    Heater 1 fault
    602
    • gabi68undefined
      gabi68
      I have the notorius error heater 1 fault. I g=have a PT100 and when I power the duet the leds are on and the interface reports Heater1 fault. If I put the provided resistor between pin 2 and 3 on the PT100 leds go off and temperature is 0C (as is should) meaning all is working. Still that fault after disconnecting the resistor.
      config duet sd card.g
        droftarts administrators
        @gabi68 Sounds more like a wiring issue, or a failed PT100. If you have a multimeter you can check the resistance on the wires; use this table to check the resistance of the PT100 at different temperatures: https://www.sterlingsensors.co.uk/pt100-resistance-table
        PT100 will be more reliable if you wire it 4-wire, too; see https://miscsolutions.wordpress.com/2016/06/25/more-delta-printer-upgrades-wifi-and-silence/
        When using a 2-wire PT100 sensor, any additional resistance in the wires and connections between the sensor and the electronics will cause an increase in the reading, by about 1°C per 0.4 ohm. This inaccuracy can be avoided by using a 4-wire connection. So I chose the 4-wire configuration for greatest accuracy. However, as long as you are careful to make good connections, the sensor will work just fine in 2-wire mode and you can save some wiring.
        Wiring a 2-wire PT100 as 4-wire is further down the page. Also see this post re loose connections at the cartridge, and avoiding running wires near high current wires: https://forum.duet3d.com/post/35691
        • gabi68undefined
          gabi68
          Tryed that still nothing. Connections are as follows:
          Smart efector side Duet side
          Pin 1 Unconnected
          Pin 2 Pin 2 PT100
          Pin 3 Pin 3 PT100
          Pin 4 Unconnected
          Input 2
          H+ to E0 VIN
          H- to E0-
          config.g
          M305 P1 X200 ; Set thermistor + ADC parameters for heater 1
          The z probe flash twice at startup and reacts on every tap.
          Led and fan working properly.
          Having the prvided resistor between pin 2 and 3 on the PT100 report 0 C
          Still heater 1 fault.
          Before order a thermistor (bed is working like that very accurate), what else should I do?
          Thank you
          Gabi
            jay_s_uk
            Do you have the jumper fitted for 2 wire PT100 on the smart effector?
            Have you tried connecting the PT100 directly to the daughter board?
            gabi68undefined 1 Reply Last reply Reply Quote 0
            • gabi68undefined
              gabi68 @jay_s_uk
              @jay_s_uk
              The jumpers are in place. PT100 is inseterd and plastic prong is in place. Anything else, please?
                jay_s_uk
                I would suggest checking the PT100 with a multimeter to make sure the resistance reading is correct.
                I would also use a multimeter to check your point to point wiring to make sure there are no breakages in the cable or poorly made crimps.
                  droftarts administrators @gabi68
                  @gabi68 Would have been good to mention you were using a Smart Effector! Have you actually measured the resistance of the PT100? You need to check at each connector. I don't see how this is a config/Duet issue, as you get 0ºC with the resistor.
                  • gabi68undefined
                    gabi68 @droftarts
                    @droftarts
                    I just checkit. The resistance is under 1 ohm and the continuty is there for all cables. According to the PT100 resistance table I should see values between 107 and 111 ohm.
                    I agree is not a duet issue, but this (PT100) is sold like an addon for duet. Any advice, please?
                    Gabi
                      @gabi68 Contact the seller and ask for a warranty replacement, as the PT100 seems to be faulty. I'd connect the 100ohm resistor to the pins on the SmartEffector, which should check continuity and for any extra resistance/short in the wiring.
                      • gabi68undefined
                        gabi68 @droftarts
                        @droftarts
                        There is any way to check if the PT 100 is fried?
                        Do you know it will be better to order a thermocouple board with associate thermocuple?
                        Gabi
                        • Vetiundefined
                          Veti @gabi68
                          @gabi68 said in Heater 1 fault:
                          it it is 1 ohm there is a short somewhere inside, so its fried.
                            If the resistance really is 1 ohm, it's probably a thermocouple, not a PT100.
                            • gabi68undefined
                              gabi68 @dc42
                              @dc42 How can I check if is a thermocouple?
                                dc42 administrators @gabi68
                                What colour are the wires coming out of it? I believe E3D uses different coloured wires for thermistor, PT100 and thermocouple cartridges.
                                • gabi68undefined
                                  gabi68 @dc42
                                  @dc42 Red
                                    @dc42 Red
                                    Looks like E3D PT100 is red https://e3d-online.com/pt100-temperature-sensor
                                    Thermocouples usually have a braided cover https://e3d-online.com/type-k-thermocouple-cartridge
                                    Thermistors are blue https://e3d-online.com/thermistor-cartridge
                                    So probably still just a failed PT100.
