			        ; move Z up stopping at the endstop
                          G1 H1 X-235 Y235 F4800		; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 X5 Y-5 F6000				; go back a few mm
                          G1 H1 X-7.5 Y7.5 F1300		; move slowly to X and Y axis endstops once more (second pass)
                          G1 Z-5.0 F1400
                          G1 H1 Z7.5 F800				; move Z up until the switch triggers
                          ; homex.g
                          G1 H1 X-232 F4800	; move quickly to X axis endstop and stop there (first pass)
                          G1 H1 X-7.5 F1300	; move slowly to X axis endstop once more (second pass)
                          ; homey.g
                          G1 H1 Y235 F4800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y-5 F6000     ; go back a few mm
                          G1 H1 Y7.5 F1300  ; move slowly to Y axis endstop once more (second pass)
                          ; homez.g
                          G1 H1 Z215 F1600		; move Z up until the switch triggers
                          G1 Z-5.0 F1400
                          M574 X1 S1 P"!xstop"					; configure active-low endstop for low end on X via pin xstop
                          M574 Y2 S1 P"!ystop"					; configure active-low endstop for high end on Y via pin ystop
                          M574 Z2 S1 P"!zstop"					; configure active-low endstop for high end on Z via pin zstop
                          If I write H2 in this sentence G1 X5 F6000 ; go back a few mm it works, but with Y, Z and homeall it is not necessary either?
                          I'm totally keen on the meta commands, but first one by one
                          greetings
                          Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                          littlehobbyshopundefined 1 Reply Last reply Reply Quote 0
                          • littlehobbyshopundefined
                            littlehobbyshop @zerspaner_gerd
                            @zerspaner_gerd You need that H2 in there as you described for the move back a few mm. My config has these and was generated by the config tool.
                            BLV MGN Cube w/Hemera, K8200, Sunlu S8
                              deckingman @littlehobbyshop
                              @littlehobbyshop said in RepRapFirmware 3.0 is released!:
                              He shouldn't need to add that H2. If the first G1 H1 X- move works, then the axis will be flagged as being homed. So after that, he should be able to do any G1 moves without any H parameter.
                              I suggest the OP steps through his homex one command at a time to check that the axis gets flagged as being homed after that first move. One thing that might be a clue is that in homeall, the move is X-235 but in home X it's - 232 (I think - but I'm typing this on my phone and can't scroll up).
                              zerspaner_gerdundefined 1 Reply Last reply Reply Quote 1
                                zerspaner_gerd @deckingman
                                @deckingman said in RepRapFirmware 3.0 is released!:
                                I agree with you. Why should it be necessary for X and not for Y, Z and homeall?
                                The warning message disappears for the first time, so I assume that it is considered referenced.
                                Well seen, I compared again and again and saw no differences.
                                But nothing has changed.
                                Since my english is not good here is a video of how the X axis behaves
                                https://www.dropbox.com/s/b9ms5dav5o08n24/2020-01-27 16-06-58.ts?dl=0
                                What I have found out is that this is completed without errors:
                                G1 H1 X-235.0 F4800	; move quickly to X axis endstop and stop there (first pass)
                                G1 X10.0 F6000		; go back a few mm
                                Only the result is wrong.
                                It seems to me that it ignores the second H1.
                                Why?
                                  zerspaner_gerd
                                  This is also completed without errors:
                                  ; homex.g
                                  G1 X5.0 F6000		; go back a few mm
                                  G1 H2
                                  One question should this not fail or complete successfully:
                                  ; homey.g
                                  G1 Y-50.0 F6000		; go back a few mm
                                  With RF2.05 I had no problems.
                                  And why only homex.g
                                  Can't be because of my config, right?
                                  Maybe in connection with low end and high endstop configuration
                                  greetings
                                  stewwyundefined 1 Reply Last reply Reply Quote 0
                                  • stewwyundefined
                                    stewwy @zerspaner_gerd
                                    @zerspaner_gerd This is my homex.g
                                    G1 H1 X-265 F3000 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 X5 F6000 ; go back a few mm
                                    G1 H1 X-265 F600 ; move slowly to X axis endstop once more (second pass)
                                    G1 H2 Z-5 F6000 ; lower Z again
                                    hope this helps , works perfectly on 3.0,
                                    zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
                                    • matej1006undefined
                                      matej1006 @dc42
                                      @dc42 Hello me again
                                      i just got my noctua fan which as we talk i want to control by water temp.
                                      so my code is now looking like that:
                                      ;Water temp
                                      M308 S5 P"e0temp" Y"thermistor" T100000 B4138 A"Water temp."                  ;configure sensor 5 as thermistor on pin e1temp
                                      ; Mesh  grid
                                      M557 X20:420 Y104:384 40
                                      M950 F0 C"!Fan0+exp.pb6" Q25000 				; fan 0 is a 4-wire PWM fan so invert it, use high PWM frequency, tacho connected to PB6 on expansion connector
                                      M106 P0 H5 T80
                                      i with that code fan no matther water temp work with same speed.
                                      i have Noctua 12V 1700 PWM fan that is connected yellow and black wire to 12v DC and blue wire to fan0- as i read.
                                      and i want that this fan work's on Thermostatic mode what i am doing wrong please help?
                                      Matej
                                        zerspaner_gerd @stewwy
                                        @stewwy Thanks
                                        I now run it with H2, but it is very strange that this is only necessary at homex.
                                        homeall, homez and homey no H2 is necessary.
                                        With RF2, H2 was nowhere necessary.
                                        Best regards
                                          dc42 administrators @matej1006
                                          @matej1006 said in RepRapFirmware 3.0 is released!:
                                          ;Water temp
                                          ; Mesh  grid
                                          M106 P0 H5 T80
                                          Matej
                                          I don't see anything wrong with that configuration. What reading is sensor 5 giving in DWC?
                                          matej1006undefined 1 Reply Last reply Reply Quote 0
                                            matej1006 @dc42
                                            @dc42 i figurit out i didn't connec 24V and 12V GND together 😉 Thanks anyway
                                            Can i use this same sensor to contorl water pump with that code?
                                            ;Water temp
                                            ; Mesh  grid
                                            M106 P0 H5 T30
                                            ;Water pump
                                            M950 F0 C"!Fan1" Q25000
                                            M106 P1 H5 T30
