    Duet 3 6HC + Expanders in multi tool printer.
    My Duet controlled machine
    1.0k
    • Danalundefined
      Danal
      Status update:
      I've now fully wired tool 0, and extruder, to a Duet 3 expansion board. There was a small learning curve in naming conventions for RepRap 3. These were changed mostly to divorce fans/heaters/sensors into a new scheme that doesn't require a "virtual" (fake) heater to have a temperature sensor.
      Anyway, once I grasped the "board.port" naming, it was pretty simple to set up. And mostly "just works".
      The word "mostly" is from a few rough edges: Fans work but don't show up in Web, small things like that. All reported in separate threads.
      Here is an example of the configuration of temp/heaters/fans on main and expansion. Bed heater is 0, and on main board. Everything else is on expansion 1. You can see things like "0.temp0" and "1.temp0" for the zeroth-connector on the main and expansion board, respectively. Very straightforward once you see some examples.
      ; Temperature sensors
      M308 S0 P"0.temp0" Y"thermistor" T100000 B3950 A"Bed"
      M308 S1 P"1.temp0" Y"thermistor" T100000 B3950 A"Ex0"
      M308 S2 P"1.temp1" Y"thermistor" T100000 B3950 A"Ex1"
      M950 H0 C"0.out0" T0           ; Bed.  H = Heater 0, C is output for heater itself, T = Temperature sensor (defined above)
      M950 H1 C"1.out0" T1           ; Heater for extruder out tool 0
      M950 H2 C"1.out1" T2           ; Heater for extruder out tool 1
      ; Fans for hot end cooling
      M950 F10 C"1.out6"
      M106 P10 S255 H1 T45       ; S = Speed of fan Px, Hxx = heater for thermo mode, T = temps for thermo mode.
      M950 F11 C"1.out7"
      M106 P11 S255 H2 T45      ; S = Speed of fan Px, Hxx = heater for thermo mode, T = temps for thermo mode.
      ; Fans for print cooling
      M950 F0 C"1.out3"
      M950 F1 C"1.out4"
      • Danalundefined
        Danal
        A temporary mounting point for the expansion board while I decide where to permanently mount it. Thats why the CAN and Power wires are just sort of dangling.
        One pic shows the board better; the other the board plus the tool (which is parked).
        Red Sand Robotundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal
          Oh, and I just noticed I had yet to hook up the motor and one of the fans in these pics. They are all hooked up now.
            dc42 administrators @Danal
            @Danal said in Duet 3 6HC + Expanders in multi tool printer.:
            It was also to support heaters and more particularly fans controlled by sensors not on the same board as the heater or fan.
            • Red Sand Robotundefined
              Red Sand Robot @Danal
              @Danal Are you anticipating any degradation of the printed parts connecting the bed to the leadscrew and linear rail?
              From what I've seen of the design of the Jubilee bed platform it seems like there would be heat directly transferred from the bed, through the metal balls, to the dowel pins, and to the printed part. If they are made of PLA and you raise the bed to temperatures suitable for ABS or PETG I would think that deformation would start to occur.
              That's just what my initial thoughts were though, in practice it might not be even noticeable.
              almost an engineer
              • Danalundefined
                Danal @Red Sand Robot
                @Red-Sand-Robot Interesting point, and the "proof is in the pudding" so to speak. I will keep an eye on it.
                Having said that, I'm thinking that common bed temperatures, 80, 90, things like that, are extremely unlikely to be a problem along that heat path. No math or engineering behind that thought, just gut feel.
                If the printer were to end up in a heated enclosure, I'd print the parts out of something, perhaps Polycarbonate, that is better than PLA.
                  @Danal I only bring that up because on my custom Prusa style machine, my Y carriage plate is aluminum and does get noticeably hot when printing around 80-90, and since the heat transfer through air is basically non existent it must therefore be transferring from the screws attaching the heated bed to the Y carriage.
                  When I saw that the heated bed was placed directly on top of a PLA part that was my first concern. An easy fix would definitely be reprinting in polycarbonate, ABS/ASA, or maybe even SLS printed from nylon.
                  almost an engineer
                  • Danalundefined
                    Danal
                    First prints. Single tool. The bed is still not really coupled into its kinematic coupling properly. Still, pretty good results.
                    Experimenting with mounting expansion boards on the sides. CAN bus is a huge enabler for this. Forgive the dangling wires; I will clean them up if this turns out to be a good place for the expander.
                    Movement and toolchange steppers on base board, limit switches on base, bed heater and temp on base; all fans, heaters, extruder motors, etc, etc, for the tool are on expansion board 1. Board 1 will soon get the second tool.
                    • Danalundefined
                      Danal
                      I ran with the expansion board on the side for quite some time... and... it is finally time to put the boards where they belong, and re-wire the tools. This will help the multiple tools wiring bundles not drag each other around.
                      Overall layout.
                      Mounted on the back of the printer. Main board is wired, expansions not yet.
                      • tobias_munichundefined
                        tobias_munich
                        thanks for sharing!
                        I like this project and I guess this could be my next project too!
                        Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                        Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                        Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                          Thanks for sharing! How may tools do you intend to use eventually?
                          • Danalundefined
                            Danal @dc42
                            @dc42 said in Duet 3 6HC + Expanders in multi tool printer.:
                            Four will fit nicely in this chassis. Since the 6HC is fully occupied with no tools, I'm putting two tools on each expansion, just for symmetry.
                            At some point, I may rebuild and go a touch larger. With the base and two expansions, six tools would make a lot of sense.
                              jay_s_uk
                              I'm planning on 6 tools on my build once I get round to ordering a second 3HC
                                dc42 administrators @jay_s_uk
                                @jay_s_uk said in Duet 3 6HC + Expanders in multi tool printer.:
                                Don't forget that we have tool boards in the pipeline, which will be available to order very soon! Perfect for Hemera direct drive extruders.
                                  jay_s_uk
                                  I haven't forgotten. I was very impressed by them at TCT when I saw them.
                                  My long term goal is all Hemeras with toolboards but that will take time
