mesh bed compensation not applying correct corrections
M671 x-60:353 Y140:140 S2 ; leadscrew at left (connected to z) and right (connected to
are you shure that your first leadscrew is on pos x-60 y 140
and the second is on x353 y140 ???if yes than the limits are wrong
; Axis Limits M208 X0 Y0 Z-1 S1 ; set axis minima M208 X295 Y277 Z275 S0
for example my working config with 3 leadscrews:
M671 X0:380:0 Y52:190:327 S3 F1.0; Leitspindeln links und rechts von der X-Achse
so the stated points are from the machine origin ie 00 the left leadscrew is to the left of the heat bed and the right leadscrew is to the right of the heat bed so the machine cant physically reach those points. should the m208 also have these figures in?
@necrorat said in mesh bed compensation not applying correct corrections:
No, M208 should define your reachable area. It's normal for the lead screws to be outside the print area. Your probe points should be as close as possible to the lead screws.
i dont think there should be a G29 S1 in the bed.g
M557 X23:270 Y9:265 P2 ; define mesh grid
P2 will not result in a usable mesh.
try S15
for the p parameter it was originally at 8 and behaved exactly the same. i am using two now to speed up iterations and to see if there is an improvement, so far the exactly the same behaviour despite the amount of probed points. as for the bed.g ill remove the G29 and see if that helps
@Phaedrux that was my understanding and have set them as such. the probe point is about 10mm in from the edge of the bed so as close as reasonably possible
one further question when taking the measurements for the where the leadscrews are positioned should i be taking the measurements from the nozzle or from the probe? (nozzle is 0,0)
I'm not sure I understand what you mean. The lead screws are fixed in relation to the bed, so their position is absolute. 0,0 is a point on the bed, the nozzle/probe/printhead is relative to that. The lead screw position would be relative to the 0,0 position in absolute coordinates.
Does that make sense?
@Phaedrux so when i home my machine the print head moves to 0,0 which lines up with the printer nozzle being in the bottom left corner. what i wanted to check is that the bed compensation calculations where been done relative to the nozzle not the probe as the probe is offset approximately 23mm from the nozzle. so the above values would of been off but after digging and as you said the calcs are done from the nozzle for all intensive purposes and that is how i have it configured at the moment.
so an update to the issue. spent all of this evening re checking that the machine is as square as reasonably possible and have levelled the bed to as close as i can get it to perfectly flat
but now when i go to load up the height map it gives me the error:
G29 S1
Error: G29: Failed to load height map from file heightmap.csv: failed to read line from fileat this point i dont really need mesh compensation as get ting very nice first layers without the mesh but for completions sake i want to get everything working as intended and iron out the few areas that are slightly more squashed than others on the first layer. should i try reducing the number of probed points to try and get it to accept the height map? or just any steers in the right direction would be highly appreciated.
Can you upload that Height map. CSV?
@Phaedrux heightmap.csv there you go mate, appreciate the help so far!
I don't see anything in particular wrong with that file. Try deleting it from the SD card and re-running G29
so deleted the file and reduced the number of probe points and it seems to of accepted the file now,but it still seems to be not applying the mesh correctly. there are inconstant very small gaps between the extruded lines in a couple of patches on the bed so that leads me to believe that something i have borked up in my config. ive checked my extrusion multiplier and calibrated my e steps so at this stage it must be something in my config or associated files.
that is either a problem with under extrusion or backlash in your printer. not a problem with mesh bed leveling.
@Veti 90% of the bed layer is perfect there are two patches where the gaps are observed so if it was under extrusion or backlash would it not be consistently like that all over the bed with mesh levelling working as it should?
post a picture
The image seems to show a bowed gantry. What areas are not touching the bed?
not the best pictures but best i can do at the moment.the main area is the region 3 threes what appears to be a island where the print head is too far from the bed
