    RepRapFirmware 3.01-beta 3 released
    Beta Firmware
    11
    56
    3.4k
      Please check whether you still have these 2 issues using the new binary at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
      zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
      • oliofundefined
        oliof
        I just tried PID tuning my hotend and while M307 H1 shows a result, M500 does not save a valid line to config-override.g
        System info:
        2/6/2020, 10:42:50 PM	M115
        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0
        FIRMWARE_VERSION: 3.01-beta3
        ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-29b1
        command run to do the PID tuning
        M303 H1 S260
        Log entries on the console
        2/6/2020, 10:28:13 PM	Auto tuning heater 1 using target temperature 260.0°C and PWM 1.00 - do not leave printer unattended
        2/6/2020, 10:28:19 PM	Auto tune phase 1, heater on
        2/6/2020, 10:30:43 PM	Auto tune phase 2, heater off
        2/6/2020, 10:30:49 PM	Auto tune phase 3, peak temperature was 265.0
        2/6/2020, 10:34:31 PM	Auto tune heater 1 completed in 378 sec
        Use M307 H1 to see the result, or M500 to save the result in config-override.g
        2/6/2020, 10:35:57 PM	M307 H1
        Heater 1 model: gain 545.6, time constant 241.1, dead time 4.6, max PWM 1.00, calibration voltage 24.1, mode PID
        Computed PID parameters for setpoint change: P17.0, I0.510, D55.2
        Computed PID parameters for load change: P17.0, I1.201, D55.2
        2/6/2020, 10:36:07 PM	M500
        contents of config-override.g
        ; config-override.g file generated in response to M500 at 2020-02-06 22:36
        ; Heater model parameters
        M307 H0 A C D S V B0
        M307 H1 A C D S V B0
        ; Workplace coordinates
        I also noted that the thermostatic hotend cooling fan runs always, here is the configuration for heaters and fans as by the reprap configurator:
        M308 S0 P"temp0" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
        M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
        M307 H0 B1 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                               ; map heated bed to heater 0
        M308 S1 P"temp1" Y"thermistor" T100000 B4138          ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
        M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
        M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
        M950 F0 C"out3" Q500                                  ; create fan 0 on pin out3 and set its frequency
        M106 P0 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"out4" Q500                                  ; create fan 1 on pin out4 and set its frequency
        M106 P1 S1 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"out5" Q500                                  ; create fan 2 on pin out5 and set its frequency
        M106 P2 S1 H-1                                        ; set fan 2 value. Thermostatic control is turned off
          dc42 administrators @oliof
          @oliof said in RepRapFirmware 3.01-beta 3 released:
          That's a known DSF issue, affecting Duet 3 + RPi users.
          • oliofundefined
            oliof
            And interestingly enough, moving the fan from out4 to out7 made thermostatic control work.
            • zerspaner_gerdundefined
              zerspaner_gerd @dc42
              @dc42 said in RepRapFirmware 3.01-beta 3 released:
              • All endstop inputs are visible, including the hidden ones 👍
              • "abort / while" I could not find any change
                Print movements are stopped, but the printer status remains printing
                And "while" only works as expected with M400
              • Status tool is not yet correct
                After once on active/standby
              Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                @zerspaner_gerd, I can reproduce that issue now, although it's slightly different: the status is still Printing, but there is no abort message on the console. I will look into it.
                  This issue ('abort' command left status as 'printing') is fixed in release 3.01RC1, which I hope to make available later today.
                  Tool states and heater states are distinct. In particular, a tool may be in Standby but its heaters may have been turned off.
                  • DaBitundefined
                    DaBit
                    Is if ... continue already implemented?
                    I am toying around a little with the conditional code:
                    while iterations < 10
                    	echo "Curent tool temp " ^ heat.sensors[tools[state.currentTool].heaters[0]].lastReading
                    	M98 P"wipe.g"
                            G4 S5
                    	if heat.sensors[tools[state.currentTool].heaters[0]].lastReading < {tools[state.currentTool].active[0]-2.0}
                    		continue
                    	if heat.sensors[tools[1].heaters[0]].lastReading > {heat.coldExtrudeTemperature < tools[1].standby[0] ? tools[1].standby[0] : heat.coldExtrudeTemperature}
                    		continue
                    	break
                    And it seems I need to split all the conditions a little, otherwise the while() condition becomes very long. 'continue' and 'break' would work, but I am getting an 'Error: Bad command: continue'
                      I have fixed 'continue' in 3.01-RC1 too.
                        Now that RRF 3.01-RC1 is released, I am locking this thread.
