Ender 3 Pro - RRF 2.04 - can't get 12864 LCD to work
Thanks David - I guess that's a non-starter then. I truly didn't know that. I think I'll order a 128X64 RepRap LCD off Amazon for $12USD. Worth the investment just to see if these two particular Maestros really will drive a display.
So you weren't using the display that came with the Ender?
@Phaedrux , yes, I was making every attempt to get the OEM Ender display running, without success. I only just threw the other one into the mix to see if it might work. Wasn't aware that it is an entirely different sort of device. I just pulled it out of a box of Tevo Tarantula that was given to me, read the label that says RepRap...... so I tried it.
To reiterate, my stock Ender 3 Pro LCD doesn't work with ANY of the suggestions proffered thus far. I've meticulously followed your guide, been back over it several times, tried everything suggested in this thread - all to no avail.
I'll buy a RepRap display off Amazon to see what's up - I'll be doubly sure it is a 12864 device. If that doesn't work, then OK, its an ineffable mystery and I'll just continue using an old phone when I need to stand right in front of the machine for babystepping.
@ccluck how do the pins on the maestro LCD connector look?
they look OK to me, the connectors are snug when they go on, not loose or wiggly -
@ccluck ![alt text](image url )
This is the back side of the LCD board I'm trying to connect - not same as the one in the Duet_Ender3 guide, but it works fine with a Creality 1.14 board and the upgraded Creality "silent" 1.15 board connected to their single ten-pin (EXP1) connectors ( they don't have EXP2 or EXP3 ) Like I said earlier, I have two Maestros here, each easily accessible, so I've tried both with no luck. I must be missing some fundamental key to the puzzle, like it needs some other key besides the M918 enablement.
I'm wondering if the pinout on that LCD version is just different.
@Phaedrux , me too, but further investigations must wait. GF has persuaded me to take her out dancing at the biker bar out in the woods .... it'll be a nice break from the print room.
For all interested parties, I have news - the $12 RepRap Discount Full Graphic Smart Controller arrived today, and instantly worked as it should, no set up or monkey business required to get it going. Yahoo !
So there it is - there is at least one Ender OEM LCD variant out there that will not readily play with the Maestro.
Thanks to all who contributed advice and comments - I appreciate your time and attention to this little issue.
![alt text]( image url)
I am glad you got it working.
I changed the main menu files to suit my use.
Top left icon should be Duet3D's icon, next along on top row should be an image of a nozzle, next should be a bed icon last should be a fan icon.
Rem: is remaining time and bottom row to the right of CTRL should be % complete.Should look like this.
I was using firmware 2.04 and now RRF3 and works fine with my Maestro.
Maybe a connection issue....Regards,
Paul -
@PaulHew , thanks for your support - it is working as I had hoped. I was babystepping with it a few minutes ago. Very handy.
