Smoked y driver on Duet 2 wifi after swapping out a motor.
370
    Redheadrambo
    So I was having trouble with y-axis losing steps here and there so I upped the current to 900mA. Worked for a while but I decided to replace the motor with a slightly larger nema 17 that I had laying around. The new motor just vibrated so I figured I had the wires in the wrong order(they were). Fixed them and it still did the same thing and there was a grounding error on screen. Next I put a motor I know was good on the y driver. Smoke. Panic. Kill power.
    Now what do I do?
      A Former User
      Did you swap the order with power applied?
      In any case https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond should be your best bet to diagnose wihtout further damage (if possible)
        Redheadrambo
        Nope. Turned of power before pulling wires.
          A Former User
          Goodie, you should be able to safely work though the steps in wiki that states to do so wihtout Vin.
          Have you got a multimeter on hand?
            Redheadrambo
            yes I do
              Unfortunately, connecting a motor with the wires in wrong order does blow the driver sometimes. The reason is that the driver thinks it is applying a certain voltage to each phase, but in reality the voltages being applied are completely different. This results in very high peak currents. The short-circuit protection built into the driver, which RRF configures to maximum sensitivity, doesn't always kick in fast enough to protect the driver.
              undefined 1 Reply Last reply 3 Feb 2020, 23:44 Reply Quote 0
                Redheadrambo @dc42
                @dc42 Damn. Can I use the E1 driver for the y-axis then?
                undefined 1 Reply Last reply 3 Feb 2020, 23:54 Reply Quote 0
                  A Former User
                  yeah, wiki should get you going with the config
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                    droftarts administrators @Redheadrambo
                    @Redheadrambo said in Smoked y driver on Duet 2 wifi after swapping out a motor.:
                    Yes. Set motor driver direction for E1 with M569 (copy from existing Y motor), then change M584 to use E1 on Y. eg if you had this before:
                    M569 P0 S1 ; physical drive 0 goes forwards (X)
                    M569 P1 S0 ; physical drive 1 goes backwards (Y)
                    M569 P2 S1 ; physical drive 2 goes forwards (Z)
                    M569 P3 S1 ; physical drive 3 goes forwards (E0)
                    M584 X0 Y1 Z2 E3 ; Set drive mapping
                    Change to
                    ;M569 P1 S0 ; physical drive 1 goes backwards (Y) BROKEN!
                    M569 P4 S0 ; physical drive 4 goes backwards (E1, now Y)
                    M584 X0 Y4 Z2 E3 ; Set drive mapping
                    undefined 1 Reply Last reply 4 Feb 2020, 00:05 Reply Quote 1
                      Redheadrambo @droftarts
                      @droftarts Hey thanks a bunch I'll swap it over when I get home and be WAY more careful with this one.
                      1 out of 10
