    Help with new config.g
    858
    • kmhudginsundefined
      kmhudgins
      this is what the config.g looks like at moment
      M550 P"My Printer" ; set printer name
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M350 E256 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z4000.00 E6984.63 ; set steps per mm
      M84 S30 ; Set idle timeout
      M208 X230 Y230 Z260 S0 ; set axis maxima
      M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X36.7 Y6 Z2.5 ; set Z probe trigger value, offset and trigger height
      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
        kmhudgins
        I have ran the config tool 18 times now trying to figure out what im doing wrong and at this point i have no clue every time something goes wrong. At this point the bltouch will not run it start up test. I followed the link DIY-O-Sphere posted earlier in the post and made sure i matched my config tool settings to the images provided and still nothing is working. I would be VERY happy if ANYONE can shed some light on whats going on. Everything worked befor I updated.
        I have an ender 3 with a duet meastro, bltouch and a fused3d bed that has a NTC100K thermistor.
        The most recent config is below.
        Thanks for the help.
        M350 X16 Y16 Z16 E128 I1 ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z4000.00 E741.00 ; set steps per mm
        M566 X600.00 Y600.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E5000.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
        M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        M308 S1 P"e0temp" Y"thermistor" T98801 B4138 ; configure sensor 1 as thermistor on pin e0temp
        • DIY-O-Sphereundefined
          DIY-O-Sphere
          @kmhudgins said in Help with new config.g:
          M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch
          (UTC+1)
            dc42 administrators @DIY-O-Sphere
            @DIY-O-Sphere said in Help with new config.g:
            Not quite, you need the ^ in front of zprobe.in. Also, in RRF3.0 you need to put the M558 command before the M950 command, because the default Z probe uses pin "zprobe.mod" as well as "zprobe.in". In RRF 3.01 it doesn't matter, because there is no default Z probe.
            M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            This is all documented at https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3.
            DIY-O-Sphereundefined kmhudginsundefined 2 Replies Last reply Reply Quote 0
              DIY-O-Sphere @dc42
              @dc42 said in Help with new config.g:
              That's a Maestro!
              (UTC+1)
                That's a Maestro!
                Yes, as @kmhudgins said he is using.
                You need the ^ in front of zprobe.in for any Duet 2 running RRF3 with a recent version BLTouch. This is because recent versions of BLTouch have open-drain outputs.
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  DIY-O-Sphere @dc42
                  Thank you for clarification. Now I am clear about why my BLT 2.0.... works without pullup (^)
                  Maybe a note in the wiki guide about the different versions of BLT would be helpful.
                  (UTC+1)
                    kmhudgins @dc42
                    Thank you for the help
                    I made this change to the config.g but it did not change anything. the bltouch shill wont run the start up test and therefor just has a blinking red light.
                      DIY-O-Sphere
                      @kmhudgins
                      Have you replaced all files in sys folder? Or only the config.g?
                      Have you checked the version of your BLTouch?
                      You can check the probe by sending:
                      M280 P0 S120
                      For RRF3 the deployprobe.g and retractprobe.g have to be modified.
                      (UTC+1)
                        kmhudgins
                        this is the code that seems to work.
