DUEX 5 - E4-E6 not working and a bit more...
@CJ-BRAVO said in DUEX 5 - E4-E6 not working and a bit more...:
@droftarts
M584 X0 Y1 Z2:4 E3:5:6:7 P3 ; CHANGE TO P3 axes ?Just drop the 'P' parameter completely. It's only there to hide additional axes after XYZ excluding extruders (eg UVWABC), which you don't have. See M584.
M584 X0 Y1 Z2:4 E3:5:6:7; Use E1 for Z axis
All of the motor settings should be in the form
Xxx Yxx Zxx Exx:xx:xx:xx
. See this note on any of the motor setting gcodes, eg M92RepRapFirmware does not support individual motor settings where an axis has multiple motors connected to different stepper drivers. The first parameter specified will be used for all motors on the axis. You should use identical motors on any axis that has more than one motor to avoid unexpected behaviour.
Example: If you have two motors on your Z axis, physically connected to Z and E0 stepper drivers, configured with M584 Z2:3, set M92 Z80, not M92 Z80:80Extruders drives, though defined with M584 E3:5:6:7, are individual axes, so should have settings applied for them.
M350 X32 Y32 Z16 I1 ; Configure microstepping with interpolation M350 E16:16:16:16 I0 ; microstepping without interpolation M92 X157.63 Y158.96 Z400 E115:315:50:50 ; Set steps per mm M566 X1200 Y1200 Z24 E800:800:800:800 ; Set maximum instantaneous speed changes (mm/min) M203 X30000 Y30000 Z600 E15000:15000:15000:15000 ; Set maximum speeds (mm/min) M201 X500 Y500 Z100 E6000:6000:6000:6000 ; Set accelerations (mm/s^2) M906 X800 Y800 Z800 E2500:1500:540:540 I30 ; Set motor currents (mA)
Be aware you have your motor currents on each extruder motor set differently, with E3 at 2500mA.
M569 P0 S1 ; Drive X
M569 P1 S1 ; Drive Y
M569 P2 S1 ; Drive Z1
M569 P3 S1 ; Drive E0
M569 P4 S1 ; Drive Z2 (E1)
M569 P5 S1 ;Drive PRINT-HEAD (E2)
M569 P6 S0 ; Drive Q12 (E3)
M569 P7 S0 ; Drive D34 (E4)
M584 X0 Y1 Z2:4 E3:5:6:7 P4 ; Use E1 for Z axisohhhh ok... I'll check it out.
yes, I have multiple extruders with different currents.
I thought that if I have the same settings for some motors I can get away with it if I just combine the setting
i.e "M350 E16 I0 ;microstepping without interpolation"thanks!
i.e "M350 E16 I0 ;microstepping without interpolation"Yes, that's generally the case with extruders. You can check it, in the above example by sending that command and then sending M350 without parameters to report the current values.
i.e "M350 E16 I0 ;microstepping without interpolation"Yes, and I said that you can check this in an earlier post. However, I thought it would be best to put all these in explicitly, so you know all the settings are in there correctly! Then see if this solves the problem of E3 not working, before looking at the tool assignments.
What firmware version are you using? Send M115 and post response.
ok it looks like its working... took off "P4".
so when should I use that command?
thanks!
@droftarts
so when should I use that command?Your machine is set up so it doesn't need it, as you only have X, Y, Z and E axes. But interesting that putting P4 in messed up the first extruder drive. Will need to test and raise as bug if necessary.
The following is just an example!
Say you have an extra axis, U, that follows Z; perhaps a camera is mounted on it that tracks the bed or nozzle. Most of the time you want the U axis to mimic movement of the Z axis (because most slicers only slice for 4 axes - XYZE), but you need to home it individually. You define all of the axes with
M584 X0 Y1 Z2:3 U3 E4 P3
which leave only XYZ visible (P3). Moving Z will move U as well. But you need to home U independently, which you can only do when it's 'visible'. So in your homing macro, you would have something like:M584 Z2 U3 P4 ; break Z into separate axes, show 4 axes G1 [home Z] G1 [home U] M584 Z2:3 U3 P3 ; recombine Z, show 3 axes
See more detail here: https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18
A more extravagant example of this is @deckingman 's machine, see https://forum.duet3d.com/topic/12887/my-corexyuvab-as-of-today. It is a CoreXY machine, but it has 3 separate XY axes, as it has to move a lot of weight; one for the mixing nozzle, one that copies the movements of the nozzle but carries the extruders (because of the weight of six extruders), and then a third XY axes that moves in the reverse direction, with a mass to reduce amount the machine shakes! I think all these get homed individually by splitting out the axes, homing and recombining. Or at least used to, not sure exactly how he's doing it in RepRapFirmware 3, as now you don't necessarily have to split out the axes.
ok so....... extruders aren't working again.
really not sure whats the deal.Yesterday took off the famous "P4" and it worked. tried to run the system again today and nada...
any new leads?
