    RepRapFirmware 3.01-beta 3 released
    Beta Firmware
    11
    56
    3.4k
      Those M307 commands for non-existent heaters are probably in config-override.g and were put there by RRF2. You can delete them.
      • zerspaner_gerdundefined
        zerspaner_gerd
        I am currently looking for the endstop inputs of E0 (e0stop) and E1 (e1stop)
        M409 K"sensors.endstops" F"v" shows only three
        Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
          dc42 administrators @zerspaner_gerd
          @zerspaner_gerd said in RepRapFirmware 3.01-beta 3 released:
          The sensors.endstops variable only reports inputs configured as endstops. I need to add a separate section for other inputs.
          Possible temporary workaround: create two additional axes e.g. U and V, and hide them using the M584 P parameter. Then you can assign those two endstop inputs to those axes using M574, and then they should be visible in sensors.endstops.
          zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
            zerspaner_gerd @dc42
            Thank you
            @dc42 said in RepRapFirmware 3.01-beta 3 released:
            The axes must be visible so that one can see the end stop.
            But I can continue to play with it
              I'll change it in the next build to include endstops for invisible axes.
                zerspaner_gerd
                Somehow I came across strange things, here are my examples
                Trigger 2 is triggered permanently
                Trigger 1 is confirmed with a finger
                Loop does not work:
                G28 X Y
                G0 X10 Y200 F1000
                M400
                M18 X Y
                M400
                while sensors.endstops[2].triggered	; == false
                	;echo "sensor wakü", sensors.endstops[2].triggered
                	; M291 P"TEST1234" R"TEST" S2
                	if sensors.endstops[1].triggered
                		abort "TEST abort"
                echo "ENDE"
                The loop works with the following code:
                G28 X Y
                G0 X10 Y200 F1000
                M400
                M18 X Y
                M400
                		abort "TEST abort"
                M400
                echo "ENDE"
                But the abort function does not work, the printing is not canceled
                With this code the abort function works
                G28 X Y
                G0 X10 Y200 F1000
                M400
                M18 X Y
                M400
                		break
                M400
                	abort "TEST abort"
                The abort function only seems to work if it is at the very end of the file.
                (Also works in a macro as soon as it is at the end of the macro)
                Could someone test this on their Duet?
                  I have tested this slightly modified version on my Duet WiFi powered delta running 3.01beta3:
                  G28
                  G1 Z350 F6000
                  M400
                  while !sensors.endstops[0].triggered	; == false
                  		abort "TEST abort"
                  M400
                  echo "ENDE"
                  I invoke it from within a print file, and it works as it should. It homes the printer, goes down, then waits for me to trigger the X endstop. If I am not holding the Y endstop down when i do that, it carries on printing and echoes ENDE. If I am holding down the y endstop at that time, it aborts the print and echoes TEST abort.
                    zerspaner_gerd
                    It's different with me, Duet2 Wiffi. This time also called from a print file.
                    Your mentioned variant does not happen to me, printing is successfully completed. The macro file is only canceled.
                    With "abort" at the end of the file, the printing movements are stopped, but the printer status remains "Printing/Processing"
                    Sometimes only an emergency stop helps, sometimes I can use "Pause Print" and then "Cancel Print" to escape the "Printing/Processing" status
                    Signature is up to date (firmware version, etc.)
                      zerspaner_gerd
                      The tool status (tools[0].state) appears to no longer be updated to off.
                      When starting, off is displayed, but once active, off is no longer displayed.
