    board not working
    573
    • patmurphyp9undefined
      patmurphyp9 @Phaedrux
      @Phaedrux I just tried that and nothing changed, but the always-on fan is working
        patmurphyp9
        would it be possible a fuse is blown because of the only thing that isn't working is the 3 volt supply
          patmurphyp9 @A Former User
            A Former User @patmurphyp9
            @patmurphyp9 said in board not working:
            I don't think so. but if you have a meter you could always measure them.
            the picture of U3 and surrounding area isn't very clear the only thing that stands out is something between the end of R85(?) and U3 but I cant tell if its a solder bridge, silscreen, maube those pads should be connected and its not a problem. But as you've tried different cables and different supplies I guess one of the admins will drop by and weigh in
              droftarts administrators @patmurphyp9
              @patmurphyp9 I agree with @bearer, looks like there’s something between U3 and R85. This may be shorting out 3.3V. If you have a multimeter, it would be good to test for 3.3V on a pin on the expansion header, just in case it’s the LED that’s failed. Have you tried connecting to it using YAT?
              Otherwise, if you have a soldering iron and a steady hand, and feel like cleaning up the possible bridge between U3 and R85, to see if that cures it, that’s fine.
              If none of those options work for you, I’m happy to authorise a warranty replacement. Contact E3D referencing this thread.
              Duet3D support
              A Former User? patmurphyp9undefined 2 Replies Last reply Reply Quote 0
                A Former User @droftarts
                @droftarts said in board not working:
                👍 didn't even cross my mind.
                the potential bridge bugged me a little as its on the 5v regulator and it does light up the 5v led so would expect u2 to get 5v and do its job.
                  patmurphyp9 @droftarts
                  @droftarts yes I have tried connecting it using YAT and I didn't even get a port response. I did check and there was something between the connection and I was able to blow it off, I tried again turning on the board but the same problem is there. I checked the 7.5A fuse and it is intact, and I have used a multimeter and I'm not seeing 3.3v anywhere closeIMG-7086.JPG
                    A Former User
                    Just for my curiosity could you put your negative probe on the big tab on U2 and measure against pin 1 and 3 (i.e the two outermost pins on each side) and post the two voltages.
                    You don't have to though, I'd contact E3D and arranged for a replacement if I were you.
                      I agree, please ask E3D to replace the Duet. With nothing else connected to the Duet, the 3.3V LED should light even when using USB power.
                      patmurphyp9undefined 1 Reply Last reply Reply Quote 0
                        patmurphyp9 @dc42
                        @dc42 Is there anything that I could do to fix it myself, and or is there a common issue/part to fix. I have contacted e3d and still waiting
                          https://raw.githubusercontent.com/T3P3/Duet/master/Duet2/Duet2v1.04/DuetWifiv1.04a_Schematic.pdf
                          if you can read the schematic and replace smd parts, then sure, no problem. if not you'll have to determine exactly what is the problem first. i.e. is it U2 not generating 3.3v or is it some of the devices using 3.3v that have failed and are shorting out the 3.3v rail?
                          a good start is to measure the voltages I asked for as it'll go a long way towards answering oart of that and directing the next step.
                          on the other hand of you're not confident you can fix it, its probably better to wait for the replacement.
