RepRapFirmware 3.01-beta 3 released
Beta Firmware
11
56
3.2k
    zerspaner_gerd @dc42
    Thank you
    @dc42 said in RepRapFirmware 3.01-beta 3 released:
    and hide them using the M584 P parameter.
    The axes must be visible so that one can see the end stop.
    But I can continue to play with it
    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
      I'll change it in the next build to include endstops for invisible axes.
        zerspaner_gerd
        Somehow I came across strange things, here are my examples
        Trigger 2 is triggered permanently
        Trigger 1 is confirmed with a finger
        Loop does not work:
        G28 X Y
        G0 X10 Y200 F1000
        M400
        M18 X Y
        M400
        while sensors.endstops[2].triggered ; == false
        ;echo "sensor wakü", sensors.endstops[2].triggered
        ; M291 P"TEST1234" R"TEST" S2
        if sensors.endstops[1].triggered
        abort "TEST abort"
        echo "ENDE"
        The loop works with the following code:
        G28 X Y
        G0 X10 Y200 F1000
        M400
        M18 X Y
        M400
        abort "TEST abort"
        M400
        echo "ENDE"
        But the abort function does not work, the printing is not canceled
        With this code the abort function works
        G28 X Y
        G0 X10 Y200 F1000
        M400
        M18 X Y
        M400
        break
        M400
        abort "TEST abort"
        The abort function only seems to work if it is at the very end of the file.
        (Also works in a macro as soon as it is at the end of the macro)
        Could someone test this on their Duet?
          I have tested this slightly modified version on my Duet WiFi powered delta running 3.01beta3:
          G28
          G1 Z350 F6000
          M400
          while !sensors.endstops[0].triggered ; == false
          abort "TEST abort"
          M400
          echo "ENDE"
          I invoke it from within a print file, and it works as it should. It homes the printer, goes down, then waits for me to trigger the X endstop. If I am not holding the Y endstop down when i do that, it carries on printing and echoes ENDE. If I am holding down the y endstop at that time, it aborts the print and echoes TEST abort.
            zerspaner_gerd
            It's different with me, Duet2 Wiffi. This time also called from a print file.
            Your mentioned variant does not happen to me, printing is successfully completed. The macro file is only canceled.
            With "abort" at the end of the file, the printing movements are stopped, but the printer status remains "Printing/Processing"
            Sometimes only an emergency stop helps, sometimes I can use "Pause Print" and then "Cancel Print" to escape the "Printing/Processing" status
            Signature is up to date (firmware version, etc.)
              zerspaner_gerd
              The tool status (tools[0].state) appears to no longer be updated to off.
              When starting, off is displayed, but once active, off is no longer displayed.
              Only with me or can someone reproduce that
                Please check whether you still have these 2 issues using the new binary at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                undefined 1 Reply Last reply 7 Feb 2020, 00:59 Reply Quote 0
                  oliof
                  I just tried PID tuning my hotend and while M307 H1 shows a result, M500 does not save a valid line to config-override.g
                  System info:
                  2/6/2020, 10:42:50 PM	M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0
                  FIRMWARE_VERSION: 3.01-beta3
                  ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-29b1
                  command run to do the PID tuning
                  M303 H1 S260
                  Log entries on the console
                  2/6/2020, 10:28:13 PM	Auto tuning heater 1 using target temperature 260.0°C and PWM 1.00 - do not leave printer unattended
                  2/6/2020, 10:28:19 PM	Auto tune phase 1, heater on
                  2/6/2020, 10:30:43 PM	Auto tune phase 2, heater off
                  2/6/2020, 10:30:49 PM	Auto tune phase 3, peak temperature was 265.0
                  2/6/2020, 10:34:31 PM	Auto tune heater 1 completed in 378 sec
                  Use M307 H1 to see the result, or M500 to save the result in config-override.g
                  2/6/2020, 10:35:57 PM	M307 H1
                  Heater 1 model: gain 545.6, time constant 241.1, dead time 4.6, max PWM 1.00, calibration voltage 24.1, mode PID
                  Computed PID parameters for setpoint change: P17.0, I0.510, D55.2
                  Computed PID parameters for load change: P17.0, I1.201, D55.2
                  2/6/2020, 10:36:07 PM	M500
                  contents of config-override.g
                  ; config-override.g file generated in response to M500 at 2020-02-06 22:36
                  ; Heater model parameters
                  M307 H0 A C D S V B0
                  M307 H1 A C D S V B0
                  ; Workplace coordinates
                  I also noted that the thermostatic hotend cooling fan runs always, here is the configuration for heaters and fans as by the reprap configurator:
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                  M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                  M307 H0 B1 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                               ; map heated bed to heater 0
                  M308 S1 P"temp1" Y"thermistor" T100000 B4138          ; configure sensor 1 as thermistor on pin temp1
                  M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
                  M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                  M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"out3" Q500                                  ; create fan 0 on pin out3 and set its frequency
                  M106 P0 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"out4" Q500                                  ; create fan 1 on pin out4 and set its frequency
                  M106 P1 S1 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"out5" Q500                                  ; create fan 2 on pin out5 and set its frequency
                  M106 P2 S1 H-1                                        ; set fan 2 value. Thermostatic control is turned off
                  undefined 1 Reply Last reply 6 Feb 2020, 22:34 Reply Quote 0
                    dc42 administrators @oliof
                    @oliof said in RepRapFirmware 3.01-beta 3 released:
                    That's a known DSF issue, affecting Duet 3 + RPi users.
                      oliof
                      And interestingly enough, moving the fan from out4 to out7 made thermostatic control work.
                        • All endstop inputs are visible, including the hidden ones 👍
                        • "abort / while" I could not find any change
                          Print movements are stopped, but the printer status remains printing
                          And "while" only works as expected with M400
                        • Status tool is not yet correct
                          After once on active/standby
                          @zerspaner_gerd, I can reproduce that issue now, although it's slightly different: the status is still Printing, but there is no abort message on the console. I will look into it.
                            This issue ('abort' command left status as 'printing') is fixed in release 3.01RC1, which I hope to make available later today.
                            Tool states and heater states are distinct. In particular, a tool may be in Standby but its heaters may have been turned off.
                              DaBit
                              Is if ... continue already implemented?
                              I am toying around a little with the conditional code:
                              while iterations < 10
                              echo "Curent tool temp " ^ heat.sensors[tools[state.currentTool].heaters[0]].lastReading
                              M98 P"wipe.g"
                              G4 S5
                              if heat.sensors[tools[state.currentTool].heaters[0]].lastReading < {tools[state.currentTool].active[0]-2.0}
                              continue
                              if heat.sensors[tools[1].heaters[0]].lastReading > {heat.coldExtrudeTemperature < tools[1].standby[0] ? tools[1].standby[0] : heat.coldExtrudeTemperature}
                              continue
                              break
                              And it seems I need to split all the conditions a little, otherwise the while() condition becomes very long. 'continue' and 'break' would work, but I am getting an 'Error: Bad command: continue'
                                I have fixed 'continue' in 3.01-RC1 too.
                                  Now that RRF 3.01-RC1 is released, I am locking this thread.
                                  50 out of 56
