    RepRapFirmware 3.01beta1 released
    Beta Firmware
    16
    60
    3.5k
    • kraegarundefined
      kraegar
      We're going to need line numbers in the file editor in DWC now 🙂
      • 4latheundefined
        4lathe
        Can I use that new duet2combinedfirmware.bin on my maestro? The 3.01 was duetmaestrofirmware.bin.
        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
        • DIY-O-Sphereundefined
          DIY-O-Sphere @4lathe
          @4lathe
          It's still DuetMaestroFirmware.bin
          (UTC+1)
            DIY-O-Sphere @dc42
            Hi David, maybe I have found a bug....
            For testing I was back on 2.05 on a Maestro (DWC 2.06) and I was not able to get back directly to 3.01b.
            Flashing 3.0 stable worked.
            (UTC+1)
              dc42 administrators @DIY-O-Sphere
              @DIY-O-Sphere said in RepRapFirmware 3.01beta1 released:
              Read the upgrade notes!
              • gtj0undefined
                gtj0 @dc42
                @dc42 said in RepRapFirmware 3.01beta1 released:
                Thanks for confirming. FWIW, maximum GCode line length excluding leading white space, line number and checksum (if present) and comments is currently 160 characters.
                Are you sending them via text message??? 🙂
                  DIY-O-Sphere @dc42
                  Sorry....The one who can read is in advantage
                  (UTC+1)
                    dc42 administrators @gtj0
                    @gtj0 said in RepRapFirmware 3.01beta1 released:
                    Hadn't you noticed your smartphone bills going up every time you print? 😉
                    gtj0undefined 1 Reply Last reply Reply Quote 1
                    • gtj0undefined
                      gtj0 @dc42
                      Ah that makes sense now. I though it was the cat texting his buddy across the street.
                      • garyd9undefined
                        garyd9 @kraegar
                        @kraegar said in RepRapFirmware 3.01beta1 released:
                        Here is the version that works well:
                        I like this, but it seems unnatural to have to repeat the same G30 commands twice in the same script. This is more significant with a delta printer (that often has many more probe points.)
                        I'm wondering what alternatives might exist. I see there's no do/while (which would be my first thought), but I'm wondering if it would work to put the list of G30 gcodes in a different file (bed-probes.g)
                        @dc42, do the variables from the object model available survive across different scripts? For example, if I had file called "bed-ProbePoints.g" that contained something like:
                        G30 P0 Xn Yn
                        G30 P18 X0 Y0 S6
                        And then my bed.g contained:
                        M561
                        G28
                        M98 P"bed-ProbePoints.g"
                        while true
                            if iterations > 5
                                abort "something needs tightening..."
                            if abs(move.initialDeviation.deviation - move.calibrationDeviation.deviation) <= 0.01
                               break
                        Would this work? Would the deviation values be updated across the scripts?
                        Thank you
                        Gary
                        kraegarundefined 1 Reply Last reply Reply Quote 0
                        • kraegarundefined
                          kraegar @garyd9
                          @garyd9 This was my very rough first iteration (and still is early, room for improvement, etc etc). Only posted in this thread due to the bugs I was noticing.
                          Anyway, see my post here where I did split the G30 segment out into a macro:
                          https://forum.duet3d.com/topic/13890/auto-tramming-a-railcore-using-conditional-gcode
                          garyd9undefined 1 Reply Last reply Reply Quote 1
                          • garyd9undefined
                            garyd9 @kraegar
                            @kraegar That is great (and answers my question.)
                            thank you
                            • insertnamehereundefined
                              insertnamehere @dc42
                              You've found a bug (the property table wasn't ordered alphabetically after I renamed a property, so the binary search failed). I've fixed it in the latest build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. I also added a compile-time check to prevent this happening in future, and an extra property state.upTime.
                              Firstly, thanks for the quick response. I've tried the fixed firmware and it works great.
                              Another thing, I use an ATX type 24V supply controlled by the PS_ON pin.
                              After all axis are homed, if I turn of the 24V supply, the axis remain homed "Blue" on the DWC. If I turn on the ATX supply again I can move all axis as if they are homed. Shouldn't turning of the 24V supply automatically mark all axis as homed : false?