@CJ-BRAVO Probably you sent something in the console that you didn't update in the config.g. Please post you full current config.g for checking. You never said what firmware version you are running; please send M115 and post response.
Also, having just answered another question about mixing ratios, I see that yours are a bit odd; T0 is E3:1, and T3 is E1.5:3. Usually mixing ratios should add up to 1, or, in your case, you will massively over-extrude.
Thanks for the quick response!
firmware:
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04RC1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2019-07-14b1full config file:
; generated by RepRapFirmware Configuration Tool v2 on Thu May 02 2019 17:36:54 GMT+0300; General preferences
G21 ; Work in millimetres
G90 ; Send absolute coordinates
M555 P2 ; Set firmware compatibility to look like Marlin
M568 ; tool mix ratios on; Axis Limits
M208 X300 Y400 Z400 S0 ; Set axis maxima; Network
M550 P ; Set machine name
M552 S1 ; Enable network
M587 ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive X goes backwards
M569 P1 S0 ; Drive Y goes backwards
M569 P2 S1 ; Drive Z1 goes forwards
M569 P3 S0 ; Drive E0 FEEDER
M569 P4 S1 ; Drive Z2 (E1) forwards
M569 P5 S0 ;Drive (E2) goes forwards
M569 P6 S0 ; Drive holder (E3)
M569 P7 S0 ; Drive (E4)
M584 X0 Y1 Z2:4 E3:5:6:7 ; Use E1 for Z axisM350 X32 Y32 Z16:16 I1 ; Configure microstepping with interpolation
M350 E16:16:16:16 I0 ;microstepping without interpolation
M92 X157.63 Y158.96 Z400:400 E115:315:50:50 ; Set steps per mm
M566 X1200 Y1200 Z24:24 E800:800:800:800 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y30000 Z600:600 E15000:15000:15000:15000 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z100:100 E6000:6000:6000:6000 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800:800 E2500:1200:500:750 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z300 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
; M557 X15:0 Y15:195 S20 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M307 H1 B0 S1.00 ; Disable bang-bang mode for the Hotend heater and set PWM limit
M307 H0 A107.3 C652.0 D0.6 S1.00 ; Bed PID
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M307 H1 A284.4 C163.5 D1.5 S1.00 V12.1 B0 ; Hotend PID
; M307 H1 A105.3 C77.4 D1.5 S1.00 V12.1 B0 ; PID FOR INLINE HEATER ;
M143 H1 S250 ; Set temperature limit for heater 1 to 120C
M302 P1 S0 ; Allow cold extrusion minimum of 0; Fans
M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P3 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0:1 S"A" ;Define tool 0
M563 P1 D0 S"B" ;Define tool 1
M563 P2 D3 S"C" ;Define tool 2
M563 P3 D0:1 S"D" ;Define tool 3
M567 P0 E3:1 ;MIXING RATIO tool 0
M567 P1 E1 ;MIXING RATIO tool 1
M567 P3 E1.5:3 ;MIXING RATIO tool 3G10 P0 ;Set tool 0 axis offsets
; G10 P1 X-67 Y-16 ;Set tool 1 axis offsets; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
; M581 E2 S1 T0 C0 ; T0 = emergency stop on trigger
;M581 E2 S1 T3 C0 ; emergency stop on trigger3.g
; M581 E3 S1 T2 C0 ; prime-MIX - trigger2.g
And yes, mixing ratios are odd - I am not extruding your regular filament.
Update to 2.05; it fixes a few bugs. https://github.com/dc42/RepRapFirmware/releases/tag/2.05
You've defined a bed and hot end heater, but haven't defined a tool that uses the hot end heater, and so the temperature monitoring attached to that heater. Same for fans. Is that intentional? This shouldn't stop the extruders working, as they are only mapped to extruder drives.
You don't need the M568 at the beginning; it's deprecated. See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M568_Turn_off_on_tool_mix_ratios
For most of your motor settings, you've still got Znn:nn. Though this doesn't matter, and the firmware will ignore the second number, it's better to remove colon and second number.
