    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    12.6k
    • Hornetriderundefined
      Hornetrider
      0.0°C
        @Hornetrider said in RepRapFirmware 3.0 is released!:
        M106 P2 H3:H4 T48:60 C"MCU FAN"
        I've just spotted the problem. You are using:
        but it should be:
        M106 P2 H3:4 T48:60 C"MCU FAN"
        Sending M106 P2 would have revealed that it was monitoring sensors 0 and 3.
          Hornetrider
          thx!
          I'll give it a try later today and get back to you.
            Hornetrider
            now everything is like it should be... thx a lot!
            • 4latheundefined
              4lathe
              I have several duet 2 wifi’s on deltas and a railcore Zl and have converted the deltas to rrf3. I decided to put a maestro on a Frankenstein Ender 3 Pro that had a bltouch and v6 on it ( I first tested it with a spare duet wifi I had on hand using 2.05 and that worked perfectly). So I installed the maestro and tested using 2.05. No problems. I then upgraded to 3.0. All works perfectly except for deploy and retract probe. I added M950 S0 P”zprobe.mod” before my M558. I then changed the deployprobe.g and retractprobe.g to M280 P0 S10 and M280 P0 S90. When I went to homez, the probe didn't deploy. I tested issuing the commands in the console. Nothing. I searched here and saw that someone said they had to put the M950 command again just before the M280’s in deployprobe and retractprobe. I tried that and it works perfectly. There is no config-override file so nothing is undoing the original M950 in config.g. Any ideas on why this is happening? Thx for any help.
              • DIY-O-Sphereundefined
                DIY-O-Sphere
                That are the lines for my Maestro.
                Already on RRF3.01b
                M558 P9 C"zprobe.in" H5 F120 T3000
                M950 S0 C"zprobe.mod"
                (UTC+1)
                  dc42 administrators @4lathe
                  @4lathe said in RepRapFirmware 3.0 is released!:
                  In 3.0 the Z probe defaults to using probe.in+zprobe.mod. You need to use
                  M558 to make the Z probe use just zprobe.in. Only then will zprobe.mod be free to use in M950.
                  • 4latheundefined
                    4lathe
                    @dc42 here is my config.g
                    M950 S0 C”zprobe.mod”
                    M558 P9 C”zprobe.in” H4 F120 T2400 R0.5
                    So are you saying I must place the M950 after that M558?
                    • 4latheundefined
                      4lathe
                      Just tried that. Works fine. Might be worth a comment somewhere to tell people that M950 has to be after the M558 since it default assigns both.
                      • 4latheundefined
                        4lathe
                        On another issue, I upgraded to 3.01 no issues. I also upgraded to dwc 2.0.5 but in the system page it still shows 2.0.4.
                        • 4latheundefined
                          4lathe
                          Sorry to post on this again, but used the version on chrishamm’s github page and it now shows 2.0.5.
                            Thanks, I'll check which version I included in the release.
                            In 3.01 there is no default Z probe, so the ordering issue between M950 and M558 should not arise.
                            • Adryzzundefined
                              Adryzz @dc42
                              I just updated from 2.0 to 3.0 on a corexy, I used the online configurator, but the stallguard does not work, the cart does not stop, while in 2.0 it worked perfectly.
                              In config,g i've put :
                              M574 X1 S3 ; configure sensorless endstop for low end on X
                              M574 Y1 S3 ; configure sensorless endstop for low end on Y
                              and in homex.g (for example) i've put:
                              M915 P0:1 S0 R0 F0 H400; both motors because corexy; Sensitivity 10, don't take action, don't filter, 400steps/sec
                              G91 ; relative positioning
                              G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
                              G1 X5 F6000 ; go back a few mm
                              G90 ; absolute positioning
                                Try upgrading to 3.01beta. I have a CoreXY tool changer running 3.01 with stall homing working on X and Y.
                                Also, try running M98 P"config.g" to see if it generates any error messages.
                                • zerspaner_gerdundefined
                                  zerspaner_gerd
                                  Hello everyone
                                  I just switched to RF3
                                  I would have the following questions
                                  • How can I convert M581 S-1 into RF3?
                                  • Why does my X homing fail?
                                    Y, Z and homeall work?