                              m409
                              {"key":"","flags":"","result":{"boards":[{"firmwareFileName":"Duet2CombinedFirmware.bin","firmwareVersion":"3.01-beta1+1","iapFileNameSD":"Duet2CombinedIAP.bin","mcuTemp":{"current":39.6,"max":39.9,"min":38.0},"name":"Duet 2 WiFi","shortName":"2WiFi","vIn":{"current":0.7,"max":24.4,"min":0.4}}],"heat":{"coldExtrudeTemperature":160.0,"coldRetractTemperature":90.0,"heaters":[{"current":22.0,"sensor":0,"state":"Off"},{"current":23.2,"sensor":1,"state":"Active"}],"sensors":[{"lastReading":22.0,"name":"","type":"Thermistor"},{"lastReading":23.2,"name":"","type":"Thermistor"}]},"job":{"file":{"filament":[],"firstLayerHeight":0.0,"generatedBy":"","height":0.0,"lastModified":"28115-10-29T03:41:51","layerHeight":0.0,"numLayers":0,"printTime":0,"simulatedTime":0,"size":0},"lastFileName":"","layer":0,"timesLeft":{"filament":0.0,"file":0.0,"layer":0.0}},"move":{"axes":[{"homed":true,"letter":"X","max":300.0,"min":0.0,"userPosition":70.000,"visible":true},{"homed":true,"letter":"Y","max":300.0,"min":0.0,"userPosition":265.000,"visible":true},{"homed":true,"letter":"Z","max":350.0,"min":0.0,"userPosition":4.213,"visible":true}],"calibrationDeviation":{"deviation":0.000,"mean":0.000},"currentMove":{"requestedSpeed":0.0,"topSpeed":0.0},"daa":{"enabled":false,"minimumAcceleration":10.0,"period":0.0},"idle":{"factor":0.7,"timeout":30000},"initialDeviation":{"deviation":0.004,"mean":0.014},"meshDeviation":{"deviation":0.032,"mean":0.099},"printingAcceleration":10000.0,"speedFactor":100.0,"travelAcceleration":10000.0},"network":{"interfaces":[{"actualIP":"192.168.1.142","firmwareVersion":null,"gateway":"0.0.0.0","subnet":"0.255.255.255","type":"wifi"}]},"state":{"currentTool":0,"machineMode":"FFF","status":"Off","upTime":193}}}
                                dc42 administrators @insertnamehere
                                @insertnamehere said in RepRapFirmware 3.01beta1 released:
                                Yes. I will fix that.
                                garyd9undefined 1 Reply Last reply Reply Quote 0
                                • garyd9undefined
                                  garyd9 @dc42
                                  With the build from your dropbox...
                                  Error: in file macro, line 18 column 12: unknown value abs
                                  The line in question:
                                  if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.02
                                    @garyd9, try enclosing the whole expression in { } so that the round brackets are not treated as enclosing comments.
                                    The deviation value is RMS so it is always positive, unlike the mean.
                                    dc42undefined garyd9undefined 2 Replies Last reply Reply Quote 0
                                      dc42 administrators @dc42
                                      I've just put 3.01-beta1+1 (2020-01-17b3) binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. These support additional OM variables, including extruder parameters such as pressure advance.
                                      The format for driver IDs may change in future beta releases. I am currently returning strings such as "3.1" for driver 1 on board 3; but I may change this to return 301 in this case, i.e. 100*board_id + driver_number. Whichever I choose, I will allow the format returned by the OM variable to be used in M584, M569 etc.
                                      • Danalundefined
                                        Danal
                                        If you are taking votes/opinions, overall compatibility with the pin labeling nomenclature seems desirable.
                                        • garyd9undefined
                                          garyd9 @dc42
                                          About being positive, that's true, but the difference between means might be negative, so I want to get the absolute value of the difference...
                                          As for using curly braces, I'm not having much luck with that. Perhaps because I'm not quite sure where, exactly, the curly braces should be. Here's some of the things I tried, followed by the resulting error:
                                          if {abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                          Error: in file macro, line 16 column 91: expected ')'
                                          if abs{(move.calibrationDeviation.deviation - move.initialDeviation.deviation)} < 0.002
                                          Error: in file macro, line 16 column 11: unknown value abs
                                          if abs{move.calibrationDeviation.deviation - move.initialDeviation.deviation} < 0.002
                                          if abs({move.calibrationDeviation.deviation - move.initialDeviation.deviation}) < 0.002
                                          Error: in file macro, line 16 column 12: unknown value abs
                                          {if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                          Error: Bad command: {if abs(move.calibrationDeviation.deviation - move.initialDeviation.deviation) < 0.002}
                                          To be absolutely clear, my intention is to get the absolute value of the difference of the two deviations, and compare that to 0.002
                                          • Danalundefined
                                            Danal
                                            @garyd9 said in RepRapFirmware 3.01beta1 released:
                                            I get no error with the format above. Running:
                                            Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-beta1+1 (2020-01-17b3)