M350 X32 Y32 Z16:16 I1 - firmware will not be interpolating microsteps on X and Y. Duet Wifi only has interpolation at x16 microstepping
Otherwise, I'm struggling to see what could be wrong. The only other thing is the current that you're pushing through E0, 2.5A. This might be causing the stepper driver to overheat and cut out, but you should get warnings of this in DWC.
Can you send M122 after you send a command that doesn't move, and post the report?
I've updated RRF to 2.05
I don't need the bed actually - I've got a modified cr10-s4, I noticed that (at least in the past) that I get an error if I tried to remove the bed related commands from config. I don't need it for my prints. can I just remove the beds' heater and such?
I removed M568.
the cr10-s4 has a double Z axes, I mapped the 2nd Z on E0 - suggested by a fellow cr10/duet user, instead of using the 2nd Z axis - it was not recommended to use the duets' 2ns Z spot with the cr10 motors or something as such.. don't really remember the reason.
2.5A per motor, I thoght can handle that? I've got a 600W 25A psu for that reason...
that motor also doesn't work all the time..At the moment the extruders work fine.........
I'll attach M122 anyway:
12:46:51 PMM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-956GU-DGMSN-6JKF2-3SD6R-TVR3H
Used output buffers: 3 of 24 (12 max)
Static ram: 25712
Dynamic ram: 94364 of which 0 recycled
Exception stack ram used: 376
Never used ram: 10620
Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
Owned mutexes:
Last reset 00:08:54 ago, cause: software
Last software reset at 2020-01-17 12:37, reason: User, spinning module GCodes, available RAM 10724 bytes (slot 1)
Error status: 0
Free file entries: 10
MCU temperature: min 32.3, current 32.4, max 34.1
Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max 0/0
Driver 7: standstill, SG min/max 0/55
Date/time: 2020-01-17 12:46:49
Cache data hit count 1608398685
Slowest loop: 3.96ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 222302ms
=== DDARing ===
Scheduled moves: 16, completed moves: 16, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.52ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25272
WiFi IP address
WiFi signal strength -60dBm, reconnections 0, sleep mode modem
thanks a lot!!!
- WiFi -
ok so now it doesn't work, here's the m122:
12:50:34 PMM122
Used output buffers: 3 of 24 (9 max)
Static ram: 25712
Exception stack ram used: 344
Never used ram: 10652
Tasks: NETWORK(ready,752) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:56 ago, cause: software
Last software reset at 2020-01-17 12:49, reason: User, spinning module GCodes, available RAM 10612 bytes (slot 2)
Error status: 0
MCU temperature: min 32.0, current 32.2, max 32.7
Driver 5: standstill, SG min/max 0/213
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Date/time: 2020-01-17 12:50:33
Cache data hit count 144601954
Slowest loop: 2.10ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 44391ms
=== DDARing ===
Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
=== Network ===
Slowest loop: 15.49ms; fastest: 0.00ms
WiFi MAC address
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25032
WiFi IP address
WiFi signal strength -61dBm, reconnections 0, sleep mode modem
The only driver working is driver 5...
After updating the firmware I only turned on driver 6 and 7 (E3/E4) which worked fine.
then I turned on E1 (driver 5) worked as usual then tried again dr 6/7 and do not respond again....... - WiFi -
ok. current update - it works.
I've updated the DWC to the latest version 2.06 and everything currently works (all tools and drivers).don't know if that due to the dwc update but at the moment everything looks fine.
another thing that I did is to disconnect the mosfet (stock from cr10) that was connected but as I said before I'm not using the bed/heater so I disconnected that as well.Let's see whats next
p.s.
I found "M140 H-1" to disable the bed heater which looks better now on the dwccheers!
Hey David, back to the original post - I've checked the funky duex 5, ground and all but still it acts funny like I mentioned earlier.
Can I check anything else?
thanks
Hard to say, but my guess would be a bad ground connection or over-voltage on +5V has caused that. Is either of the 74HCT02 chips on the DueX getting hot?
@CJ-BRAVO One thing I noticed in your config.g is that you are using the format Znnn:nnn for your Z axis speeds, accelerations, steps per mm etc. It isn't necessary even though you have multiple motors, because it's a single axis. It is necessary for extruders because each separate extruder is treated like a separate axis.
It probably isn't doing any harm and the extra values after the colon are likely just being ignored but who knows?? It might be wise to tidy that up and remove the multiple, colon separated values for the Z axis (just in case).
OK I'll change it.
I've got my initial config setup from a fellow double Z axis user who sent his config.Thanks
