    BLTouch probe malfunction and Z stepper warning
    477
    • HowardTheDuckundefined
      HowardTheDuck @Phaedrux
      @Phaedrux yes:
      Firmware Version: 3.0 (2020-01-03b3)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
        Could you copy and paste the bltouch section of the config?
        Also you should be using dwc 2.0.7 with rrf3
        HowardTheDuckundefined 1 Reply Last reply Reply Quote 0
          Also for the z axis error check your wiring. The error may be telling you exactly what's wrong.
            @Phaedrux
            M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
            M558 P9 C"^zprobe.in" H5 F100 T2000 ; Set Z Probe to type BLTouch
            M950 S0 C"exp.heater3"
            G31 X0 Y0 Z3.3 P25 ; Set Z probe trigger value, offset and trigger height
            M557 X20:200 Y20:200 S40 ; define mesh grid
            • aidarundefined
              aidar
              I think you should use Z0 in M574 command. Look at : https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                The first thing is to check whether the M401 and M402 commands deploy and retract the pin. Do they?
                  HowardTheDuck @aidar
                  @aidar thanks, I've changed it, but that doesn't appear to have done anything
                    HowardTheDuck @dc42
                    @dc42 M401 and M402 commands work as expected.
                      Please post your homing files.
                        @Phaedrux That Z axis error regarding the motor phase was indeed a faulty connection, it's been repaired. Thank you.
                        The home files are below. FYI, I have not altered these; when I do a home all, it pushes the bed all the way back in the Y axis to home it, which leaves the bed well behind the Z axis probe. So after homing X and Y, it moves the Z down, but the bed is no longer under the Z probe. I suppose I'll need to add something to move the bed forward again after the Y axis is homed; my bigger problem is that the pin on the Z probe doesn't extend.
                        homeall.g
                        homex.g
                        homey.g
                        homez.g
                          The reason the pin isn't extending is because your homeall.g and homez.g are configured to use an endstop switch and not the probe.
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 15:52:13 GMT-0500 (Eastern Standard Time)
                          G1 H2 Z5 F6000          ; lift Z relative to current position
                          G1 H1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 H2 X5 Y5 F6000       ; go back a few mm
                          G1 H1 X-258 Y-235 F360  ; move slowly to X and Y axis endstops once more (second pass)
                          G1 H1 Z-245 F360        ; move Z down stopping at the endstop
                          G90                     ; absolute positioning
                          G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                          It should be
                          ; homeall.g
                          G1 X150 Y150 F6000 ; move the probe to the center of the bed. Adjust as needed.
                          G30 ; probe the bed
                          G1 X5 Y5 Z5 F6000 ; return to a parked position
                          For homez you have
                          ; homez.g
                          ; called to home the Z axis
                          G1 H1 Z-245 F1800 ; move Z down until the endstop is triggered
                          But you should have
                          ; homez.g
                          G30 ; probe the bed
                          Notice that it now positions the probe at the center of the bed and then sends G30 to actually use the probe. Then returns to a position off to the side. You'll have to modify the probing position and the parking position to suit your needs.
                            @Phaedrux Thank you, that got it working!
