DUEX 5 - E4-E6 not working and a bit more...
999
    CJ.BRAVO
    ok so....... extruders aren't working again.
    really not sure whats the deal.
    Yesterday took off the famous "P4" and it worked. tried to run the system again today and nada...
    any new leads?
    undefined 1 Reply Last reply 16 Jan 2020, 15:46 Reply Quote 0
      droftarts administrators @CJ.BRAVO
      @CJ-BRAVO Probably you sent something in the console that you didn't update in the config.g. Please post you full current config.g for checking. You never said what firmware version you are running; please send M115 and post response.
      Also, having just answered another question about mixing ratios, I see that yours are a bit odd; T0 is E3:1, and T3 is E1.5:3. Usually mixing ratios should add up to 1, or, in your case, you will massively over-extrude.
        CJ.BRAVO
        Thanks for the quick response!
        firmware:
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04RC1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2019-07-14b1
        full config file:
        ; generated by RepRapFirmware Configuration Tool v2 on Thu May 02 2019 17:36:54 GMT+0300
        G21 ; Work in millimetres
        G90 ; Send absolute coordinates
        M555 P2 ; Set firmware compatibility to look like Marlin
        M568 ; tool mix ratios on
        M208 X300 Y400 Z400 S0 ; Set axis maxima
        M550 P ; Set machine name
        M552 S1 ; Enable network
        M587 ; Configure access point. You can delete this line once connected
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M569 P0 S0 ; Drive X goes backwards
        M569 P1 S0 ; Drive Y goes backwards
        M569 P2 S1 ; Drive Z1 goes forwards
        M569 P3 S0 ; Drive E0 FEEDER
        M569 P4 S1 ; Drive Z2 (E1) forwards
        M569 P5 S0 ;Drive (E2) goes forwards
        M569 P6 S0 ; Drive holder (E3)
        M569 P7 S0 ; Drive (E4)
        M584 X0 Y1 Z2:4 E3:5:6:7 ; Use E1 for Z axis
        M350 X32 Y32 Z16:16 I1 ; Configure microstepping with interpolation
        M350 E16:16:16:16 I0 ;microstepping without interpolation
        M92 X157.63 Y158.96 Z400:400 E115:315:50:50 ; Set steps per mm
        M566 X1200 Y1200 Z24:24 E800:800:800:800 ; Set maximum instantaneous speed changes (mm/min)
        M203 X30000 Y30000 Z600:600 E15000:15000:15000:15000 ; Set maximum speeds (mm/min)
        M201 X500 Y500 Z100:100 E6000:6000:6000:6000 ; Set accelerations (mm/s^2)
        M906 X800 Y800 Z800:800 E2500:1200:500:750 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X400 Y400 Z300 S0 ; Set axis maxima
        M574 X1 Y1 S1 ; Set active high endstops
        M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
        ; M557 X15:0 Y15:195 S20 ; Define mesh grid
        M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
        M307 H1 B0 S1.00 ; Disable bang-bang mode for the Hotend heater and set PWM limit
        M307 H0 A107.3 C652.0 D0.6 S1.00 ; Bed PID
        M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
        M307 H1 A284.4 C163.5 D1.5 S1.00 V12.1 B0 ; Hotend PID
        ; M307 H1 A105.3 C77.4 D1.5 S1.00 V12.1 B0 ; PID FOR INLINE HEATER ;
        M143 H1 S250 ; Set temperature limit for heater 1 to 120C
        M302 P1 S0 ; Allow cold extrusion minimum of 0
        M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P3 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0:1 S"A" ;Define tool 0
        M563 P1 D0 S"B" ;Define tool 1
        M563 P2 D3 S"C" ;Define tool 2
        M563 P3 D0:1 S"D" ;Define tool 3
        M567 P0 E3:1 ;MIXING RATIO tool 0
        M567 P1 E1 ;MIXING RATIO tool 1
        M567 P3 E1.5:3 ;MIXING RATIO tool 3
        G10 P0 ;Set tool 0 axis offsets
        ; G10 P1 X-67 Y-16 ;Set tool 1 axis offsets
        ; Automatic power saving
        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        ; M581 E2 S1 T0 C0 ; T0 = emergency stop on trigger
        ;M581 E2 S1 T3 C0 ; emergency stop on trigger3.g
        ; M581 E3 S1 T2 C0 ; prime-MIX - trigger2.g
        And yes, mixing ratios are odd - I am not extruding your regular filament.
        undefined 1 Reply Last reply 16 Jan 2020, 16:10 Reply Quote 0
          @CJ-BRAVO said in DUEX 5 - E4-E6 not working and a bit more...:
          Update to 2.05; it fixes a few bugs. https://github.com/dc42/RepRapFirmware/releases/tag/2.05
          You've defined a bed and hot end heater, but haven't defined a tool that uses the hot end heater, and so the temperature monitoring attached to that heater. Same for fans. Is that intentional? This shouldn't stop the extruders working, as they are only mapped to extruder drives.
          You don't need the M568 at the beginning; it's deprecated. See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M568_Turn_off_on_tool_mix_ratios
          For most of your motor settings, you've still got Znn:nn. Though this doesn't matter, and the firmware will ignore the second number, it's better to remove colon and second number.
          M350 X32 Y32 Z16:16 I1 - firmware will not be interpolating microsteps on X and Y. Duet Wifi only has interpolation at x16 microstepping
          Otherwise, I'm struggling to see what could be wrong. The only other thing is the current that you're pushing through E0, 2.5A. This might be causing the stepper driver to overheat and cut out, but you should get warnings of this in DWC.
