    RepRapFirmware 3.01beta1 released
    Beta Firmware
    16
    60
    3.4k
    • gtj0undefined
      gtj0 @dc42
      @dc42 said in RepRapFirmware 3.01beta1 released:
      Thanks for confirming. FWIW, maximum GCode line length excluding leading white space, line number and checksum (if present) and comments is currently 160 characters.
      Are you sending them via text message??? 🙂
      • DIY-O-Sphereundefined
        DIY-O-Sphere @dc42
        Read the upgrade notes!
        Sorry....The one who can read is in advantage
        (UTC+1)
          dc42 administrators @gtj0
          @gtj0 said in RepRapFirmware 3.01beta1 released:
          Hadn't you noticed your smartphone bills going up every time you print? 😉
          gtj0undefined 1 Reply Last reply Reply Quote 1
          • gtj0undefined
            gtj0 @dc42
            Ah that makes sense now. I though it was the cat texting his buddy across the street.
            • garyd9undefined
              garyd9 @kraegar
              @kraegar said in RepRapFirmware 3.01beta1 released:
              Here is the version that works well:
              I like this, but it seems unnatural to have to repeat the same G30 commands twice in the same script. This is more significant with a delta printer (that often has many more probe points.)
              I'm wondering what alternatives might exist. I see there's no do/while (which would be my first thought), but I'm wondering if it would work to put the list of G30 gcodes in a different file (bed-probes.g)
              @dc42, do the variables from the object model available survive across different scripts? For example, if I had file called "bed-ProbePoints.g" that contained something like:
              G30 P0 Xn Yn
              G30 P18 X0 Y0 S6
              And then my bed.g contained:
              M561
              G28
              M98 P"bed-ProbePoints.g"
              while true
                  if iterations > 5
                      abort "something needs tightening..."
                  if abs(move.initialDeviation.deviation - move.calibrationDeviation.deviation) <= 0.01
                     break
              Would this work? Would the deviation values be updated across the scripts?
              Thank you
              Gary
              kraegarundefined 1 Reply Last reply Reply Quote 0
              • kraegarundefined
                kraegar @garyd9
                @garyd9 This was my very rough first iteration (and still is early, room for improvement, etc etc). Only posted in this thread due to the bugs I was noticing.
                Anyway, see my post here where I did split the G30 segment out into a macro:
                https://forum.duet3d.com/topic/13890/auto-tramming-a-railcore-using-conditional-gcode
                garyd9undefined 1 Reply Last reply Reply Quote 1
                • garyd9undefined
                  garyd9 @kraegar
                  @kraegar That is great (and answers my question.)
                  thank you
                  • insertnamehereundefined
                    insertnamehere @dc42
                    You've found a bug (the property table wasn't ordered alphabetically after I renamed a property, so the binary search failed). I've fixed it in the latest build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. I also added a compile-time check to prevent this happening in future, and an extra property state.upTime.
                    Firstly, thanks for the quick response. I've tried the fixed firmware and it works great.
                    Another thing, I use an ATX type 24V supply controlled by the PS_ON pin.
                    After all axis are homed, if I turn of the 24V supply, the axis remain homed "Blue" on the DWC. If I turn on the ATX supply again I can move all axis as if they are homed. Shouldn't turning of the 24V supply automatically mark all axis as homed : false?
                    m409
                    {"key":"","flags":"","result":{"boards":[{"firmwareFileName":"Duet2CombinedFirmware.bin","firmwareVersion":"3.01-beta1+1","iapFileNameSD":"Duet2CombinedIAP.bin","mcuTemp":{"current":39.6,"max":39.9,"min":38.0},"name":"Duet 2 WiFi","shortName":"2WiFi","vIn":{"current":0.7,"max":24.4,"min":0.4}}],"heat":{"coldExtrudeTemperature":160.0,"coldRetractTemperature":90.0,"heaters":[{"current":22.0,"sensor":0,"state":"Off"},{"current":23.2,"sensor":1,"state":"Active"}],"sensors":[{"lastReading":22.0,"name":"","type":"Thermistor"},{"lastReading":23.2,"name":"","type":"Thermistor"}]},"job":{"file":{"filament":[],"firstLayerHeight":0.0,"generatedBy":"","height":0.0,"lastModified":"28115-10-29T03:41:51","layerHeight":0.0,"numLayers":0,"printTime":0,"simulatedTime":0,"size":0},"lastFileName":"","layer":0,"timesLeft":{"filament":0.0,"file":0.0,"layer":0.0}},"move":{"axes":[{"homed":true,"letter":"X","max":300.0,"min":0.0,"userPosition":70.000,"visible":true},{"homed":true,"letter":"Y","max":300.0,"min":0.0,"userPosition":265.000,"visible":true},{"homed":true,"letter":"Z","max":350.0,"min":0.0,"userPosition":4.213,"visible":true}],"calibrationDeviation":{"deviation":0.000,"mean":0.000},"currentMove":{"requestedSpeed":0.0,"topSpeed":0.0},"daa":{"enabled":false,"minimumAcceleration":10.0,"period":0.0},"idle":{"factor":0.7,"timeout":30000},"initialDeviation":{"deviation":0.004,"mean":0.014},"meshDeviation":{"deviation":0.032,"mean":0.099},"printingAcceleration":10000.0,"speedFactor":100.0,"travelAcceleration":10000.0},"network":{"interfaces":[{"actualIP":"192.168.1.142","firmwareVersion":null,"gateway":"0.0.0.0","subnet":"0.255.255.255","type":"wifi"}]},"state":{"currentTool":0,"machineMode":"FFF","status":"Off","upTime":193}}}
                      dc42 administrators @insertnamehere
                      @insertnamehere said in RepRapFirmware 3.01beta1 released:
                      Yes. I will fix that.
