    Duet 3 Mainboard 6HC
    • andornotundefined
      andornot
      Does this board support the paneldue?
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
        jay_s_uk
        Yes, it does. See https://forum.duet3d.com/topic/13640/paneldue-on-the-duet3-board?_=1579075335574
          Yes, when running in standalone mode. If you use Duet 3 with an attached RPi then you would normally use an HDMI touch screen connected to the RPi and running DWC instead.
          • andornotundefined
            andornot
            So would you recommend this board for future upgrades for the high temperature delta printer i am designing? If i wanted to connect a touch screen would i have to use a raspberry pi?
              dc42 administrators @andornot
              @andornot said in Duet 3 Mainboard 6HC:
              Duet 3 can run in standalone mode (without RPi) with a PanelDue, just like Duet 2, except that the cabling (4-wire cable) doesn't support the SD card socket on PanelDue. If you attach a RPi then the file and macro-related functions of PanelDue won't work, so you should use a touch screen connected to the RPi instead.
              The main drivers for using the more expensive Duet 3 rather the Duet 2 are:
              1. A need for greater or more flexible expansion.
              2. A need for higher stepper motor currents.
              3. A need for a customised user interface (which is easier to do using Duet 3/DWC than it is to modify PanelDue firmware).
              4. A need for the advanced features that the attached Raspberry Pi will be able to support.
              If this is a one-off machine and Duet 2 (without a DueX expansion board) or Duet Maestro meets your needs, then there is no need to go to Duet 3. But if this is going to be a commercially-manufactured machine and the pricing permits the higher cost of Duet 3, then choosing Duet 3 will give you more flexibility.
              HTH David
              andornotundefined 1 Reply Last reply Reply Quote 1
              • andornotundefined
                andornot @dc42
                @dc42 thanks for the info, i have ordered one.