          Can you send M122 after you send a command that doesn't move, and post the report?
            CJ.BRAVO
            I've updated RRF to 2.05
            I don't need the bed actually - I've got a modified cr10-s4, I noticed that (at least in the past) that I get an error if I tried to remove the bed related commands from config. I don't need it for my prints. can I just remove the beds' heater and such?
            I removed M568.
            the cr10-s4 has a double Z axes, I mapped the 2nd Z on E0 - suggested by a fellow cr10/duet user, instead of using the 2nd Z axis - it was not recommended to use the duets' 2ns Z spot with the cr10 motors or something as such.. don't really remember the reason.
            2.5A per motor, I thoght can handle that? I've got a 600W 25A psu for that reason...
            that motor also doesn't work all the time..
            At the moment the extruders work fine.........
            I'll attach M122 anyway:
            12:46:51 PMM122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later + DueX5
            Board ID: 08DGM-956GU-DGMSN-6JKF2-3SD6R-TVR3H
            Used output buffers: 3 of 24 (12 max)
            Static ram: 25712
            Dynamic ram: 94364 of which 0 recycled
            Exception stack ram used: 376
            Never used ram: 10620
            Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:08:54 ago, cause: software
            Last software reset at 2020-01-17 12:37, reason: User, spinning module GCodes, available RAM 10724 bytes (slot 1)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 32.3, current 32.4, max 34.1
            Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 5: standstill, SG min/max not available
            Driver 6: standstill, SG min/max 0/0
            Driver 7: standstill, SG min/max 0/55
            Date/time: 2020-01-17 12:46:49
            Cache data hit count 1608398685
            Slowest loop: 3.96ms; fastest: 0.07ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 222302ms
            === DDARing ===
            Scheduled moves: 16, completed moves: 16, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 15.52ms; fastest: 0.01ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is running
              WiFi firmware version 1.23
              WiFi MAC address
              WiFi Vcc 3.38, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 25272
              WiFi IP address
              WiFi signal strength -60dBm, reconnections 0, sleep mode modem
            thanks a lot!!!
              CJ.BRAVO
              ok so now it doesn't work, here's the m122:
              12:50:34 PMM122
              Used output buffers: 3 of 24 (9 max)
              Static ram: 25712
              Exception stack ram used: 344
              Never used ram: 10652
              Tasks: NETWORK(ready,752) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
              Owned mutexes:
              Last reset 00:00:56 ago, cause: software
              Last software reset at 2020-01-17 12:49, reason: User, spinning module GCodes, available RAM 10612 bytes (slot 2)
              Error status: 0
              MCU temperature: min 32.0, current 32.2, max 32.7
              Driver 5: standstill, SG min/max 0/213
              Driver 6: standstill, SG min/max not available
              Driver 7: standstill, SG min/max not available
              Date/time: 2020-01-17 12:50:33
              Cache data hit count 144601954
              Slowest loop: 2.10ms; fastest: 0.07ms
              Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 44391ms
              === DDARing ===
              Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
              Segments left: 0
              === Network ===
              Slowest loop: 15.49ms; fastest: 0.00ms
              • WiFi -
                WiFi MAC address
                WiFi Vcc 3.39, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25032
                WiFi IP address
                WiFi signal strength -61dBm, reconnections 0, sleep mode modem
              The only driver working is driver 5...
              After updating the firmware I only turned on driver 6 and 7 (E3/E4) which worked fine.
              then I turned on E1 (driver 5) worked as usual then tried again dr 6/7 and do not respond again.......
                CJ.BRAVO
                ok. current update - it works.
                I've updated the DWC to the latest version 2.06 and everything currently works (all tools and drivers).
                don't know if that due to the dwc update but at the moment everything looks fine.
                another thing that I did is to disconnect the mosfet (stock from cr10) that was connected but as I said before I'm not using the bed/heater so I disconnected that as well.
                Let's see whats next 🙂
                p.s.
                I found "M140 H-1" to disable the bed heater which looks better now on the dwc 🙂
                cheers!
                  CJ.BRAVO @dc42
                  Hey David, back to the original post - I've checked the funky duex 5, ground and all but still it acts funny like I mentioned earlier.
                  Can I check anything else?
                  thanks
                  undefined 1 Reply Last reply 24 Jan 2020, 15:05 Reply Quote 0
                    Hard to say, but my guess would be a bad ground connection or over-voltage on +5V has caused that. Is either of the 74HCT02 chips on the DueX getting hot?
                      deckingman @CJ.BRAVO
                      @CJ-BRAVO One thing I noticed in your config.g is that you are using the format Znnn:nnn for your Z axis speeds, accelerations, steps per mm etc. It isn't necessary even though you have multiple motors, because it's a single axis. It is necessary for extruders because each separate extruder is treated like a separate axis.
                      It probably isn't doing any harm and the extra values after the colon are likely just being ignored but who knows?? It might be wise to tidy that up and remove the multiple, colon separated values for the Z axis (just in case).
                      undefined 1 Reply Last reply 26 Jan 2020, 08:52 Reply Quote 0
                        CJ.BRAVO @deckingman
                        @deckingman
                        OK I'll change it.
                        I've got my initial config setup from a fellow double Z axis user who sent his config.
                        Thanks
                        24 out of 25
