After installing dual z stops heater gone
I added and now have working dual stops.
I changed the extruder from E0 to E1 and connected the second Z to E0
Now hot end heater no longer shows up
flashes on for half a second when config.g begins to load then goes away?
Is my tools command wrong and messing it up?; Heaters
M307 H0 B0 S1 ; disable bang-bang mode for the bed heater and set PWM limit
M307 H1 A748 C185.9 D11.3 V24.1 B0
M143 H1 S290 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D1 H1 F0 ; define tool 0
G10 P0 R0 S0 -
@drthomasw3 said in After installing dual z stops heater gone:
the hotend heater is normaly in thermostatic mode and will not shown in dwc (i think you mean this)
Yes previously it showed up as H1.
Now it flashes and is gone -
that is right so far, if you now heat your hotend the fan goes on at 45 degree
No Heater 1 is missing
sorry i was on the fan.... can you post your config g file
Configuration file for Duet WiFi (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 15:25:16 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Tronxy X5SA" ; set printer name;M667 S1 ; select CoreXY mode
M669 K1 ; select CoreXY mode
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss;DUAL Z
M584 X0 Y1 Z2:3 U3 E4 P3; Drives
M569 P0 S1 ; physical drive 0 goes forwards X
M569 P1 S1 ; physical drive 1 goes forwards Y
M569 P2 S0 ; physical drive 2 goes backwards z
M569 P3 S0 ; physical drive 3 goes backwards second z
M569 P4 S1 ; Drive 4 goes forwards ExtruderM350 X64 Y64 Z64 U64 E16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E439.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 U1 S1 ; set active high endstops
M558 P0 X0 Y0 Z0 H2 F60 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X15:300 Y15:300 S20 ; Define mesh grid; Heaters
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Network
M552 S1 ; enable network
M587 S Configure access point and IP addresses. You can delete this line once connected
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; Custom settings are not defined
M501 ; load saved parameters from non-volatile memory -
@drthomasw3 You still only have one extruder, so your tool definition should still be D0, not D1.
Sending M98 P”config.g” may also report this error.
You should remove the second “:16” from the E, as it’s trying to set microstepping for an extruder that doesn’t exist. Should be ignored by firmware, but sometimes causes problems.
Thanks to all changing the tool number worked!
