    Y offset correction
    My Duet controlled machine
    510
    • PaulHewundefined
      PaulHew
      I have a Maestro board running RRF3.
      I have tried but cannot fathom it out as G10 is something different now.
      I have lost Y axis build area, since I installed a Titan Aero extruder mount.
      I know how much Y I have lost, 20mm, but do not know how to tell the Duet how to compensate for it.
      Please could someone assist, as I am lost.
      TIA
      Paul.
      • Ntrackundefined
        Ntrack
        Can't you just substract 20mm form your Axis maxima ?
        • SIamundefined
          SIam
          did you mean that your y endstop is now on position -20?
          if yes you can set the Axis axis minima Limits with:
          M208 Y-20 X0 Z0 S1
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          • PaulHewundefined
            PaulHew
            Thanks for your replies.
            This is my current M208
            M208 X0:235 Y0:235 Z0:235 S0                       ; set axis minima:maxima
            My bed is still the same size.
            X0 is correct, it is Y that is wrong.
            When Y is at 0, the nozzle is over the control box of my Ender3, due to the Hangtight mount I am using, it has created an offset.
            I have enough travel on the bed to be able to offset this dimensional discrepancy, but as I said, I am not sure how!
            So, could I use Y20:255 in the M208 command?
            Thanks again,
            Paul.
            • SIamundefined
              SIam
              @PaulHew said in Y offset correction:
              This means the nozzle is so 20mm out from the bed (pos. 0) ? or 20 mm to far in the bed?
              • PaulHewundefined
                PaulHew
                so when Y hits the endstop, that is zero, but the nozzle is off the bed.
                Hope that makes sense
                P.
                • SIamundefined
                  SIam
                  ok so you have to move your head 20mm to reach your bed, in this case is the endstop on -20 mm and the bed is 0?
                  M208 X0:235 Y-20:235 Z0:235 S0                       ; set axis minima:maxima
                  PaulHewundefined 1 Reply Last reply Reply Quote 3
                  • PaulHewundefined
                    PaulHew
                    Thank you, I will try when it has finished printing.
                    P.
                    • PaulHewundefined
                      PaulHew @SIam
                      @SIam Thank you, That worked.
                      Appreciate the help
                      Kind Regards,
                      Paul
