    Duet wifi not showing up in device manager
    1.2k
    • 3DPrintingWorldundefined
      3DPrintingWorld @Phaedrux
      I have no switches connected. How do I check the reset?
        The erase and reset buttons are on the board along an edge. Tiny push buttons labeled.
        3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
          3DPrintingWorld
          Oh, sorry now I understand. I'll give it a try.
            A Former User
            Just asking the obvious, but it doesn't show up as a unkown device or under the USB device tree?
            (A picture (or screenshot) is worth a thousand words in these cases)
              3DPrintingWorld @A Former User
              No unknown devices in any category and nothing under the USB category or at least these values don't change when its plugged in.
              screen shot.png image url)
              • Danalundefined
                Danal
                Occasionally a given computer cannot supply enough power via USB. Connect a 12 or 24V supply to VIN (careful of polarity) and try again.
                  3DPrintingWorld @Danal
                  @Danal Supplying 24 volts did not seem to help...
                    @Phaedrux The reset button did not get it to work.
                      A Former User
                      It should be possible to get it running without the usb console, slightly trickier with the wifi than the ethernet/maestro.
                      But you should be able to edit the /sys/config.g file on the included SD card along with 11 herbs and spices to get connected. But if the usb port is borked might be better just getting it replaced.
                      (no, if the firmware was erased thats not gonna work, never mind)
                        Is it a genuine UK-manufactured Duet WiFi? If so then I suggest you ask for a warranty replacement. If you bought it direct from Duet3D, see https://www.duet3d.com/warranty and refer to this post as authorisation.
                          3DPrintingWorld @dc42
                          @dc42 Yes, and will do. Thanks DC!
                          • biomed27undefined
                            biomed27
                            This post is deleted!
                              Phaedrux Moderator @biomed27
                              @biomed27 Please keep it to a single thread.
