    Duet wifi upload stl fail
    669
    • joe92undefined
      joe92
      since the update to 3.01 it is no longer possible to upload the stl file
      • SIamundefined
        SIam
        have you updated the dwc to the latest version 2.0.6 ?
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • chas2706undefined
          chas2706
          Don't you mean gcode file.
          If you try to upload stl file, it will show errors anyway.
            A Former User
            Unlses you have network connectivity problems the issue is likely with the contents of the uploaded file. If its an stl file then, as chas says that won't work. but the screenshot does say g-code so presumably its from the slicer.
            So if it is a g-code file output from the slicer, your problem is likely in the slicer settings and attaching the file here might help getting to the bottom of it
            • joe92undefined
              joe92
              yes it is a gcode file. I saved the file directly to the SD card and it worked. only uploading via web control does not work
              • joe92undefined
                joe92
                Dwc 2.0.6
                  Can you upload that gcode file somewhere online and link it here?
                  • joe92undefined
                    joe92
                    CFFFP_xyzCalibration_cube1912.gcode
                    I tried to load directly here. this is one of many gcodes files that always worked. it doesn't matter if I take a new or old file, the error always comes
                      Which WiFi server version are you using?
                      • joe92undefined
                        joe92
                        Dzundefined 1 Reply Last reply Reply Quote 0
                        • Dzundefined
                          Dz @joe92
                          @joe92 I am on the same firmware and experience the same issues uploading gcode files. I think my record is 34 consecutive upload attempts, but eventually, it goes. Just gotta keep trying to smash it in there and the stars will align and the wifi fairy will sprinkle the right dust.
                          Board: Duet WiFi 1.02 or later
                          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
                          Duet WiFi Server Version: 1.23
                          • Dzundefined
                            Dz
                            My Plight:
                              A Former User @Dz
                              @Dz said in Duet wifi upload stl fail:
                              please post the output of M122 in your other thread.
                              OP can do the same here,
                              • joe92undefined
                                joe92
                                Hello, I found the reason for the error message. after the update, the wifi connections are no longer sufficient. everything works well via direct lan (pc) connection. thank you for your help