                                  ; homeall.g
                                  G1 H1 Z215 F1600			        ; move Z up stopping at the endstop
                                  G1 H1 X-235 Y235 F4800		; move quickly to X and Y axis endstops and stop there (first pass)
                                  G1 X5 Y-5 F6000				; go back a few mm
                                  G1 H1 X-7.5 Y7.5 F1300		; move slowly to X and Y axis endstops once more (second pass)
                                  G1 Z-5.0 F1400
                                  G1 H1 Z7.5 F800				; move Z up until the switch triggers
                                  ; homex.g
                                  G1 H1 X-232 F4800	; move quickly to X axis endstop and stop there (first pass)
                                  G1 H1 X-7.5 F1300	; move slowly to X axis endstop once more (second pass)
                                  ; homey.g
                                  G1 H1 Y235 F4800 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 Y-5 F6000     ; go back a few mm
                                  G1 H1 Y7.5 F1300  ; move slowly to Y axis endstop once more (second pass)
                                  ; homez.g
                                  G1 H1 Z215 F1600		; move Z up until the switch triggers
                                  G1 Z-5.0 F1400
                                  M574 X1 S1 P"!xstop"					; configure active-low endstop for low end on X via pin xstop
                                  M574 Y2 S1 P"!ystop"					; configure active-low endstop for high end on Y via pin ystop
                                  M574 Z2 S1 P"!zstop"					; configure active-low endstop for high end on Z via pin zstop
                                  If I write H2 in this sentence G1 X5 F6000 ; go back a few mm it works, but with Y, Z and homeall it is not necessary either?
                                  I'm totally keen on the meta commands, but first one by one
                                  greetings
                                  Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                  littlehobbyshopundefined 1 Reply Last reply Reply Quote 0
                                  • littlehobbyshopundefined
                                    littlehobbyshop @zerspaner_gerd
                                    @zerspaner_gerd You need that H2 in there as you described for the move back a few mm. My config has these and was generated by the config tool.
                                    BLV MGN Cube w/Hemera, K8200, Sunlu S8
                                      deckingman @littlehobbyshop
                                      @littlehobbyshop said in RepRapFirmware 3.0 is released!:
                                      He shouldn't need to add that H2. If the first G1 H1 X- move works, then the axis will be flagged as being homed. So after that, he should be able to do any G1 moves without any H parameter.
                                      I suggest the OP steps through his homex one command at a time to check that the axis gets flagged as being homed after that first move. One thing that might be a clue is that in homeall, the move is X-235 but in home X it's - 232 (I think - but I'm typing this on my phone and can't scroll up).
                                      zerspaner_gerdundefined 1 Reply Last reply Reply Quote 1
                                        zerspaner_gerd @deckingman
                                        @deckingman said in RepRapFirmware 3.0 is released!:
                                        I agree with you. Why should it be necessary for X and not for Y, Z and homeall?
                                        The warning message disappears for the first time, so I assume that it is considered referenced.
                                        Well seen, I compared again and again and saw no differences.
                                        But nothing has changed.
                                        Since my english is not good here is a video of how the X axis behaves
                                        https://www.dropbox.com/s/b9ms5dav5o08n24/2020-01-27 16-06-58.ts?dl=0
                                        What I have found out is that this is completed without errors:
                                        G1 H1 X-235.0 F4800	; move quickly to X axis endstop and stop there (first pass)
                                        G1 X10.0 F6000		; go back a few mm
                                        Only the result is wrong.
                                        It seems to me that it ignores the second H1.
                                        Why?
                                          zerspaner_gerd
                                          This is also completed without errors:
                                          ; homex.g
                                          G1 X5.0 F6000		; go back a few mm
                                          G1 H2
                                          One question should this not fail or complete successfully:
                                          ; homey.g
                                          G1 Y-50.0 F6000		; go back a few mm
                                          With RF2.05 I had no problems.
                                          And why only homex.g
                                          Can't be because of my config, right?
                                          Maybe in connection with low end and high endstop configuration
                                          greetings
                                          stewwyundefined 1 Reply Last reply Reply Quote 0
                                          • stewwyundefined
                                            stewwy @zerspaner_gerd
                                            @zerspaner_gerd This is my homex.g
                                            G1 H1 X-265 F3000 ; move quickly to X axis endstop and stop there (first pass)
                                            G1 H2 X5 F6000 ; go back a few mm
                                            G1 H1 X-265 F600 ; move slowly to X axis endstop once more (second pass)
                                            G1 H2 Z-5 F6000 ; lower Z again
                                            hope this helps , works perfectly on 3.0,
                                            zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
