    Strange values on E0 temp, and bed not heating up.
    639
    • Vetiundefined
      Veti
      500-600 means there is a short.
      its reading very little resistance
      also B4138 is incorrect for your thermistor.
      SoDamnInsaneundefined 1 Reply Last reply Reply Quote 0
      • SoDamnInsaneundefined
        SoDamnInsane @Phaedrux
        @Phaedrux said in Strange values on E0 temp, and bed not heating up.:
        Was that generated by the web configurator tool?
        Thx for the quick answer.. Yes it was generated by the web configurator.
          SoDamnInsane @Veti
          @Veti said in Strange values on E0 temp, and bed not heating up.:
          Thanks for the quick answer...
          Ok, do you maybe know what value i've to use?
          Maybe a stupid question.
          But when i measure the resistance of the thermistor, it's about 120 KOhm... But when i installed it at the nozzle, the resistance is almost 0...... Is this normal?
          Thanks in advance!
          Vetiundefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti @SoDamnInsane
            @SoDamnInsane said in Strange values on E0 temp, and bed not heating up.:
            that means there is damage to the thermistor.
            the insulation is broken, creating a short.
            • Vetiundefined
              Veti @SoDamnInsane
              which exact model of thermistor are you using?
                dc42 administrators @Veti
                Or, if it's the bead type of thermistor (not the modern cartridge type), when you fit the screw with the washer over the thermistor leads to hold it in place, one of the leads is shorting against the heater block.
                  SoDamnInsane @Veti
                  @Veti I use a 100 k ohm NTC 3950 Thermistor.
                  A friend told me that the correct value should be: B3950.... ?
                    SoDamnInsane @dc42
                    @dc42 said in Strange values on E0 temp, and bed not heating up.:
                    Thx. That's what i thought too. But it was a brand new and complete E3D set. So everything was already installed..
                    I measured the resistance, it was about 120 KOhm...
                    And after connected to the mainboard, it was almost 0 Ohm..... Strange, isn't it?
                    AND... this was the 2nd one... The first had the same problem...
                      SoDamnInsane
                      This post is deleted!
                        SoDamnInsane
                        Update:
                        After installing a 3rd brand new thermistor, de extruder is heating up, and reads normal values. 😌
                        Next problem. (I've several issues.. 🤔 )
                        When i heat the bed, it starts heating up... but only for about 8 a 10 seconds..
                        Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @SoDamnInsane
                          @SoDamnInsane have you PID tuned the bed yet?
                            Thanks, @Phaedrux for the quick response..
                            When I had Marlin firmware, I did.
                            But I now see so many settings related to the heatbed that I don't know what to do anymore ... Sorry, noob. LOL
                            I used the web configurator to play safe.
                            Below are the current settings ...
                            I would be eternally grateful if I could finally use my printer after 4 weeks ... haha;)
                            I still have 1 problem after that, but that will come later ...;)
                              droftarts administrators @SoDamnInsane
                              @SoDamnInsane You need to tune your heater settings with M303. For full details see: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                              Your heater settings are set to the default.
                              M307 H0 B0 S1.00
                              M307 H1 B0 S1.00
                              You need to tune your heaters, with something like:
                              M303 H0 S60
                              M303 H1 S200
                              Run them each a number of times (usually 3 times is enough), but wait for the heater to be at room temperature before doing it again. Once the results converge, send M500 to save them to config-override.g
                              Then either add M501 to the end of config.g so they load from config-override.g, or copy the heater settings to config.g, replacing the default values for M307.
                              You can check the current heater settings by sending M307 H0 or M307 H1 from the console.
                                You can follow this step by step as well.
                                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
                                In fact that whole guide series might be helpful for you.
                                  @SoDamnInsane Also, when posting your config.g, it's best to copy the text of the config.g into your post, rather than post a picture. Then if anything needs to be copy/pasted, it's easier for the people trying to help you! Use the 'code' format from the edit menu </> , and it comes out like this, and doesn't take up too much space:
                                  code_text
                                    SoDamnInsane
                                    Thank you very very much.... @Phaedrux and @droftarts !!
                                    I'll do that right now, lol.
                                    I'll keep you posted! 😄 😄
                                    Maybe there's a chance that i can start printing this year... 😂
                                      SoDamnInsane @droftarts
                                      @droftarts said in Strange values on E0 temp, and bed not heating up.:
                                      code_text
                                      I'm very sorry.
                                      I'll keep it in mind for a next time... And there will be a next time, LOL.
                                      Problems with Z axes. But first tackle this problem. 😉
                                        SoDamnInsane
                                        Thanks @Phaedrux and @droftarts !! You made me very, very happy!!! It's working now! 👍 👍