                      garyd9undefined 1 Reply Last reply Reply Quote 0
                      • garyd9undefined
                        garyd9 @dc42
                        With the build from your dropbox...
                        Error: in file macro, line 18 column 12: unknown value abs
                        The line in question:
                        if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.02
                          @garyd9, try enclosing the whole expression in { } so that the round brackets are not treated as enclosing comments.
                          The deviation value is RMS so it is always positive, unlike the mean.
                          dc42undefined garyd9undefined 2 Replies Last reply Reply Quote 0
                            dc42 administrators @dc42
                            I've just put 3.01-beta1+1 (2020-01-17b3) binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. These support additional OM variables, including extruder parameters such as pressure advance.
                            The format for driver IDs may change in future beta releases. I am currently returning strings such as "3.1" for driver 1 on board 3; but I may change this to return 301 in this case, i.e. 100*board_id + driver_number. Whichever I choose, I will allow the format returned by the OM variable to be used in M584, M569 etc.
                            • Danalundefined
                              Danal
                              If you are taking votes/opinions, overall compatibility with the pin labeling nomenclature seems desirable.
                              • garyd9undefined
                                garyd9 @dc42
                                About being positive, that's true, but the difference between means might be negative, so I want to get the absolute value of the difference...
                                As for using curly braces, I'm not having much luck with that. Perhaps because I'm not quite sure where, exactly, the curly braces should be. Here's some of the things I tried, followed by the resulting error:
                                if {abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                Error: in file macro, line 16 column 91: expected ')'
                                if abs{(move.calibrationDeviation.deviation - move.initialDeviation.deviation)} < 0.002
                                Error: in file macro, line 16 column 11: unknown value abs
                                if abs{move.calibrationDeviation.deviation - move.initialDeviation.deviation} < 0.002
                                if abs({move.calibrationDeviation.deviation - move.initialDeviation.deviation}) < 0.002
                                Error: in file macro, line 16 column 12: unknown value abs
                                {if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                Error: Bad command: {if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                To be absolutely clear, my intention is to get the absolute value of the difference of the two deviations, and compare that to 0.002
                                • Danalundefined
                                  Danal
                                  @garyd9 said in RepRapFirmware 3.01beta1 released:
                                  I get no error with the format above. Running:
                                  Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-beta1+1 (2020-01-17b3)
                                  • garyd9undefined
                                    garyd9 @Danal
                                    @Danal said in RepRapFirmware 3.01beta1 released:
                                    Odd. I'm also running "3.01-beta1+1 (2020-01-17b3)". Perhaps because I'm running it on a Duet2 (duet wifi)?
                                    I'll try again in 5-6 hours (if I'm still awake) when my current print finishes...
                                    I will say that I'm starting to wonder if I should "upgrade" to a duet3. While I really don't need the extra ports or capabilities, the newer versions of RRF3 seem to bog down the older boards. I started to get hiccups on my delta at even only 150mm/sec movements now. 😞
                                    • Danalundefined
                                      Danal
                                      Yeah, and I'm running a Pi. It is very unclear to me how much gcode is processed on the DSF on the Pi vs actually being passed to the Duet.
                                        dc42 administrators @Danal
                                        GCodes commands are pre-parsed on the Pi, but most of them are just passed in the parsed state to the Duet. A few such as M98 and M32 are processed partly on the Pi.
                                        I am currently looking at the why RRF3 has hiccups at lower step rates than RRF2.
                                        • garyd9undefined
                                          garyd9 @Danal
                                          I've confirmed that I DO get an error similar to "Error: in file macro, line 22 column 90: expected ')'" with the same statement (followed by a newline, tab, and 'break' statement':
                                          if{abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                          I'm using a Duet Wifi 1.04 with firmware "RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-beta1+1 (2020-01-17b3)" (No SBC option exists.) I wonder if the same problem exists for non-SBC Duet3 users.
                                          • kraegarundefined
                                            kraegar
                                            I couldn't get abs to work either, so just nested the if statements. Ugly, but I figured it was something I was doing wrong. Also testing on a duet2.
