    Large Delta printer not homing on an original duet Maestro
    Example setups and prints
    2.2k
    • Danalundefined
      Danal @NEVER LUCKY
      @NEVER-LUCKY said in Large Delta printer not homing on an original duet Maestro:
      all i have is 2 red LEDs next to the usb port and a green and red LED lit, and no connection.
      Again, it will not connect until:
      1. You verify the port appears/disappears when you plug/unplug. Use device manager.
      2. You configure it for LF line ends and more. See the link above.
        Did something get shorted potentially during the rewiring of the endstops? Is all of the wiring still in place?
        If following the YAT configuration linked above doesn't change anything, try disconnecting everything except USB. If that still doesn't work, connect the power supply for VIN as well.
        • NEVER LUCKYundefined
          NEVER LUCKY
          the port appears and disappears in device manager.
          it was already configured for LF.
          after unplugging, still nothing.
          after using VIN also nothing
            Just to remove YAT from the equation, can you try with pronterface? https://www.pronterface.com/
            The fact that it appears and disappears is a good sign. At least it's being detected by windows.
            The same windows USB stuff also applies. Try a different port. Reboot the PC. Try a USB hub.
              When you reboot the Duet, the port will disappear for a few moments and YAT will disconnect. So you may need to press Open/Connect button again. If that doesn't work, go to Settings in YAT and check that the port is still recognised. Restart YAT if you need to.
                NEVER LUCKY
                the port is perfectly fine, the board just doesnt reply to my messages, makes me sad 😞
                I installed pronterface and im not familiar with it at all
                  Phaedrux Moderator @NEVER LUCKY
                  There's a dropdown to select the USB port to connect to. You connect if possible and then you hopefully can send some commands from the console.
                    NEVER LUCKY
                    omg now it isnt online
                    device manager shows the port as port 11
                      What else shows in the port drop down?
                        NEVER LUCKY
                        nothing
                          Alright, start working through this page
                          https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
                            If it's showing the Bossa port then you have erased the firmware. Use the Bossa program to reinstall it. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3.
                              NEVER LUCKY
                              this is embarrassing what is the g code for inserting sd card again?
                              • Danalundefined
                                Danal
                                Power off whenever inserting or removing SD.
                                  You can also use M21 and M22 to load and eject the SD card.
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M21_Initialize_SD_card
                                  • Danalundefined
                                    Danal
                                    Well, I learn something every day! Thanks @Phaedrux
                                      NEVER LUCKY
                                        NEVER LUCKY
                                        ill wire things up and test if i can connect the web interface
                                          That's a really good sign.
                                            NEVER LUCKY
                                            so i wired everything up and checked the endstops. it looks kinda good i guess.
                                            After i pressed HOME ALL, the axes did what they were supposed to.
                                            I want to thank all three of you guys for staying up this late and helping me figure this out and also for not giving up when i had no idea what could be done otherwise.
                                            cheers lads and thanks so much.
                                            @Danal @dc42 @Phaedrux