                      Only with me or can someone reproduce that
                        Please check whether you still have these 2 issues using the new binary at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                        • oliofundefined
                          oliof
                          I just tried PID tuning my hotend and while M307 H1 shows a result, M500 does not save a valid line to config-override.g
                          System info:
                          2/6/2020, 10:42:50 PM	M115
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0
                          FIRMWARE_VERSION: 3.01-beta3
                          ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-29b1
                          command run to do the PID tuning
                          M303 H1 S260
                          Log entries on the console
                          2/6/2020, 10:28:13 PM	Auto tuning heater 1 using target temperature 260.0°C and PWM 1.00 - do not leave printer unattended
                          2/6/2020, 10:28:19 PM	Auto tune phase 1, heater on
                          2/6/2020, 10:30:43 PM	Auto tune phase 2, heater off
                          2/6/2020, 10:30:49 PM	Auto tune phase 3, peak temperature was 265.0
                          2/6/2020, 10:34:31 PM	Auto tune heater 1 completed in 378 sec
                          Use M307 H1 to see the result, or M500 to save the result in config-override.g
                          2/6/2020, 10:35:57 PM	M307 H1
                          Heater 1 model: gain 545.6, time constant 241.1, dead time 4.6, max PWM 1.00, calibration voltage 24.1, mode PID
                          Computed PID parameters for setpoint change: P17.0, I0.510, D55.2
                          Computed PID parameters for load change: P17.0, I1.201, D55.2
                          2/6/2020, 10:36:07 PM	M500
                          contents of config-override.g
                          ; config-override.g file generated in response to M500 at 2020-02-06 22:36
                          ; Heater model parameters
                          M307 H0 A C D S V B0
                          M307 H1 A C D S V B0
                          ; Workplace coordinates
                          I also noted that the thermostatic hotend cooling fan runs always, here is the configuration for heaters and fans as by the reprap configurator:
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                          M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                          M307 H0 B1 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                               ; map heated bed to heater 0
                          M308 S1 P"temp1" Y"thermistor" T100000 B4138          ; configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
                          M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                          M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                          M950 F0 C"out3" Q500                                  ; create fan 0 on pin out3 and set its frequency
                          M106 P0 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"out4" Q500                                  ; create fan 1 on pin out4 and set its frequency
                          M106 P1 S1 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
                          M950 F2 C"out5" Q500                                  ; create fan 2 on pin out5 and set its frequency
                          M106 P2 S1 H-1                                        ; set fan 2 value. Thermostatic control is turned off
                            dc42 administrators @oliof
                            @oliof said in RepRapFirmware 3.01-beta 3 released:
                            That's a known DSF issue, affecting Duet 3 + RPi users.
                            • oliofundefined
                              oliof
                              And interestingly enough, moving the fan from out4 to out7 made thermostatic control work.
                                • All endstop inputs are visible, including the hidden ones 👍
                                • "abort / while" I could not find any change
                                  Print movements are stopped, but the printer status remains printing
                                  And "while" only works as expected with M400
                                • Status tool is not yet correct
                                  After once on active/standby
                                  @zerspaner_gerd, I can reproduce that issue now, although it's slightly different: the status is still Printing, but there is no abort message on the console. I will look into it.
                                    This issue ('abort' command left status as 'printing') is fixed in release 3.01RC1, which I hope to make available later today.
                                    Tool states and heater states are distinct. In particular, a tool may be in Standby but its heaters may have been turned off.
                                    • DaBitundefined
                                      DaBit
                                      Is if ... continue already implemented?
                                      I am toying around a little with the conditional code:
                                      while iterations < 10
                                      	echo "Curent tool temp " ^ heat.sensors[tools[state.currentTool].heaters[0]].lastReading
                                      	M98 P"wipe.g"
                                              G4 S5
                                      	if heat.sensors[tools[state.currentTool].heaters[0]].lastReading < {tools[state.currentTool].active[0]-2.0}
                                      		continue
                                      	if heat.sensors[tools[1].heaters[0]].lastReading > {heat.coldExtrudeTemperature < tools[1].standby[0] ? tools[1].standby[0] : heat.coldExtrudeTemperature}
                                      		continue
                                      	break
                                      And it seems I need to split all the conditions a little, otherwise the while() condition becomes very long. 'continue' and 'break' would work, but I am getting an 'Error: Bad command: continue'
                                        I have fixed 'continue' in 3.01-RC1 too.
                                          Now that RRF 3.01-RC1 is released, I am locking this thread.
