    Where to find the motor side connectors used on Nema17s?
    connectors motors
    813
    • zaptaundefined
      zapta
      Search AliExpress for PH2.0 and I believe that you will find what you are looking for. The Nema17 use the 6 pins connectors.
      • bricorundefined
        bricor @A Former User
        @bearer You are correct. Thank you for pointing that out.
          A Former User
          @zapta said in Where to find the motor side connectors used on Nema17s?:
          Search AliExpress
          Male crimp connectors? I've searched for 3 and 4 pins before without luck, only the preassembled cable like i linked to. I was shocked to find 2pin male on eBay. If you stumble onto a link please share, I'm still hunting for 3 and 4 pins for other projects:)
          • zaptaundefined
            zapta @A Former User
            Not crimps but PCB TH (can also be soldered with a shrink tube), straight and right angle. E.g.
            https://www.aliexpress.com/item/32965581442.html
            Edit: looking at JST's website for the PH series, the male side doesn't seem to come with a crimp version, just TH PCB (their website is built such that it's difficult to share links).
              A Former User
              There are non-JST branded (or rather unbranded maybe), but I've never seen them offered uncrimped with the exception of the 2 pin on eBay a few posts up. I send the guy a message asking for 3 and 4 pins, but don't expect an answer until after new year over there.
              edit: he actually offered 2,3, and 4 pin so I ordered some. Could still be worth asking for 6 pin
                A Former User @elliott.griffiths
                @elliott-griffiths mahbe this can work? https://www.aliexpress.com/item/32879665640.html
                (unrelated that guy is offering 3.96 VH connectors as well)
                • elliott.griffithsundefined
                  elliott.griffiths
                  Hi all,
                  Thank you very much for all your responses! This is why this community is awesome 👍
                  Decided to go with @bearer latest suggestion, thanks! Will make a circuit board to adapt I guess, many thanks!
                    @elliott-griffiths said in Where to find the motor side connectors used on Nema17s?:
                    why do you need a board? whats the use case?
                    elliott.griffithsundefined 1 Reply Last reply Reply Quote 0
                      elliott.griffiths @A Former User
                      @bearer Essentially we have a piece of equipment that doesn't support reversing the extruder at the moment (it's actually made for something else). So I want to reverse the direction of the NEMA - but there are a couple of different extruders we use, some geared, some not - so an adaptor to reverse the motor would be ideal for quick switching.
                      A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                        @elliott-griffiths so you'll do a relay hooked to the direction pin or something? interesting!
                        (but can you not use a through hole or surface mount 6-pin PH connector if you need a board anyway?)
                          dc42 administrators @elliott.griffiths
                          What's wrong with M569 ? Are you looking to use exactly the same config.g file with different extruders?
