    Duet 3 motor wiring?
    792
    • Danalundefined
      Danal
      There is no universal color code for those motors, particularly those with plugs. On most of them, Black/Green is a motor coil and Red/Blue is a motor coil.
      We want a coil on the "leftmost" pair of the four pins on the Duet, and the other pair on the "rightmost" two pins. The exact order of, say, Black/Green or Green/Black on the "leftmost" pair of pins does not matter; only that they are together on the left, and red/blue with each other on the right.
      • Garfieldundefined
        Garfield
        Do not believe the colours - period - they cannot be trusted.
        Go by pin number instead which tends to be consistent.
        If you look at the plug for the stepper which is most likely a JST PH connector, look at the side that has the ridges (not the flat side) and the pins are left to right 1 to 6.
        In your top picture Pin 1 is blue. Your wiring in those images looks fine.
        Pin 1 you can regard as A1, Pin 3 as B1, Pin 4 as A2, Pin 6 as B2 - don't waste your time trying to second guess rotation just be consistent then set that up in config.g
        If you're really struggling you need a multimeter to identify the coils on your steppers, and to make sure the coils aren't shorted. If you have the stepper drawing it helps a lot but my experience is that the pin numbers are pretty consistent.
        Just out of interest run M906 and see what is reported for stepper currents - if any are 0 they won't work and the problem is in the config.g M906 settings.
        • Government_Baconundefined
          Government_Bacon
          i got the wiring figured out i have 3 different motor all have different pinouts. just need to figure out how to get the dual z axis to work. im not sure if i have the steps set right for the second z motor.
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 11 2020 20:17:48 GMT-0800 (Pacific Standard Time)
          M550 P"Duet 3" ; set printer name
          M569 P0.0 S1 ; physical drive X 0.0 goes forwards
          M569 P0.1 S1 ; physical drive Y 0.1 goes forwards
          M569 P0.2 S0 ; physical drive Z 1 0.2 goes forwards
          M569 P0.3 S0 ; physical drive Z 2 0.3 goes forwards
          M569 P0.5 S1 ; physical drive E 0 0.5 goes forwards
          M584 X0.0 Y0.1 Z2:3 E0.0:0.5 ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E415.00:400.00 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X500 Y500 Z500 S0 ; set axis maxima
          M574 X1 S1 P"!io3.in" ; configure active-high endstop for low end on X via pin io3.in
          M574 Y1 S1 P"!io4.in" ; configure active-high endstop for low end on Y via pin io4.in
          M574 E0 S1
          M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
          M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out1" T0 ; create nozzle heater output on out0 and map it to sensor 0
          M143 H0 S280 ; set temperature limit for heater 0 to 280C
          M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
          M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
          M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
          M106 P2 S1 H0 T45 ; set fan 2 value. Thermostatic control is turned on
          M563 P1 S"Hot End" D0 H0 F0 ; define tool 1
          ; Custom settings
          M584 X0 Y1 Z2:3 E ; two Z motors connected to driver outputs Z and E1
          M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M208 X-5:475 Y0:250 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
          T1 ; select first tool
          • Garfieldundefined
            Garfield
            You need to know the pitch of your leadscrew / ballscrews (if that's what your Z axis is) and also the degree steps of your stepper.
            Then go here >> Look here for leadscrew driven systems steps per mm
              Government_Bacon
              its 400 steps i know that one side works fine the the other skips steps
              • Garfieldundefined
                Garfield
                I do hope that the steppers are the same - can't be different on the Z as I don't think you can set different values for each Z stepper.
                400 seems very low - is this a leadscrew system ? - where did 400 come from ?
                • jens55undefined
                  jens55
                  400 is standard on Creality CR10 varieties
                    Government_Bacon
                    both motors are 1.8 degree
                    • Garfieldundefined
                      Garfield
                      400 may be standard on CR10's with whatever controller they use - 1/4 microstep ?
                      On 1/16th microsteps a typical 2mm pitch leadscrew is more like 1600 steps, the 400 only applies to the Creality controller (that I confess I know naff all about). The big G seems to indicate that the CR10 uses TR8x2 - so 2 mm pitch leadscrews.
                      at 1.8 degrees per step with the standard Duet 16 microsteps as per the OP's gcode
                      That's 1600 steps per mm ....
                      • jens55undefined
                        jens55
                        These are the relevant lines of my config.g
                        M92 X80.20 Y80.15 Z406.00:406.00 E415:415 ; Set steps per mm
                        M350 X16 Y16 Z16:16 E16:16 I1 ; Configure microstepping with interpolation
                        Edit: Extruders are BMG clones (reduction gear)
                          Government_Bacon
                          so i plugged in a different motor and the problem went away. all is working
                          • infiniteloopundefined
                            infiniteloop @Garfield
                            @Garfield said in Duet 3 motor wiring?:
                            400 is standard with 1.8° full steps (for the CR-10), so @jens55 is right. For 0.9° steppers, take 800.
                            But, you are not wrong either: it all depends on the sequence of M92 / M350 in the config.g. If you define the steps/mm first (M92) and configure microstepping (M350) after that, RRF wants the full steps in M92 - just as @jens55 posted it above.
                            @Government_Bacon has done it just the other way round, so, in his M92, he must multiply the full steps by his microstepping value, which, according to his config, should be 400*16 = 6400.
                            This is documented here, in the Examples section of M350.
                            EDIT: I should better read the documentation I cite: with M92, the steps/mm default to 16 microsteps, not full steps. So, the CR-10 with a 1.8° stepper for Z, needs 400 1/16 steps per mm. If microstepping is changed to 1/128 by M350 before setting the steps/mm with M92, these will be 400 * 128 / 16 = 3200.
                            Government_Baconundefined 1 Reply Last reply Reply Quote 0
                              Government_Bacon @infiniteloop
                              @infiniteloop i set it to 6400 and it is very wrong
                                infiniteloop @Government_Bacon
                                @Government_Bacon
                                My bad. Reading the link carefully, it states something different: The 400 steps/mm are valid for a default of 16 microsteps, not for full steps as I blindly assumed. So, as long as you stay with 16 microsteps (which is recommended for Duet2), the sequence of M92 and M350 doesn’t matter. Sorry for the confusion.
                                  @infiniteloop its all good. i checked it just to make sure i had my steps right
